Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Printer won't print in black
I think the printheads need to be changed, how to change printheads in all in one HP 7780 model.
  • HP Master
  • 419 Answers
If you need to change the printheads on this printer you need to do the following:
- Open the main lid (not the scanner one)
- Check the LED Screen on the printer and you will see that it gives you the instructions to hold down the "OK" button on the printer panel for 5 seconds if you want to change the printhead... So do this... Hold the OK button.
The printer will now move the printheads into the exchange position.. Wait a few seconds for the printhead carriage to stop moving around as sometimes it can catch your fingers..then:
- Lift the blue flap (lift from the front - hinge at the back)
You should now see the printheads
- Carefully lift the little blue plastic handle for the printhead and pull this up and out to lift the printhead out that you want to change
Now for your new printhead:
- Before you install it, shake it back and forth 6 times as shown to shake up and mix the ink that's pre-filled in the cartridge.
- Pull the orange covers and plugs off/out as shown
- Carefully slot the printhead into the position vacated by the old one. You may find that you need to slot it in by angling it slightly but be patient...
Once the new printhead is in position (check the other printhead to check they're the same level ie: that the new printhead is all the way in).
- Close the blue flap back into the closed position
- Close the main lid
The printer will then begin a priming routine and after a few minutes you can start to use your printer again..
Posted on Jan 27, 2009
HP photosmart B210 wont print black
Seems to be a common problem - I had it too. I spent a lot of time looking, but never quite found a consistent fix. I fixed mine in a few steps: First, I removed all the cartridges, and cleaned the filters on the top of the printhead (these are the little screens you see when you look at the tray with the cartridges removed). To do this I blotted each screen with premoistened alcohol wipes, changing wipes frequently, until the wipes were clean. I then removed the printhead by lifting the black handle on the right side, and lifting the printhead straight up. I used alcohol pads on the rear contacts (refer to HP's instructions for changing printheads) in a downward motion only. Finally, I cleaned
Nov 10, 2012 | HP Photosmart Plus B210A Multifunction...
HP 6940 won't print black-new cartridge installed-prints color but no black
In all likelihood your print head has become clogged at the black ink outlet. Be aware that printheads can BURN OUT if you keep trying to print and there's insufficient ink reaching the printhead. The ink flow is relied upon to prevent overheating of the tiny resistors at the printhead. Best bet is to remove the cartridges from the printhead and then remove the printhead and try to clean it in warm water. You will find many youtube videos on suggestions for cleaning the printheads on HP printers. Do a google search for your model. If all else fails you can order replacement printheads for the part that has failed. They are not cheap so price compare. Oftentimes they will cost nearly as much as a new printer!
May 16, 2012 | HP 6940 InkJet Printer
My hp 6500 won't print black. I've changed the cartridge twice. No result. Can the ink not be getting to the printer head?
Unplug the printer for at least overnight. I have 3 of these printers and all 3 have done this. All 3 came back after being unplugged for a long period.
Personally, I think a class action suit might be in order.
Nov 19, 2011 | HP Officejet 6500 Wireless All-in-One...
Alignment of HP L 7780 failed. What are the steps to correct?
hello, you will need to run a cleaning cycle, you are looking for black printing, if not printing well, it might fail, if it does you will need #88 printhead. the black/yellow one. most times you will not need calibration to print, unless machine is stuck in that mode and won't pass. and won;t allow for print.
Oct 25, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Printhead has a problem black/yellow
I am so frustrated. It is going through them like candy. The cartriges obviously have ink in them but the printer says there is some thing wrong with the cartriges. There is not HELP!! I can not afford this printer anylonger
Aug 03, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
HP Officejet Pro 7780 will not scan on Mac Powerbook G4
YOU WILL NEED DRIVERS FOR THAT DEVICE.
WWW.HP.COM/MAC
HP OFFICEJET PRO DRIVERS MAC 7780
OR
HP OFFICEJET PRO 7780 MAC DRIVERS
OR
HP OFFICEJET PRO 7780 DRIVERS
AND
CONTROL PANAL GO INTO NETWORKING AND SHARING FOLDER
PRINTING SHARING, OR PROPERTIES SETTING NEED TO BE CHANGED
DOES THE SYSTEM SUPPORT WIFI
MAKE SURE THAT THE ANTIVURAS PROGRAM AND FIREWALL IS HAS STOPPED YOU SCANNER TO COMMUNICATE WITH THE MACHINE, JUST SOME FINE TUNNING IN THE FIRE WALL MAYBE ALL IT IS.
ROD
Feb 09, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Streaks though the pages
Step one: Retry the print job The problem may occur only rarely. If you have not seen it in other printouts, try again. Step two: Increase the print quality mode If reprinting did not help, try increasing the print quality mode.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected, and then click Properties .
  3. Select the Paper/Quality tab.
  4. In the Print Quality area, choose the next higher quality setting. If the current setting is Draft, choose Normal. If the current setting is Normal, choose Best.
Step three: Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing. NOTE: This step does not apply to color printouts.
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Step four: Clean the printheads If the print quality is still bad, clean the printheads.
  1. Make sure the printer is loaded with unused white paper.
  2. Open HP Solution Center .
  3. Click Settings , Print Settings , and then select Printer Toolbox .
  4. Click the Service Tab .
  5. Click Clean Printhead , and then click Clean .
Step five: Align the printheads If the print quality is still bad, align the printheads.
  2. Open the printer Toolbox , and select the Printer Services tab.
  3. Click Align Printheads . The Align Printheads window opens. Click Align .
  4. The printer prints an alignment page. The lines in the patterns should appear to be straight. Click OK when the page finishes printing.
Step six: Calibrate the linefeed If the print quality is still bad, calibrate the linefeed:
  2. Open the printer Toolbox and select the Printer Services tab.
  3. Click Calibrate Advanced Linefeed . The Advanced Linefeed Calibration window opens. Click OK .
Step seven: Replace one or both printheads If the print quality is still bad after performing all the above steps, one or both of the printheads will have to be replaced. Print a PQ Diagnostic page to see which printhead should be replaced.
  2. Press the Setup button.
  3. Press 1 and * simultaneously.
  4. Look at the color blocks labeled Test Pattern 2. Some or all of them could show white horizontal streaks. If none of the blocks are streaked, the printheads are okay.
    • If the Black block has lines – replace the KY printhead.
    • If the Cyan block has lines – replace the MC printhead.
    • If the Magenta block has lines – replace the MC printhead.
    • If the Red block has lines – replace the KY printhead.
    • If the Green block has lines – replace the KY printhead.
Nov 25, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP officejet pro l7680 all in one
Most likely the print head has failed and the black is not printing which is causing the printer to have issues. Talk to HP as I guess printheads have warranty or simply change the yellow/black printhead. Or if all of these fail give the machine to HP to get you a new one as this is not right. I hope this helps.
Nov 18, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
358 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
