Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
My Black and Decker Pivot Plus cordless drill won't charge. Had one previously and thought the battery was bad, but after I bought a new one I think I found out it was the charger instead(could not get a replacement battery) Seems I may have the same problem again Thoughts?
  • 1 more comment
  • joesf70 Mar 28, 2009
    I have only used this on a couple of small projects. I had to borrow a friend's drill to finish the second one because my drill petered out. I've tried charging it but I only hear a hum when I press the power button and the device doesn't move/rotate.
    Does this mean I need a new battery - only after using the device a couple times?
    Thanks,
  • jhk0063 May 19, 2009
    I have the same problem. The AC adapter does not get warm which means it's the adapter or the connection to the battery or the battery itself that's the problem.
    I'm thinking of getting another adapter to see if it charges.
  • David Ford
    David Ford May 11, 2010
    How old is the tool? Batterys have so many recharging cycles before they go dormant. If you take the batterys and charger to a DeWalt Service Center usually they wont charge to test both of these for you. Let me know If I can help
This one dosn't charge. It takes batterys. how do i change them
Posted on Mar 19, 2011
How do remove the battery from my black and decker pivot plus drill
It's in the **** end. You must unscrew all the black screws in the lower handle. Remove the black heel. Then unplug the Red wire. Carefully pull out the battery pack. Then unplug the black wire
You can order a new battery from HERE
Jun 22, 2011 | Black & Decker Pivot Plus Cordless...
CANT GET DRILL BIT OUT OF BLACK DECKER BATTERY CHARGE DRILL HELP
dear sir
please use drill bit remove key with drill machine and try to turn it anti clock vise then your bit will being loose and you can remove it easily .
thank you
hope answer the question
please vote !
Oct 04, 2010 | Black & Decker Pivot Plus Cordless...
I KEEP MY PIVOT ON CHARGE BUT IT DOES NOT WORK
if you know how to use a volt ohm meter you can check your charger, battery and switch.
Aug 29, 2010 | Black & Decker Pivot Plus Cordless...
Power is low. How to charge it?
The pivot has to be in the straight position and the charger plugs in the joint (it's hidden in the bent position)
Mar 19, 2009 | Black & Decker Pivot Plus Cordless...
Where to insert AC adaptor to charge Black & Decker Pivot Plus El
The female plug is directly in the center of the underside of the handle...Inserted the AC Charger/
That was it.
Nov 13, 2008 | Drills
Black & Decker Pivot Plus Cordless Drill/Screwdriver AC Adaptor
extend the handle straight and all will be reavealed! Just in front of the triger inside the piviot point.
Mike
Nov 13, 2008 | Black & Decker Pivot Plus Cordless...
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
615 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
