Question about GE Spectra JGBP30 Gas Kitchen Range
Oven produces soot when running, broiler ok, stove top ok
I installed a new ge gas stove model JGBP25DEM4WW. $$ is tight, so I put it in. I am on Lp gas. Replaced top range orfices and adjusted broiler + oven orfices per booklet. Broiler flame is good but strong. Oven flame is 90% yellow and throws alot of soot.
  • Anonymous Mar 29, 2014
    oven is very sooty and gas smell
    can the oven control valve cause soot
    Problem Solver:
  • 6 Answers
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Posted on Dec 20, 2008
Our new home has a GE XL44 gas stove the top works fine but when I use the oven it smokes and sets off the smoke alarms.The stove is over 3 years old Any ideas before I have to call the repairman in?
A gas stove shouldn't smoke. Is is clean? There is some grease that has eluded your cleaning efforts of interior surface?
Here are some tips that may help you resolve this problem:
Check the broiler flame. If the broiler flame is not adjusted properly, you could be creating soot from the burner flame.
Position the items that your are broiling lower so that they do not splatter grease up onto the broiler baffle.
Use a broiler pan that will drain grease and drippings down below the top surface.
Broiling many items will naturally produce some smoke. If you have the oven door closed when broiling then the only place that the smoke can go is up and out of the oven vent. If you partially open the oven door, some of the smoke will come out of the door opening.
You may have residue on the top walls of the inner oven cavity. Do you have self-clean feature on your range to clean the oven? Follow all of the procedures in your owner's manual to properly clean the oven using the self-clean cycle. This may clear out any undetected residue that could be causing excessive smoke during broiling.
Aug 26, 2015 | GE Kitchen Ranges
Ge 317b6641p001
Does the broiler still work? If not, the broiler element has burnt thru and needs to be replaced. Here is the part to order.
Oct 21, 2013 | Kitchen Ranges
GE Gas oven not coming on (ignitor not glowing at all) ge jgsp28sek4ss Broiler works, stove top works, oven igniter not coming on Thanks Jim
The ignitor just needs replaced . you can find the parts using your stove model # . its two screws and a wire to replace .
Feb 05, 2011 | GE Kitchen Ranges
I have a K/A kgst307 gas stove that was bought new as a natural gas unit. After 3 years, I moved to a house that had propane. NO PROBLEM because an LP conversions kit came with the stove. Used the stove on...
Although the natural gas orifices for the stove top burners were replaceable with propane orifices, many ovens/broilers orifices are simply adjustable using a 1/2" open end wrench to convert from one gas to another. Some brands are adjustable and some have to be changed out. It depends on the make and model. Do you have your owner's manual? It contains detailed info on converting your unit. I included a link below to choose from the list to download your manual. You'll need your exact model # listed on your stove. Pull out the bottom drawer and look at the data plate for the model # and then find it on the list for the correct manual. Douglas
Oct 01, 2010 | KitchenAid KGST307 Gas Kitchen Range
GE gas top and digital oven has broiler drawer near top with electric broiler inside. We are looking at this free-standing (stainless steel) stove here in Mexico and the manuals, and the website are in...
Yes appliances in the U.S. have different model numbers to their foreign counterparts.
The above, from GE's website, is the only thing I found as a gas stove with a baking tray. Are you sure it's a broiler drawer and not a warming drawer? Some stoves have a drawer to keep your food warm.
Aug 03, 2010 | Kitchen Ranges
Can't get stove to light
you must get some flame and put were the gas is
Sep 11, 2009 | GE Spectra JGBP30 Gas Kitchen Range
How do you convert the oven to lp gas on ge xl44 range
if this is a new stove need to change the pin in the regulator ,
then need to replace the stove top orifices from gas to l.p.
check under the stove for pieces they tape them under there by the regulator -- that how i found mine under my new jenn air
check the stove companies web site for a users manual also
Feb 19, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
I don't seem to be getting gas to the oven and broiler.
top of stove work but the oven dont work the igniter come on and glows but no gas
Jan 24, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Magic Chef LP range produces soot whenever oven is on.
The vent (shutter) allowing air to mix with the gas has shut. Access the burner with the oven off, of course, and look for the shutter (a sliding 'door'). It usually has one screw holding it n place and an elongated slot to permit adjustment. It may also turn. Since your burner is producing soot, you need to open the shutter more. Loosen the screw and slide the shutter open more. Turn the oven on and look for a nice blue flame, and one that doesn't run too far over the burner. Keeping in mind that everything there will be hot when the burner is on, and also for a long time after it is off, you can use a long-bladed screwdriver to push the shutter back and forth to get the flame you are looking for. If the screw is loose, a gentle tap will be enough. When you are see that optimum blue flame and you are satisfied, let the oven cool off for an hour or so, and final tighten the screw--making sure you haven't moved the shutter much when tightening. If this doesn't work you have a bigger problem and need to call a service person. Your local gas company sometimes will direct you to a person.
Dec 08, 2008 | Kitchen Ranges
GE Profile Spectra Kitchen Range
Are you using natural gas or propane (LP)? It sounds like you may need to change the orifice size on the gas lines going to each burner. If you are using LP and have the orifice set for Natural gas, the flames will burn higher and hotter, causing heavy soot. Under each burner, there should be a small nut with a hole in the center at the end of the gas line. The hole for Natural gas has a slightly larger diameter than one for LP. Your stove should have come with extra orifices as part of a conversion kit. Could this be the case? There's also another orifice in the main gas regulator in the back of the stove. Have you checked to see if the orifice for the regulator is set correctly? Does the oven burn hotter than usual with heavy soot, too? If you could please answer these questions first, I can give you better advice. Let me know...
Aug 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
See all GE Spectra JGBP30 Gas Kitchen Range Questions
GE Spectra JGBP30 Gas Kitchen Range Logo
803 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
