Question about Frigidaire PLMB209DC Microwave Oven
I have frigidaire model plmb209dca microwave (about 4 years old)
The buttons on the key pad sometimes work or do not (start, clear 1-minute buttons), if we hold our finger on them for a couple of seconds they finally work. any suggestions?
  • Frigidaire Master
  • 9,098 Answers
You have a failing membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
Posted on Dec 21, 2008
How do i defrost by weight. I can't bi pass the express key function
mine if I enter 1 it's .1 enter 1 0 tis 1.0 lb
16 would be 1.6 lbs. not 16oz.
8 oz= 1/2 lb or 5
a model # and make would help a bunch!
hope this isn't as clear as mud?!
Feb 01, 2018 | In Microwave Ovens
Change time on frigidaire microwave no clock button
Hi ssullivan013 - Here are some generics instructions that I found for the model number posted above. Hope the information is helpful.
Suppose you want to enter the correct time of day 12:30 (A.M or P.M.).
1. Touch Clock pad.
2. Enter time 1,2,3,0 and press CLOCK pad again
This is a 12 hour clock. If you attempt to enter an incorrect clock timer, ERROR will appear in the display. Touch the CLEAR/OFF pad and re-enter the time.
Mar 18, 2013 | Frigidaire PLMV169DC Microwave Oven
Hotpoint microwave key pad parcially not working
The pads actually share some of the same lines inside the touch pad. There are silver oxide traces inside there. If a trace inside breaks, it depends on which trace breaks as to what pads dont work. If a trace that is common to say pads 1,3,5,7 you would lose function of those pads. 1.....2.....3.....4......5....... it is sort of set up like that inside wher eone connects to another and so on. So lets say a line between 2 and 3 breaks then you would lose pads 3, 4, 5 and any others on that same line. Will have to replace touch pad, cannot repair.
Oct 15, 2017 | Hotpoint JE740WY/GY Microwave Oven
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I've had mine for approx. 5 years and this year the buttons started to not work. I could only use the One Minute Plus button. This morning nothing worked! I unplugged it, replugged it and still nothing....
    On these models, each of the four plastic buttons on the right side of the control panel runs a hidden pad on the membrane keypad.
    The other pads on the keypad are fully exposed once you open the door and you just press them directly to operate them.
    These plastic button assemblies have been upgraded due to weakness and breakage.
    Most often it's the bottom two buttons (Stop/Clear and Start/Minute Plus) that fail.
    You can order the button assemblies here.
    The service manuals you need to refer to are here and here.
    Oct 01, 2010 | Sharp R-1502 Microwave Oven
    Our GE countertop microwave key pad does not work. The start and clear button does not work. owners mamual jes1651 . unit is 2 years old.
    HI. Kindly, unplug the unit for five minutes. this will drain all power, and reset the main board. Once the five minutes have passed, simply plug the unit back into the power outlet. If the error continues, the touch pad should be replaced asap.
    Oct 19, 2009 | GE Microwave Ovens
    Will not start when pushing start button
    Check the door switch is properly working. If it is ok the defect may be with the key pad.
    May 23, 2009 | Frigidaire Mid-Size Microwave
    Unlocking child lock on the sharp microwave model R316FSC
    The Sharp Microwave/Convection oven I have says to touch the Custom Help button, the number "1", then touch the Start Button. To turn off the child lock, press the Stop button.
    Or just unplug it, wait 1 minute, and plug in.
    Jan 06, 2009 | Sharp R-308J Microwave Oven
    Microwave key pad stopped working
    Okay, thank you for that.
    You have a failed membrane keypad, but on this model, it is not available separately.
    You would need to order the control panel assembly, part # WB56X10817, which you can get here for far less than GE charges.
    It costs more than just a membrane would, but is much simpler to replace.
    Then you remove your circuit board from the old frame and install it in the new frame.
    Jan 01, 2009 | Microwave Ovens
    Sharp model number: R-320HQ (1200 watts)
    the electronic circuit are corroded timer does not function / the IC program was lost of memory such as function / if you have some old look a like Sharp Model you may transfer control panel.
    Jan 05, 2008 | Sharp R-510HW Microwave Oven
    Frigidaire PLMB209DC Microwave Oven Logo
    233 people viewed this question
    Top Frigidaire Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
