Hi I think your battery may be going bad or you need to purchase a wall charger to fully charge your battery. Charging your iPod on your computer works fine for a while, but as the battery gets older, it needs more charging and often it doesn't get enough from the computer. Try a wall charger first. Charge it all the way up until it stops charging. If it still shows a low battery you need to have a new battery. There are a lot of places that can do it. Hope that helps.
How old is the battery ipod batteries can only be recharged a certain ammount of times before they need replacing
If an iPod appears not to turn on, check the hold switch on the device. If this switch is activated while the device is off, it will not power on again until the hold switch is turned off.
If that is determined not to be the problem, the battery's charge should be checked. When the battery is no longer holding a charge, the device will not power on, but will show a battery icon on the screen for a few seconds. If you see this icon while trying to boot up the iPod, just connect it to the USB cable and allow the battery to charge, which can sometimes take up to 30 minutes before the iPod becomes operable again.
If no battery icon appears when trying to turn on the device, try resetting the iPod. Once reset, the device should turn on, but if it does not, the battery may need to be drained first (by leaving the iPod disconnected from power for up to 24 hours), and the reset procedure tried again. hope this helps
This may not be the answer you are looking for but your I pod might not be fully charged, meaning that you are not plugging it in the computer/docking system long enough.( it takes much longer than 15 minutes to charge the battery. So you might want to plug it in/dock it over night) Or you may be playing a game that uses a lot of MB/GB so it kills the battery. And make sure that you press the play/pause button down for at least five seconds before switching the little switch at the top of your I pod. If you don't press the play/pause button for five seconds and just switch the switch at the top a little lock will appear on the left corner meaning you need to hold the play/pause button down for five seconds then the i pod screen goes black at that time flick the switch at the top off.
-hope it helps
owner of i pod nano and I pod touch.
Apple does this so that only Certified accessories have to software to make the hardware circuits charge an i pod, thats especially a problem with some sound docks, my i pod 2 gen works with only 1 of the 3 sound docks that i have tried, but i have a bluetooth i home so i play my music wirelessly
Since it has been sitting for so long, try doing this: Connect the ipod to your computer and let it sit for about fifteen minutes. Then it should show up in your computer and under itunes. Usually, if your ipod dies completely, when you try to charge it using a wall or car charger, it will do that, just flashing the apple logo and going back off. Leaving it plugged up to the computer will allow the battery to charge just enough so that it can sync with itunes. While it is plugged into the computer and charging, it should say something like, battery very low, charging. It should work after letting it sit plugged up to the computer.
maybe when u insert the usb in the pc u just get it with out ejecting the usb because if not it has virus maybe ur pc is not protected i encouter that problem it did not on and play...
try the apple reset procedure by pressing and holding both the center and menu buttons for at least 5 seconds. If this does not work, it may be best to call apple.
