Question about KitchenAid Warming Drawer - 27" - Biscuit Oven
KitchenAid Warming draw stopped working
We left the warming draw on overnight by mistake.  When we woke up it was off.  The circuit is working and I checked the timer over ride (both troubleing shooting steps in the manual).  Before I take it apart any suggestions?
Trying to cook prime rib that needs to rest in hot oven for 2 hours. How do I turn off cooling fan
that fan is a cooling fan but not for the food,it's to cool down the electronics in the oven like the clock assy. so it's doing it's job,that's why i tell people not to use the self clean feature on stoves or ovens,the temp. gets up to 1000 degrees and it will sooner or later damage the electronics in the machine,so if you're gonna use it use it after the holidays,i see people use it the day before thanksgiving,the oven stops working and parts have to be ordered or if it's an older oven you can't get parts anymore and they can't cook so that fan is a good thing.happy holidays.you have to set the oven on a low setting just to keep the oven warm.like 200 or 225,also some ovens have a warming draw under the oven door,if you have this make sure you clean it first,i've seen them filled with dust because nobody ever uses it.here i googled this for you
https://www.chowhound.com/post/meat-warm-360832
Dec 23, 2017 | Ovens
Frigidaire oven warming light stays on when not using it
Hi waynepaige - Try resetting the unit by either unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and turn on the oven. Is the warming light still on? An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the EOC (Electronic Oven Control), faulty light switch, or a potential wiring failure.
Apr 12, 2013 | Frigidaire 30 in. Electric Gallery Series...
My daughter-in-law just moved in to a newer home with a stainless steel Kitchen Aid ceramic top stove. It has a warming oven, a convect feature etc. However, with options etc. it is very confusing to...
Kitchen Aid manuals are available from their support site: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . The model number is needed to locate the manual. For ranges, the plaque with the model number is inside the oven door.
The KitchenAid ovens that I know will turn off when you press Off (unless the control lock is on - then you need to disable the control lock). The Warming Drawer will have a separate Off button. Dual oven units require you to select which oven and then press off.
See http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KESS907XSP_Use%20and%20Care_EN.pdf for a similar range. (ceramic glass cooktop, convection feature and warming drawer)
I hope this helps.
Jul 02, 2011 | KitchenAid Ovens
Warming up, big POP sound and totally stopped working.
Hello- Wow-  Sounds like the failure of one of the elements.  Sometimes there's a bright arc welding flash with it too. Look inside oven with flash light and inspect elements. If one of them is burned through, then it must be replaced. In some instances, control boards and other circuits can also be affected, but most work just fine when the element is replaced.     Please acknowledge this posted solution if helpful.                                   Have more info if needed- thanks-  Ed
Mar 24, 2010 | Wolf Range Ovens
Need heating element for oven of 1950's Frigidaire by GM stove
Fixya is unable to identify parts sources.
Jan 23, 2018 | Ovens
Electric warming drawer will not heat
Found that there is an electrical connection at the point the main electric enters the back of the stove. There is a connector for the element that was not connected. Now it works!
Feb 18, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Thermador sm272zs microwave/oven combo
Woke up this morning and heard my smw272 built-in oven beeping. Oh no! First the display (but at least the oven worked) now the oven is beeping (fault signal according to manual) and the thing is dead except for the microwave and warming bin. The only way to turn off the incessant beeping--which was driving me crazy--was to go outside to the fuse box and turn off the circuit to the oven. Yeah, I stopped the beeping but now I'm at the mercy of the unscrupulous service repairman--was quoted a flat fee to drive out and a hefty hourly rate (i.e., "value added" service charge). OUCH! Hey folks, please follow my simple advice if you want to avoid making a big mistake: NO MORE THERMADORS. RUN--DON'T WALK AWAY FROM THIS BRAND!!!
Pruneau
Aug 18, 2007 | Thermador SMW272 Electric Double Oven
KitchenAid  Warming Drawer - 27" - Biscuit Oven Logo
77 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
