Question about Garmin Nuvi 660 GPS Receiver
No sound from Garmin nuvi 760 by any method
No sounds/voice can be heard on Garmin nuvi 760 either through internal speaker or via fm transmitter
  • 5 more comments
  • Anonymous Dec 22, 2008
    I purchased Garmin Nuvi 760 in January-08 and I loose audio in November-08. The only way to communicate is through FM transmiter, however in big cities like chicago, it is very difficult to set FM frequency.
    Does anyone have solution.
    Thanks
    Bhadresh
    Same problem with my Nuvi 680 -- lasted approx 1 year with no audio problems....now it is out immediately after warranty expiration!
  • sjhatfield Dec 23, 2008
    The mute under tools/settings/volume hasn't accidentially been checked?
  • Anonymous Jan 24, 2009
    The sound works with mps but will not work on the direction
  • madjoh79 Feb 01, 2009
    There is a swedish voice installed at my unit but I cant hear any sound from my garmin, neither sound from voice or sound from my mp3s.
  • jasontricci Feb 23, 2009
    Never even hooked up my Nuvi760, yet when I turned it on one day to experiment with it, the damn speakers didn't work.
  • brian_copela May 01, 2009
    I also received a Garmin 760 today. No SOund of any kind.
  • 4 Answers
Sounds like your speaker went south. Since your fm transmitter is working I'll be your earphone jack is too. So you could always use an earphone. Only other option is a speaker replacement.
Posted on Jan 07, 2009
My nuvi 275 doesn't have sound
ok a few things to figure out here, Sound..you cant hear any street names, or music
If its street names you must chose a language that has an ending ( TTS ) text to speech
do that by going to Tools.... Settings... Language... under Voice pick one with an ending ( TTS )
next we will try any other sound... is it muted? on main screen press Volume Icon
doe sit have a checkmark in MUTE? if so remove it
If not then on that screen there is FM Trans on bottom of screen .... press it
Enable FM Transmitter if it has a checkmark remove it...... place a checkmark there if you want to hear your unit thru your car speakers
Nov 05, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
My garmin nuvi 765T has no volume coming out from internal speaker but it comes from handfree, how to solve this problem? plzz help me
Power unit on
Press Volume Icon..... If there is a check mark on mute remove it
if not
Press FM Trans
uncheck Enable FM Transmitter
Love my Nuvi760
Oct 21, 2010 | Garmin Nuvi 760 Car GPS Receiver
I lost all voice prompts on my Garmin Nuvi 760. If I use the FM band, it works, and the volume works for keystrokes. Is there a fix for this?
you will just need to de activate the FM transmitter to do that press the volume button at the bottom right hand corner of the main menu and uncheck the box that says something about the FM transmitter
Jul 09, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
The voice is just not working, all else is fine, no, the mute is not on...??
Do you have the unit set to internal speaker or FM Transmitter? Go to the Volume section from the menu, FM Trans, disable FM Transmitter.
Feb 13, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Everything works fine on the unit no problem until
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
if this side of it works then the FM transmitter is faulty
Check that the sound has not been MUTED
plug the earphone into the socket to see if any sound is heard. The socket is also a switch that takes sound from internal speaker to ephone and reverse.
If no sound is hear in either FM or normal mode your unit is faulty and needs repair
Jul 24, 2009 | Garmin nuvi 250W GPS Receiver
My Nuvi 750 has stopped talking, still shows the map but no voice
That has happened to me several times. When it happens I go to Tools > Settings > Language. In my case, the Voice field is empty, so I click on the Voice field and then select American English-Jill (TTS) and it's okay afterwards.
May 05, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
There is no sound on my nuvi 760
I had the same problem! When I went under Settings/Language/ there was no voice that the machine could find! It is. I think a firmware bug or something like that.   You have to reset the 760 by holding the on-off switch on the left position for more than 8 seconds. After that you will have to choose the Language of your choice again. Let us see what will the next software upgrade brings us as a better solution.
Dec 21, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Dec 14, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 760
Go to tools-settings-language-voice and make sure it is set to "American English-Jack (TTS) or to American English-Jill (TTS)
Aug 10, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
1,646 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
