Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
My friend has an 19" LG Flatron LCD Monitor.  Last nite his power went out (in the house).  Since then the monitor will not power back up, nothing, nada, zip.  He said something about an orange lt being on, then no lts at all.  Is there a reset procedure? Thanks
  • 661 Answers
Check the fuse in the power cable.. also check the power block that you are plugged into, hopefully it's just a fuse blown somewhere
Posted on Apr 24, 2009
My LG FLATRON W1934S was working fine last night. went to turn it on this morning and nothing happened. no orange or blue lights and it wasnt left in sleep mode either. what could be wrong with it?
I would suspect a problem in the monitor power supply, either a fuse or possible bad filter caps especially if you had to turn it on several times to get it on just before it failed.
If you are able to open it here is what bad caps look like:
Dec 17, 2012 | LG Electronics W1934S Flatron W1934S...
Automatically power saving mode ...........................cpu start working..........monitor power saving mode
Hook a spare monitor to the computer, if the same symptoms occur the problem is the Video Graphics Card in the computer, but if the picture is okay, it is clearly the LG Flatron that has the problem, and if possible sub the video cord from the computer to the monitor just to be sure.
Mar 10, 2012 | LG Flatron L1951S 19" LCD Flat Panel...
Hi, I turned my computer and monitor off as I normally do last night and when I came downstairs this morning to turn my computer and monitor on, my monitor didn't turn on. I pressed the power button on...
You need your monitor repaired or replaced.
Unlike a computer, there is not much troubleshooting beyond making sure it is plugged into a live outlet and turned on which you did already.
Jul 19, 2011 | LG L194WT 19" LCD Monitor
Turned my tv off last night and then when i tried
power supply has blown. you need to replace the bad capacitors on it. common problem
Jan 01, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Why does my LG flatron 1953T LCD monitor (19') goes white
Because the fuse on scaler PCB is blown. Open the monitor, open metal cover, disconnect all cables coming between display and boards, take the chassis off the display.
On back side of display you will see metal cover, mounted with tiny screws, take them off. Unscrew the board also and carefully tilt it up. Observe tiny chip fuse (referenced F1 or FU1 or something with "F") somewhere nearby the connector, ring it, replace it with solder drop.
Take everything back together.
Sep 11, 2009 | LG Flatron L1750S 17" LCD Monitor
LG FLATRON E700SH is not displaying RED color
there is ovbiously a fault with the monitor and w ould be best if you bought a new up to date monitor then if any faults consist with that one you could just take it back
Dec 06, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Analoge power saving mode
My friend left computer on,as it wouldn't turn off, after several minutes it came back on, and told her to check some sort of box on the other computer .
As she knows nothing about computers ,and its her friends she is leaving till they get home.
Nov 22, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Analog power save
same as above asking for a friend who does't know about commputers
my email is mssposs@bigpond.com
Nov 19, 2008 | LG Flatron L1951S-SN 19" LCD Flat Panel...
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
288 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
