Question about NetGear RangeMax NEXT WNR834B Wireless Router
Xbox live problem
There is no problem connecting to xbox live through my WNR834B netgear router, i have signed up and everything for xbox live but when i try to play a game through it, it says that there are nobody online which is imposible because i have checked for several days now PLEASE HELP ME!
  • Bernie Reeves May 11, 2010
    what games have you tried on-line ?
  • 854 Answers
The NETGEAR router is a firewall. It blocks ports to prevent attacks from programs or users from the Internet to the computers or devices behind your router. Each application on the Internet uses ports. For example, when you browse the Internet, it uses port 80. An FTP server uses port 21. This is the same as your Xbox that uses ports to connect to the Internet. Before we proceed to any troubleshooting procedures, check if the Xbox is working directly to the modem. This will verify if there is something wrong with the Xbox. If the game console won't connect to the Internet when directly connected on the modem, it means that it is not your router blocking the connection. Here are the steps on how to open the ports on the router:
A. Determine the IP Address and MAC Address of the Xbox.
Note: You may find the IP address and MAC address of your Xbox on your Dashboard's Network Settings. Please refer to your Xbox manual for more information on this.
B. Reserve the IP address.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing or in the address field and click Enter or Return key.
3. For security reasons, the router has its own user name and password. When prompted, enter admin for the User name and password for the Password, both in lower case letters.
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. When the setup page opens, click on LAN IP Setup under Advanced tab.
5. Click on Add under Address Reservation.
6. Under Address Reservation window, please select the radio button of the computer you wish to add from the Address Reservation Table.
7. If the computer you want is not on the list, please click on the Refresh button to update the table.
8. If the computer is still not on the Address Reservation Table, please type in the IP Address, MAC Address, and Device Name of the computer you wish to add.
9. Click the Add button when done.
C. Forward the ports.
1. Click on the option with the name Port Forwarding/Port Triggering under the Advanced. For older firmware version, click on Port Triggering tab or just click Port Forwarding on Please select the service type.
2. Click Add and another window will pop up.
3. Type Xbox for Name. Set the radio button to Enable.
4. On Outgoing Port Range, set the Start Port and End Port to 3074.
5. On Incoming Port Range, you also have to indicate 3074 for Start Port and End Port. Save the settings by clicking on Apply.
6. Please repeat steps b to e and indicate 88 for Start Port and End Port. Then change the Name to Xbox2.
Note: If it still does not work, you may try these other options:
D. Lower down the MTU.
1. Access the Setup page of the router (refer to Step 2 above).
2. Click on the WAN Setup under Advanced tab.
3. Lower down the MTU size to 1492, 1400, 1358 or 1300.
4. Click on the Apply button.
E. Enable UPnP.
1. Go to UPnP tab of the router.
2. Enable UPnP and then save the settings by clicking on Apply. Some websites and devices require UPnP or Universal Plug and Play. Just make sure that it is enabled on the router.
F. Upgrade the firmware.
Note: Follow the steps below if the above troubleshooting still do not allow Xbox to connect using the router.
1. Please verify the router version and model either underneath or at its side panel.
2. Go to and please select the model of the router.
3. Click the appropriate version of the router.
4. Select the link of the latest firmware. Click the button Right-click and Save to Download. Save the file to the Desktop.
Note: Please perform firmware upgrade with Wired or Ethernet connection only.
5. Before upgrading, please write down all current settings since you need to enter them manually.
6. Using the computer hardwired on the router, please launch Internet Explorer and access the Setup page of the router (refer to Step 2).
7. Click on Maintenance and then Router Upgrade.
8. Click on Browse and locate the upgraded file in your Desktop. Then click on Upload.
9. Please wait for the router to reboot. After a successful firmware upgrade, you need to reset the router.
E. Reset the router.
1. Please push the reset button at the back of the router and release after 30 seconds.
2. Unplug the power adapter for 10 seconds and then plug it back in.
(this note should go before the step to Reset the router) Note: Resetting the router will erase all the settings so it needs to be reconfigured afterwards. The router can be reconfigured using the setup CD or by manual configuration.
Posted on Apr 27, 2009
How do I find wps button on Netgear WNR834B
The Netgear WNR834B does not support WiFi Protected Setup (WPS).
You can follow the documentation in the manual to setup WPA-PSK (Pre-Shared Key) and use the key to add devices to your wireless network.
Jun 24, 2014 | Arris SURFboard SBG900 Wireless Router...
How to turn Netgear WNR834B into a repeater
I don't think the Netgear WNR834B is capable of acting as a repeater but there is another solution. I would decide where I want to put the Netgear WNR834B for best coverage and then do the following. Go buy the Powerline Ethernet Adapters of your choice and put one at the main connection and plug a ethernet cable into a open switch port. Second go to where the repeater is to be located and plug the 2nd Powerline Ethernet Adapters in and connect to the Netgear WNR834B LAN port. Be sure to turn off DHCP on the Netgear WNR834B and assign a IP address that is not used. I normally use the highest address in the last octet so that I can remember for management. I hope this helps you.
Apr 28, 2010 | NetGear RangeMax NEXT WNR834B Wireless...
Connected to the internet, but cannot browse any webpages
i think u have soem firewall isse in router also try to reset router then check .
reset switch in back side of router.pres it for 10 seconds .then it reset to defaults.
Mar 28, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Msg. conntected with limited access
Try this.
Unplug the Router.
Unplug the modem.
Wait about 15-20 secs.
Reconnect the modem.
wait about a minute or until all the lights are solid on the display.
Reconnect the Router.
Wait about another minute until everything is given time to start up.
Try connecting again.
If it still does that, it may be a problem with your computer that your trying to access with wirelessly.
My mother had that problem on one of her laptops, it turned out that her particular installation didn't support WPA or WEP incryption. I did a full reinstall and now it works.
If you want to avoid a full reinstall you can try uninstalling the wireless network card, then reinstalling it.(Make sure you go to your manufacturers web site first to download the proper driver for your model)
I hope this helps,
Nov 19, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Loss of connection
This problem is mainly cause by the router firmware, so I advuice you to contact Netgear and ask them to update the firmware of your router to resolve this problem that you have....
Apr 21, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Get booted off
Ok. i have the exact same problem, but i use linksys. I have has geeksquad and they dont know. I have only one option i havent tried. try to just hook up the modem to your router only. Buy a wireless adapter for your home computer. If it doesnt work, return it for a refund. I feel for you guys because i have been going through hell and it drives me crazy that even geeksquad doesnt know. (By the way dont buy that garbage when the people say you need a new router, because they just want more money.)
Mar 22, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
NetGear RangeMax  NEXT WNR834B Wireless Router Logo
297 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
