Question about Gateway GT5220 PC Desktop
Gt5520 video card
I bought new pci Randeon video card and installed it. Went to device manager and shut down old one but still not work. Need a step by step guide on how to shut down old video card in bios. Cannot find it to shut it down. The computer can autodetect new one but need to shut old one down 1st.
  • 45 Answers
Is this a PCI-E card? I will work on the assumption that it is. Unless you are running two video cards in SLI remove the old card, they make great paper weights. Be sure to only add/remove hardware while the machine is turned off.
Posted on Dec 20, 2008
My graphics card does not show up on my Device Manager
I had just run into the same problem while installing my new graphics card earlier today. This is what I did to fix it:
1. Uninstall the new driver for the new card, if you can, in control panel if it installed.
2. Reinstall the new driver.
3. Go to Device Manager and UNINSTALL, not disable, UNINSTALL the on-board card. Don't worry this won't kill anything. It will ask you to restart your computer. Click yes.
4. While the computer is restarting and on the shut down screen for windows unplug the monitor cord from the onboard card and plug it into the new card.
5. Wait for windows to boot up and load the new drivers. It should be working with the correct drivers.
If it takes more than 8 minutes for anything to come on the screen(icons, login screen, etc.) reboot your computer again.
Apr 08, 2013 | PowerColor Go Green AX5450 512MK3-SH...
Re: Reinstalling Windows XP - Finding new drivers
Pick latest and up to date drivers for PCI Modem, Video Controler etc at that HP web page and installed them.
Oct 27, 2008 | Compaq Presario 2100 and 2500 ,NX 9000...
New video card old motherboard
The new video-card should have come with a CD-ROM, containing the necessary device-driver software to support the device.
Or, from the manufacturer's web-site:
http://game.amd.com/us-en/drivers_catalyst.aspx?p=xp/radeonx-xp
download the device-driver for Windows XP Home/Professional, and install it.
Apr 10, 2010 | ATI RADEON HD 4870, PCI Express Video...
Onboard video works fine but when I install a pci express card the video is garbled. The card checks out good on a different machine.
you need to unstill the intergrated vga port via the BIOS or disable the device via the device manager, install the new driver first the install the pci card
Feb 03, 2010 | E-Machines T6216 (827103077834) PC Desktop
I need to disable the onboard video card on the emachine t1090 but I don't have any video output
Enter the bios under onboard devices you see the the video adapter disable it there save and exit
Oct 07, 2009 | E-Machines T1090 PC Desktop
Computer freezes up after install of drivers for new video card..
You do need to disable the onboard in bios in order to run a video card. In bios you should see an option for onboard devices or integrated devices. This is where you would disable the onboard video. You will also need to change your graphics options in bios to the PCI-E being the primary. Once you make these changes in bios, save and exit. Your computer will reboot itself applying the changes. Once you are back in your operating system you can then insert the cd that came with your card & run the installation. Once this has completed reboot and you should be all set. Hope these tips help.
Sep 20, 2009 | Computers & Internet
Video Card not recognized on PCV-RS410
Go into video settings (control panel- display- settings) Here there should be a drop down box in it you should see you onboard and new video card switch to the new one.
Dec 10, 2008 | Sony VAIO Digital Studio PCV-RS410 PC...
IBM Netvista PCI/PNP Slot 3 Error
I had to remove the old network card and replace it with a new one to resolve the issue.
Jun 18, 2008 | IBM NetVista A40 PC Desktop
Monitor Shutdown problem
I believe the problem is from the herzian synch windows wants to achieve, either too low or too high.
You ought to try with a different monitor, either to set the synch or to make a analasys if it's another problem we're facing, like graphics card or motherboard itself.
Nov 15, 2007 | ASUS A9550GE/TD Radeon 9550 Graphic Card
PCI adapter did not install
I don't know how you could have installed the drivers BEFORE you installed the hardware... Shut down and UNPLUG the system; REMOVE the new PCI card, then hook up the power and boot the system back to the Desktop. Check the Device Manager to be sure you're not showing any problems; if everything seems back to normal, shut down and unplug the system a second time, then install the PCI card again, restore power, and prepare to reboot the system. Be SURE that ALL of the PCI cards are fully seated in the slots, and that the main power cable (from the PSU) is fully seated in the connector; IOW, check the system just to be sure that nothing has come loose while you've been working inside the case. Next, boot the system again; Windows SHOULD detect the new PCI card during bootup, though it might NOT request drivers, if they are already embedded within XP itself... Once you get back to the Desktop, open the Device Manager and check to be sure that the new card has been detected and properly installed. If you see any question marks, error messages, or exclamation marks, take detailed notes, and post that information here, so we can help you troubleshoot the problem... Good luck; I can only give you general advice about this, because you didn't provide any specific details about your new hardware, but with a little luck, you'll get everything working without any more heartburn...
Mar 31, 2007 | D-Link DU-520 - 5-Port USB 2.0 PCI Adapter...
Gateway GT5220 PC Desktop Logo
170 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
