Question about Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My Affinity Frigidaire dryer will not work.
When I push start it either comes on for 1 second and then the Drying, Cool Down and Extended tumble lights come on blinking or the lights just come on blinking and it does not start at all. I have only had this dryer for 3 weeks!
  • qlina Feb 09, 2009
    Same problem...dries for a few minutes, then the dryer stops and the 3 lights start blinking
4 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
  • 49 Answers
SOURCE: my affinity dryer will not continue the cycle
the lights that are flashing probably mean a certain error has occured. call a servicer to find out what it means
Posted on Aug 21, 2009
SOURCE: iDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Great. This is the same error my electric dryer is showing now...
Posted on Oct 05, 2011
Dryer is tumbling but no heat - when I reset it shuts off after about 10 min and the Drying, Cool Down, and Extended Tumble lights are all flashing.
Janet McDonald,
I understand that you are having trouble with your dryer not heating and not running a full cycle and shutting off with the Drying, Cool Down, and Extended Tumble lights flashing. What I suggest is to give your appliance a hard reset. You will do this by either unplugging it or cutting the power off at the circuit breaker for 3-5 minutes. After the 3-5 minutes, bring power back and try to start a cycle. If it does not complete the cycle and shuts off with the lights flashing, I suggest to either contact the manufacturer or a local appliance technician. This way you will be able to locate the cause of this issue and have it resolved.
-Best Regards-
Jan 14, 2014 | Frigidaire AEQ6700FE Affinity Electric...
My Frigidaire Affinity dryer won't tumble; it just hums
Thats not even a question Stupit!!!! A good hummer is good for you ********!!!!
Aug 04, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Turns on & tumbles but no heat. top got really hot b4 it quit drying
You may have a clogged vent.your machine gets to hot and safety switch kicks in or you lost the blower fan
when drying does it sound like air is blowing.... let it cool down and see if it starts again
Dec 19, 2010 | Frigidaire Electric Dryer
My dryer quit working this morning. The light and beep go off but the drum dies nothing.
I have the Frigidaire Affinity Washer and Dryer. A few weeks ago my Washer door switch went out I changes that with no problem. Now the Dryer has just stop quit working. Here are the symptoms on the ; 1>it's plug up and the power is fine 2> there is no errors on the panel 3> control operate fine. 4> close the door, set the controls, press start, No spinning. 5> when you press start you hear a buzzing sound for about 5 seconds, then nothing... Is it over for the dryer I bought 3 years with out extended warranty, or is the a simple fix? Thanks, Rob...
Sep 07, 2010 | Frigidaire Affinity AEQ6000WH Dryer
The dryer stops after about 15+ seconds.
No, but mine started doing the same thing today. Did it once before and same- started working again. Any suggestions for last poster and myself?
May 31, 2010 | Frigidaire AGQ6000ES Gas Dryer
My affinity dryer will not continue the cycle
Aug 18, 2009 | Frigidaire Affinity AEQ6000WH Dryer
IDry Frigidaire Affinity Gas Dryer Error "AD" shuts off in 5 min
Jun 27, 2009 | Frigidaire Electric Dryer
Error code E4A on my frigidaire affinity dryer
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Dec 02, 2008 | Frigidaire Dryers
Won't Start
do you have the power cord correctly hooked up and have the correct voltage ? is the white wire in the middle? you should have 120 volt with red-white . 120 black- white and 240 black-red... careful with electricity it can hurt and kill you. let me know if you fix this one...krazytech
Sep 16, 2007 | Frigidaire AEQ6000ES Electric Dryer
Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer Logo
194 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
