Question about Dell 924 All-in-One InkJet Printer
Perforation when I print
When I print any document, regardless of size, on every page it makes a perforation down the entire page. I'm not sure how to make it stop doing this. It might be nice if I wanted to tear off half of the paper, but I would appreciate any help that you could offer. Thanks.
My dell 924 all in one is doing that very thing and I cannot figure it out either. I called it scoring, but perforating is a better explanation for it. If you ever find a solution or clue, please advise at paynehouse@cox.net, subject dell 924 perforation. Thanks so much...and gl
Posted on Apr 05, 2007
Letters are too small
  • Open the document and make necessary changes:-
    Click on the "File" menu and choose "Print Preview" from the menu. You will see a picture showing you how your finished document will look on the printed page.
  • Make the font larger if you wish. To change the font for the entire document hold the "Ctrl" key down and press the "A" key. Then click on the "Format" menu to adjust the font size.
  • Click the "File" menu and choose "Print Preview" again to see how the finished document will look. Continue to adjust the font until the document looks just the way you want.
  • Feb 20, 2011 | Epson Office Equipment & Supplies
    My Xerox CopyCentre C20 doesn't always print the entire page, as if it is only scanning part of the page. It happens when the original is placed on the glass surface as well as when the original is sent...
    the paper size detector may not detect the original size of the document check the paper tray indicator light on the panel and make sure the direction is the same with the original document onthe glass
    Aug 26, 2010 | Xerox CopyCentre C20 Black and White...
    How do I change print sixe on Deskjet 722c?
    usually you can change the print size in the print preview page setup menu.
    in this menu you can scale your document down changing the print size.
    otherwise, you can take your file in word or any document editing software and select all and change the font size for your entire document. These are two options for you which will change the print size on your printer.
    Mar 26, 2010 | HP Office Equipment & Supplies
    When trying to take print in erp alwayas skip one page of 3 page print
    for this you have to change some settings of your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size to you using paper size and enable the tear off option and( if first settings are not working enable skip over perforation option ........ hope it solve your problem ..................
    Dec 19, 2009 | Epson LQ 1070+ Matrix Printer
    How to print with the legal paper?
    follw the given step and check-
    1-Before printing your document, be sure the page size is set to legal paper. Go to "File> Page Setup" and then click on the "Paper Size" tab. Select "Legal" from the drop-down menu.
    2-Go to the printer and take out the paper tray. Remove the letter size paper.
    3-Insert about one half of the package of legal size paper into the tray, depending on the depth of your tray. Larger printers can accept an entire package, while smaller ones cannot.
    4-Make sure that the paper goes underneath the metal clips located at both the front and back of the tray.
    5-For printers that don't have a tray, you'll have to manually feed the legal size paper. Locate the paper feed either on the front or rear of the printer.
    6-Put a few sheets of legal size paper into the paper feed. The paper should be placed as close to the rubber spindles as possible. These spindles will draw the paper into the machine and feed it through the printer.
    7-Print a test page.
    Thanks,
    Dec 03, 2009 | Brother HL-2040 Laser Printer
    After every page I print, the green light goes out, and I have to press online to get it to continue printing.
    Thats ..paper size mismatch, check the paper size settings of your printer in printer properties is the same as what document or document program is set to under page size of the document you wish to print, if these dont match the printer goes offline so you can put in what it's been told is the right size paper or press online to force it to print regardless...so in your case check paper size in both locations and you should be right, there are other things but 99% of the time..thats ya baby;)
    Cheers
    Nov 15, 2009 | OKI B4600 Printer
    I have a Cannon i560 printer. The printer will
    Check to make sure you're not adjusting it to fit the page. This can shrink the entire doc..
    Look in the print dialog window when you select print from the file menu.
    There should be options to select or deselect before clicking to print.
    You may also check your page setup to make sure you are printing at 100%.
    Let me know if you solve this one...
    Oct 30, 2009 | Office Equipment & Supplies
    Printer will not print a wordperfect document.
    Try a test page when you set up your printer. If that works,
    Try going to File, page setup and choosing a paper size and type there that matches the new printer. Make sure your printer is the default one or that you pick it in the drop down menu on the print menu after you choose print. .
    Make sure your paper matches the document's paper
    Apr 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
    Can't print GE27909EE1 manual in more than one page, which is unr
    Hello - Go to www.home-electronics.net. Click on lnk for manual for GE27909EE1. Hit Control A, Control C ( or hilite the entire page, right click and copy). Open a new Word document. Paste the manual instruction page to the document. Hold down Ctrl and A to hilite the entire page. Using your down arrow, increase the font size to 10, 12, or whatever size font you want. Print.
    Dec 31, 2008 | Lands Phones
    How to change paper size on axerox phaser 8500
    From a Windows Operating System:
    1. From the computer, open the document to be printed within an application program.
    2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
    3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
    4. Click on the [Paper / Quality] tab.
      NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
    5. Select the required paper size from the Document Size pull down menu, if available.
    6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
    7. To create a new custom paper size setting click on the [New] button.
    8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
    9. In the Width field enter the width of the custom paper size.
      NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
    10. In the Height field enter the height of the custom paper size.
      NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
    11. Click on [Save]
    12. Click on [Close].
    13. Select the required paper size from the Document Size pull down menu.
    14. Click on [OK] twice to print
    From a Mac OSx:
    1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
    2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
    3. Select the custom paper size for your document from the Paper Size pull-down menu.
    4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
    5. To create a new custom paper size setting click on the [+] button.
    6. Double click on [Untitled] and enter the name to be given to the custom paper size.
    7. At the Page Size field enter the width and height of the custom paper size.
    8. Click on [OK] twice.
    Apr 22, 2008 | Office Equipment & Supplies
    Dell 924 All-in-One InkJet Printer Logo
    113 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    David Patricia James
    Marvin
    Marvin
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
