Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
Cannot get oven unlocked after self cleaning
HELP! I ran the self-cleaning cycle. Finally got the lock to unlock but then when I preheated the oven it relocked itself (even though the "lock" was not slid over). So in desperation I reran the self-cleaning cycle--but it will not open even when "unlocked." And I have 12 people coming for passover dinner tomorrow night.
  • 3 more comments
  • 5050 Dec 02, 2007
    I ran the self cleaning cycle, when it was done, it beeped 4 times and then said end. I tried to open but couldn't. It now has a E1 and F% code on it. What should i do? crazyforjesus95@yahoo.com is my email
  • Anonymous Dec 14, 2007
    After running the self cleaning cycle, the bottom oven door will not unlock?????????
  • joycela May 16, 2008
    oven is locked. how do I get it unlocked
  • misshelen233 Aug 07, 2008
    I locked the door and turned the self-cleaning on and after I shut it off the door will not open.
  • Anonymous Mar 21, 2014
    oven door is locked after cool down at end of self cleaning cycle
Turn the circuit breaker off for several seconds
this should reset the system
Posted on Nov 26, 2007
I perfromed a self cleaninig of my kenmore sp4ecial edition stove and now for some reson the stove will not heat up. The light turns on when positioned at timer and self cleaning, and broil. buft will not turn on on bake... Whatever the position, the stove will not heat. I tried a self cleaning again to see if tyhe elements were burnt but they work.
Posted on Mar 09, 2008
Why won't big oven door unlatch?
sounds like the lock motor has failed. Lots of clicking noises and not being able to lock/unlock is normally a good indicator. In some rare circumstances, main control board could be faulty. Look for me on 6ya if you need any more detailed help.
Nov 23, 2015 | Viking Kitchen Ranges
I cleaned the oven self clean, now the oven preheat feature won't turn on
I don't know what kind of range you have or if it is gas or electric. You may have to call a repairman.
May 25, 2015 | Kitchen Ranges
Ran the self cleaning cycle and now the preheat light will not turn off when it gets to the temperature I set it to. It just keeps preheating. Example: I set the oven for 375. It seemed like it had been...
Sounds like a circuit board issue. If in Warranty, contact the manufacturer and have the controller replaced. A routine cleaning has noting to do with the normal operation of the baking or broiling function. Cleaning is disengaged after the door is unlocked and ready for general aplications.
Feb 20, 2014 | Ovens
My oven is locked, Im not able to unlocked, I need help
If
you ran the self cleaning cycle, it will unlock when it cools down
Sep 04, 2013 | Ovens
Ran the self cleaning cycle - Now it keeps posting un lock dor. Lock bar easily moved to the unlocked position after cycle completed and oven was cooled. I have unplugged the oven waited 10 minutes and...
Your switch isnt right ,check the wiring on the switch or make sure the switch is closing or opening when its suppose to,you should hear a click each time it opens or closes. your problem is in the switch area no where else,the computer on the oven needs tosee that switch input and doesnt
Feb 15, 2011 | GE Profile 30" Self-Cleaning Slide-In...
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    After self-clean cycle, oven will not unlock
    Seems like you found out the hard way what I wrote about in this tip...
    Check it out it also contains some thing to try on how to unlock that oven..
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    heatman101
    Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option
    Apr 12, 2010 | GE JDS26 Electric Kitchen Range
    Lost instructions - I have my oven cleaning how
    Typical oven self clean cycle is 3 hours. Oven needs to cool down to under 550 degrees before door will unlock. Download a use and care manual at http://www.geappliances.com/service_and_support/literature/
    Nov 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    Jenn Air oven door won't open after clean cycle
    Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
    Nov 26, 2008 | Jenn-Air SVE47100 Slide-In Electric...
    GE Profile XL44 Spectra gas oven
    My Spectra XL44 suddenly refuses to ignite the baking portion of the oven - broiler and top work just fine. The day before it was working fine. Wondered if it was an electrical egnition problem - gas feed or what??? Help!! Mregressor@aol.com
    Nov 13, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
    Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
    1,180 people viewed this question
    Top Kenmore Kitchen Ranges Experts
    Sal De
    Marvin
    Marvin
    Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
