Question about AMD A7S333 (SiS 745) (MBSA7S333) Motherboard
Pls help how to install reset led, powerled, hdd led in SiS-74
Please help how to install reset led, powerled, hdd led in SiS-745 Motherboard.
  • suwandi888 Dec 20, 2008
    I dont what model of motherboard, what i know from bios it is using Sis 745 chipset, processor AMD Athlon. I am looking user manual to show the location of each switch and jumper. Please help.
  • nickpower
    nickpower May 11, 2010
    sis 745 is the chip set model on your motherboard. try looking for some other numbers on your motherboard so i can help you further.
My power supply come on to my soyo sy-p4vga but it dosent post the hard drive or the motherboard what can i do
Posted on Feb 13, 2009
  • 45 Answers
Find the model name and google it, you should find a manual to help.
Posted on Dec 21, 2008
Mk40vn no beep no powerled some hdd led some cd led after reset cmos jumper in right position no other jumpers are set on board i have no manual for jumper settings please help me susanne
in some motherboard when you change the c mos jumper the motherboard doesn't switch on change the pin to 1 and 2 normally which is c mos normal and 2 and 3 is to clear c mos you will see marking of all the jumpers in the motherboard set the pin correct to normal and also remove the power connector from the motherboard and short the green and the black wire and see whether the smps works if not working change them
Oct 01, 2011 | Shuttle MK40VN Motherboard
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
Aug 10, 2009 | MSI 745 Ultra (MS-6561-010) Motherboard
Conectoes Led
You will get a much faster answer if you ask in English, the same language this website is written in.
Aug 05, 2009 | AOpen AX45-V (91.88I10.004) Motherboard
I'd like to know the sequence to connect the following connectors:power sw, reset sw, power led, hdd led from the front panel to the motherboard (motherboard foxconn sis 651 m03. Thanks West
If your board is the one in this manual, the pins are located very close to the CMOS battery. Page 21 in that manual shows the diagram. Power LED is the top two left pins. Hard disc LED is the bottom two left pins. Power switch is the top two right pins. Reset switch is pins 3-4 on the bottom row. Pin 5 on the bottom is not used.
Apr 27, 2009 | Foxconn Computers & Internet
Problem with panel one
The manual is here http://www.pcchips.com.tw/PCCWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1182&areaid=3&LanID=0 it should have a picture telling you where to plug them in.
Aug 25, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
My computer runs for 2 seconds then shuts down.
First off all download the manual
> Make sure that motherboard is placed correctly
> Front panel connection plugs are there on the manual (4plugs POWERLED,HDD LED,reset switch,power switch) LED plug has positive negative...be careful
May 14, 2008 | Computers & Internet
Help me on how to connect my samsung motherboard!
Power>Red & white
Reset>Purple & white
HDD Led>Green+
HDD Led>White-
HDD Tx>Yellow & white
Select each pin & correspond with block on FSB M/B panel
Jan 17, 2008 | Computers & Internet
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
Panel 1 settings
Hello ocea, Here is a link to the manual: ftp://ftp.biostar-usa.com/manuals/M7VKF/M7VKFmanual.pdf Here is a picture of the front panel settings:
Oct 14, 2006 | Biostar M7VKF Motherboard
AMD A7S333 (SiS 745) (MBSA7S333) Motherboard Logo
473 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Computer Links
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
