Question about Denon AVR-3803 Receiver
Analog output from digital input for Denon AVR 3803
I'm bringing in audio from a Playstation 3 through an optical cable. I'd like to be able to output the sound to a set of Sony wireless earphones. The base for the earphones only has a right and left analog input. I've tried plugging the earphones into the audio out jacks for VCR 1 and VCR 2 but can't get any sound. Will the receiver not convert the digital to analog? If it does, which set of audio outputs could I use for this?
Thanks for the help.
H Lobdell
On the Denon AVR-888 (and I presume others), you have to put the unit in "record" mode. This is covered under "Other Operations and Functions" in the manual. Here are the steps:
1. On the front of the unit, press the zone2/rec select button
2. Turn source select until "recout source" is displayed
3. Turn source select to choose the input source
Hope this helps.
Matt
Posted on Apr 29, 2009
How do I set my receiver to read TV/CBL Dolby Digital. It is a AVR 789
The Dolby digital signal is outputted only through the Optical or Coaxial socket of the CBL box. you will have to get an optic fiber or coaxial cable depending which cable box you have and connect it to the digital input of the Denon receiver. The Denon's digital input are already assigned at the back. Eg: Optic input might be labeled CD so if you are connecting the CBL box to the optic input remember to select CD on the Denon to hear the cable sound, same goes with the coaxial input.
Aug 27, 2011 | Denon AVR-788
Hi Have Vizio Flat Screen and a Denon 3803 receiver. The Tv a Vizio 65 Inch flat screen was here. Out of the wall is a power cord and red,blue,green monster cable. Red and Blue is audio and green video I...
Red, Green and Blue cables together typically denotes a component video signal - an Analog, High Definition transportation for video. This cable does not carry audio, you need another cable to hook up audio between the DVR and receiver. You can use either an RCA stereo cable (red and white), optical-audio, HDMI, or a whole plethora of other audio cables. I would recommend optical or HDMI to get the most out of your system.
Jul 16, 2010 | Denon AVR-3803 Receiver
What is the best way to attach a Sony SCD CE595 CD player SACD to a Denon AVR 2105 Receiver. I thought the optical input would be best but according to a web posting, toslink does not support SACD
That is correct. Digital connections through some models of SACD players are via "firewire", otherwise it is analog output. There are no optical connections.
The shortest pair of RCA cables, or even component video cable as an alternative will work.
Dec 12, 2009 | Denon AVR-2105 Receiver
Can't record out from a digital input
It only passes the signal it see's. Digital for Digital and Analog for Analog. Try running a Standard analog RCA from your Cable box to the receiver then try and record. Hope this helps. If you still have an issue, post a comment and I can help you further.
Sep 18, 2009 | Denon AVR-3803 Receiver
How do i hook up a PS3 through my denon avr1905?
ONCE YOU CONNECT THE OPTICAL CABLE AT THE DENON, YOU ALSO NEED TO CHECK THE AUDIO SETTING FOR THE INPUT USED AND MAKE SURE OPTICAL IS SELECTED AND LAST ONCE YOU SELECT THE SOURCE INPUT USED TO CONNECT THE PS3 TO THE DENON PRESS THE INPUT MODE BUTTON ON THE FRONT LEFT OF THE DENON UNTIL YOU SEE DISPLAYED THE WORD AUTO, THIS SHOULD GET YOU SOUND AS LOND AS THE PS3 IS OUTPUTING AUDIO OVER THE OPTICAL
Mar 01, 2009 | Denon AVR-1905 Receiver
No output to Zone 2 from preout to 2nd power amp for second room speakers
OK, From what I am understanding is that you both are trying to uilize a digital audio source (HDMI cables are digital audio only) and hence this is the problem. You can only use an analog audio source (connection) to utilize the audio output to zone 2. A simple soultion is to use the analog audio in conjuction with the digital. Connect the digital (HDMI, Optical, Coax) to the main zone and the left and right audios to zone 2.
Dec 22, 2007 | Denon AVR-3803 Receiver
Denon AVR-3803 Receiver Logo
887 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
