Question about JRC 1800CP GPS Receiver
JRC FF-30 colour fishfinder
Just bought one, there are two wires on back, one red the other black. The seller has tagged the black one as power (+) and the red one as negative(-) This seems to be backwards but can't find anyone to tell me otherwise, and as this is a JAPAN RADIO Co. product, don't know if I should go with my instinct of red=positive/black is ground...
Any help out there?
Anyone have a manual I can get?
5 Suggested Answers
SOURCE: DSC hookup
It appears to have a computer interface,It uses an RS232C Interface, a small D9 Socket on unit, you need a specially wired cable, to talk to your unit, with GPS software, it sends out NEMA codes to the PC. You also need driver, and software, software at the least. www.jeppesen.com/documents/.../FullCompatabilityListAug09.pdf software compatibility list above.
I looked but couldn't find a manual...
Posted on Apr 03, 2010
saailer
  • 1871 Answers
SOURCE: JRC GPS JLU 128 Plotter
Hello! Are you installing a new antenna or using the same antenna that is already installed on the vessel?....................Guru.....Saailer
Posted on Jan 15, 2011
Ironfist109
  • 3018 Answers
SOURCE: looking 4 instruction manual 4 JRC Plot 500F GPS Receiver
Regards, Tony
Posted on Jun 06, 2011
emissionwiz
  • 79847 Answers
SOURCE: The antenna cable of JRC
I have the service manual for this GPS and it doesn't list the wire colors directly for the plug. This much I'm sure of:
RED-12 VOLTS (+)
BLACK-GROUND (-)
GREEN IS COMMON AND HOOKS TO CHASSIS OF GPS
THAT LEAVES THE BROWN AND YELLOW, BASED ON STANDARD DIN WIRE COLORS THE YELLOW IS LIKELY GPS OUPUT. HERE IS THE LINK TO THE SERVICE MANUAL. IF YOU OPEN UP THE UNIT THE WIRE COLORS SHOULD BE PRINTED ON THE CIRCUIT BOARD THAT THE PLUG IS ATTACHED TO.
http://www.pronav.no/engelske-manualer/ff50serv-eng.pdf
I BOUGHT A USED JAZZY JET 3 ULTRA WITHOUT BATTERIES AND I HAVE BOUGHT 2 NEW BATTERIES BUT AM NOT SURE HOW THE WIRES HOOK TO THEM, IF THE 2 BATTERIES HOOK TOGETHER.
Locate the two wires from the circuit breaker attach one wire (black if marked) to the negative post of the rear battery and attach the other wire (red if marked) to the positive post of the front battery. Locate the two wires coming from the power module plug with a red and black wire. Attach the red wire to the rear battery positive post and the black wire to the front battery negative post. attach the joystick to the nine pin plug at the rear of the chair and turn it on. You should have power at the joystick and the chair should work. Disconnect the joystick put the shroud cover back on grease the seat post and reattach the seat then plug in the joystick and charger plug at the rear of the chair. Charge the batteries before use and charge them overnite for the next 20 days. If you use the chair daily charge your batteries everynite while you sleep unplug in the morning. If you don't use the chair daily charge at least once per week or after you use the chair. Always put the chair up fully charged if you are going to be out of the chair for an extended time the disconnect the batteries at the large plug going to the power module Hope this helps you
Apr 13, 2011 | Jet 3 Ultra Power Chair
Hello, I need to know the wiring connection destinations by color for all wires coming out of the back of the Pioneer DEH-P9200R car audio receiver. Thanks in advance. John from Baltimore
If this helps you then please help my rating,voting for me would be great too thanks.
Black - Ground
Blue - Power Antenna / Control for an AMP
Orange - Constant 12 Volts
Red - 12 Volts when the ignition is on, 0 Volts when it's off
[Speakers]
[Front]
Gray - Front Right Positive
Gray Black - Front Right Negative
Green - Front Left Positive
Green Black - Front Left Negative
[Rear]
Gray Red - Right Rear Positive
Black Gray - Right Rear Negative
Green red - Left Rear Positive
Black Green - Left Rear Negative
Nov 15, 2010 | Car Audio & Video
I just bought a Panasonic CQ-C1301U deck, and want to install it into my car. The wiring schematic is not the same as my wiring harness. Which wires are which? (Grey, Grey with black stripe,Yellow, Blue,...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps
Nov 11, 2010 | Panasonic CQ-C1301U CD Player
Wont turn on i bought it though craigslist
well this is what you do to check it to see if you bought a blown amp.
wire it into your car and then take a digital volt meter check to see if you have power and ground and remote turn on .
take the red lead and put it on the battery wire at amp and the black lead to the ground then see if you get 12volt to 14.4 use the amps ground for the black test lead if nothing you may have blown fuse or bad ground.
check the remote wire same way as about if you get 12 to 14.4 volt it works if not could be blown from radio or bad ground
checking the ground put the black meter lead on ground wire and the red lead on 12 volt power source if nothing a bad ground.
if your get voltage on the remote wire and battery wire and have good ground then you need to call the seller and get your money back ..
Oct 16, 2010 | Eclipse EA3422 Car Audio Amplifier
What color is the power wire in 1994 toyota pick up
this might help
1994 Toyota Pickup Car Security Wiring Diagram
Battery Constant 12v+ Positive Wire (+): White And White/Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Black/Yellow
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Black/Yellow Or Black/Red
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Blue/Red
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Negative Wire (-): Red/Black
Parking Light Negative Wire Location: At Steering Column Harness
Parking Light Positive Wire (+): Green
Parking Light Positive Wire Location: In Drivers Kick Panel
Power Door Lock Negative Wire (-): Blue/White
Power Door Lock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Power Door Unlock Negative Wire (-): Blue/Yellow
Power Door Unlock Negative Wire Location: At Door Control Relay. The door control relay, is located behind the driver dash speaker.
Door Trigger Negative Wire (-): Black/White Or Black
Door Trigger Negative Wire Location: At 2-Pin Plug, Top Of Fusebox
Domelight Supervision Wire: Use Door Trigger, Requires Relay
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Green/Red
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Diagnostic Connector. The diagnostic connector, is located on the passenger inner fender near the fuse/relay box.
Brake Light Positive Wire (+): Green/White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Nov 29, 2009 | 1994 Toyota Pickup
HORN DIAGRAM FOR A DODGE RAM 1500 (CONNECTIONS)
Battery Constant 12v+ Positive Wire (+): Black/Orange And Red/White
Starter Positive Wire (+): Yellow
Ignition Positive Wire (+): Blue (16 Gauge)
Second Ignition Positive Wire (+): Yellow/Red
Accessory Positive Wire (+): Blue (10 Gauge)
Second Accessory Positive Wire (+): Orange
Second Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Black/Yellow
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire (+): Orange/Violet
Power Door Lock Positive Wire Location: In Drivers Kick Panel, White 6-Pin
Power Door Unlock Positive Wire (+): Pink/Violet
Power Door Unlock Positive Wire Location: In Drivers Kick Panel, White 12-Pin
Door Trigger Negative Wire (-): Yellow
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: Use Door Trigger (Requires Relay)
Horn Negative Wire (-): Black/Red
Tachometer Wire Negative Wire (-): Gray
Tachometer Wire Negative Wire Location: At PCM, Connector 1, Pin A7. The PCM (powertrain control module) is located on the firewall next to the wiper motor.
Brake Light Positive Wire (+): White/Tan
Factory Alarm Disarm Wire (-): Black/Orange (To disarm requires a (-) negative through a 1565 ohm resistor and an extra relay to connect.)
Factory Alarm Disarm Wire Location: In Drivers Kick Panel, White 12 Pin Plug
Aug 22, 2009 | 1998 Dodge Ram 3500 2WD
CAN I POWER MY FISH FINDER GOING DIRECTLY TO THE
Yes you can. Basically the red wire goes to the fuse box connection. The fuse box should then be wired into the positive battery terminal. The black wire is the negative ground wire and needs to go directly back to your negative battery terminal or to a common negative buss bar.
Jun 15, 2009 | Humminbird Fishfinder 565 With Transom...
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Jun 14, 2009 | Garmin Color Fishfinder 160c
I just bought a gps440. How do I wire it for power in my boat
There should be a red wire and a black wire. Ignore any other color wires for now as these are not basic power wires.
Simply connect the red wire to the positive terminal on your battery. The black wire goes to the negative terminal on your battery. If there is an inline fuse, this needs to go on the red wire, so the fuse is between the positive terminal on the battery and the sounder on the red wire.
Mar 19, 2009 | Garmin Gpsmap 430
Wiring hook up in the back for whirpool dryer
assuming you are referring to the power hookup,there is no positive negative, (it's not D.C.) red and black are the hot lines(240 volt between them) white is neutral and green is equipment ground.voltage reading should be 120 volts from red or black to white as well as green, 240 volts from red to black, 0 volts from white to green
Sep 08, 2008 | Whirlpool GEW9250 Electric Dryer
JRC 1800CP GPS Receiver Logo
1,199 people viewed this question
Top JRC GPS Experts
David Burbee
David Burbee
Will Halftowaite
Are you a JRC GPS Expert? Answer questions, earn points and help others
