Question about Kodak EasyShare C330 Digital Camera
FILESYS ERROR E00100
I get this error when trying to format a memory card!! PLEASE HELP!!!
  • Anonymous Dec 22, 2008
    when insert the memory card SD 2GB get the message 'memory card is full' and when try to format it I get the message "error e00100" from other posts I found that propably the card memory is too big for that Kodak model. Souds strange, but I'm going to buy 1GB card and try again...
  • 34 Answers
Which size has the card?
Is the write protection enabled?
The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
But try an firmware upgrade.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Posted on Jun 09, 2009
Obertelli
  • 3006 Answers
SOURCE: i have a kodak c310, trying to format the card and
The c310 will only accept SD cards up to 2GB.
You haven't said which card you're trying to use but the symptoms are typical of those encountered if you try either a larger capacity SD card (which go to 4GB maximum) or if you're trying to use a later SDHC (the HC means High Capacity) card. The c310 was designed and manufactured before SDHC cards were manufactured and is incompatible at the basic hardware level. SDHC's will fit inside as they have the same form as SD cards, but your camera is unable to use them.
If you have tried using the wrong card then all you need to do to fix the error is to replace it with a standard SD card not exceeding 2GB. In practice you'll find that your camera may have issues with some brands/models of 2GB SD cards but that it will work fine with any make or model of 1GB SD card. The smaller capacity card will also ensure that your camera does not become awkwardly slow in operation.
Hopefully I've answered your question; all I ask in return is that you return the favour by rating my answer.
Posted on Oct 21, 2009
SOURCE: it says the memory card
The Kodak Z612 only accepts standard SD cards up to 2GB. As you rightly point ot the physical charactreristics are identical, its the internal format of the card that defines SDHC.
Standard SD cards use FAT - which has a 2GB limit.
SDHC cards use FAT32 - which has a limit of 32GB.
Stick with 2GB or smaller standard SD cards.
Posted on Jan 16, 2009
Dipu007
  • 2110 Answers
SOURCE: Trouble Formatting New SD card
try to format using a card reader through PC...
Posted on Feb 10, 2009
  • 11967 Answers
SOURCE: I just purchased a new memory card and when I
Go into the camera menu and find "reset"...follow the on-screen instructions. Then, try to format the card again.
Posted on Dec 18, 2009
  • 102366 Answers
SOURCE: Inserted 4G memory card...says memory
The C330 uses MMC and SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD slots, they are electronically incompatible and won't work. You need to go with cards 2GB and smaller.
Posted on Jan 11, 2011
What does filesys error e00100 mean
Hello and Welcome to FixYa!
Error e00100 means that the card is corrupted or formatted for another digital camera.Format memory card and see the results,Try to format the memory card using a card reader with the PC, if error still exists then it means the memory card is electronically incompatible and won't work The Kodak C310 uses MMC and SD cards and may be you are using SDHC memory card, In this case change the memory card,
I hope problem will be solved, if error still exists then contact to Kodak Cameras service providers.
I hope this solution helps you
Your token of appreciation in the form of Four thumbs and testimonial will be esteemed.
THANK YOU and Keep Visiting FixYa
Apr 11, 2011 | Kodak EasyShare C310 Digital Camera
Inserted 4G memory card...says memory card is full...when I try to format the card, get filesys error e00100.....
Jan 11, 2011 | Kodak EasyShare C330 Digital Camera
Trying to format screen says filesys error e00100 how do you fix this
if you already try to fromat the memory card into the camera and there's an error come.try to format your memory card from your computer if you have card reader.if the problem still occur you memory card have a problem and you need to buy new one.
thank you
Jul 08, 2010 | Kodak EasyShare C310 Digital Camera
FORMAT MEMORY CARD
After downloading any pics from the card using a card reader if necessary, go ahead and format it in the camera.
Jun 21, 2010 | Kodak EasyShare C315 Digital Camera
Filesys error e00100 when attempting to format a Scandisk 2.0 gb memory card.
Hi ,Welcome
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 02, 2009 | Kodak EasyShare CD33 Digital Camera
    Feb 10, 2009 | Kodak EasyShare V803 Digital Camera
    I Cant format my memory card
    use a memory card reader and connect it into your PC, let the your memory card plug into your reader and format it into your pc using that;
    Nov 23, 2008 | PNY 2GB microSD Memory Card
    FILESYS ERROR e00100 2.0GB PNY technologies
    try formating
    u get warranty on this and hence approach the point of sales
    Jul 01, 2008 | PNY 2GB microSD Memory Card
    Kodak EasyShare C330 Digital Camera Logo
    1,851 people viewed this question
    Top Kodak Cameras Experts
    Jerry Greenberg
    Jerry Greenberg
    Computer Links
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
