Question about Maytag MER5770 Electric Kitchen Range
Maytag MER5770AAW smoothtop range
I just bought this range off somebody, they didn't have an owner's manual and an F1 message comes up on the display from time to time. I usually press the cancel key and it will stop. Sometimes I have to press it more than once, but it stops. Sometimes, it even starts going off in the middle of the night. I don't cook anything overnight, so this is when it's not in use. I also have no idea what some of the controls do, and can't seem to obtain an owner's manual online. There is little information I have been able to find on this range, I would assume because of the age of the range. Any help with the F1 thing would be appriciated, and any other information on this range would be great.
  • 1 more comment
  • JUDSY Jun 03, 2008
    f1 appears
    pushed cancel, reset clock and turned the breaker ogg.
  • d2earley Mar 25, 2009
    Maytag MER5700AAW owners manual lost. I need to know how to remove range top to replace coils.
  • caccole Apr 28, 2009
    Maytag electric range MER5770AAW. Need to replace oven door handle. Need a manual to get inside the door to access the handle screws. I can find the part for $42. Can anyone help with door specs?
Seems Maytags have never fixed this problem. I have a 1993 and have had to replace the membrane (touchpad) every 4 yrs. If you can do it yourself, actually easy, you will save $$ for repairman, and can order part from Repair Clinic.com.
Only trick is carefully opening up the stove top, having someone hold it up for you while you disconnect the membrane...
Posted on Nov 13, 2007
Hey, whom ever posted that, THANK YOU! I looked everywhere for the owners manual! I am SO grateful! Thank you, Thank you, Thank you!
Posted on Jul 01, 2007
Http://www.maytag.com/assets/pdfs/literature/MER5570AAA.pdf is the owner's manual. The F1 thing seems to be a common problem with this model involving the electronics - one or both circuit boards in the control pannel. Most common solution: repair call and $$, although the Maytag repair people suggest resetting the oven by unplugging for about and hour and re-plugging the oven.
Posted on Apr 29, 2007
Only one burner doesn't work on my maytag gemini stove
MET8776BS Maytag Gemini Smoothtop Double Oven Range
reviews.us-appliance.com/.../MET8776BS-Maytag-Gemini-Smoothtop-D...
Rating: 4.5 - ‎94 reviews MET8776BS Maytag Gemini Smoothtop Double Oven Range - Stainless Steel - Reviews ... Really like the features, however one burner doesn't work, after a month.... 2 ovens sure beats the storage bin underneath! the only negative I can think of is ...I bought my double oven a few months ago and am very happy with it.
Oct 16, 2015 | Maytag Kitchen Ranges
We have a maytag electric range/oven model #MER5770AAW .after baking some french fries ,with the oven open it made a beep and F9 message came up on the panel.everything still functions ,have hit the...
F9 Door Lock Warning Check door lock circuit or Replace Clock. If clock working don't do that.
ck here for the code.
https://www.repairclinic.com/RepairHelp/FaultCodes/31/Range-Stove-Oven
parts here....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-4-93082-/new/Maytag-Oven-not-self-cleaning-MER5770AAW
you can call their 800# or use the chat for more info if needed.
first check that the latch is not a 1/4 or so closed.
open and close the latch a few times.
also you can turn off the breaker for a few minutes
and see if it resets the ecm.
Hope this helps a little
Jan 16, 2018 | Maytag MEW5530D Electric Single Oven
F-1 message
F1= Defective Touch Pad or Membrane Replace Touch Pad or Membrane
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 28, 2010 | Amana AES3760BAW / AES3760BAQ / AES3760BAB...
Oven will not shut off
Sounds like a stuck relay in the control board. The only way to repair this problem is going to be by replacing the control board. If you have anymore questions please ask. I'll be more than happy to help you further.
Thanks
Jan 10, 2009 | Maytag MER6769 Gemini Electric Kitchen...
Frigidaire Electric Smoothtop Range......getting F 1 error on digital display
F0 & F1 EOC (Electronic Oven Control) failure Replace EOC (Electronic Oven Control)
Jul 15, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Maytag MER5770AAW Oven
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 08, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag electric range shows F1 error message and beeps what does this mean? and now it permanently shows this message and not thee closk
Apr 03, 2008 | Maytag MER5770 Electric Kitchen Range
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
No heat Maytag smoothtop range MERH752BAB
It would have to be under warranty if this happened after only 1 week. I would contact the manufacturer.
Sep 08, 2007 | Kitchen Ranges
Maytag MER5770 Electric Kitchen Range Logo
1,517 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
