Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Bottom heating element in oven is not working - broiler works
The oven is only heating up to 270 and it appears that the lower element is not working at all. Do I need a new element or is there another problem? Everything else appears to be working on the unit.
  • Anonymous Jan 04, 2009
    did you ever find out what the problem was? mine just started to do the same thing. i took the element to a appliance part shop they tested it and said it was fine so i dont know what the problem is jbob1315@yahoo.com
Top element don:t heat up on bake
Posted on Dec 27, 2008
Early 1960's Frigidaire 24" Double wall oven not heating
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
Nov 07, 2014 | Ovens
My oven heating element doesn't get red and the oven temperature rises only until 270 degrees. The broiler element works fine. Any thoughts?
I removed the heating element and checked it with an ohmeter, which showed the element had shorted out. I've purchased another element on line.
Nov 21, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Oven does not work- broiler does
You have a heating element out in the unit. This element is located in the bottom of the unit. Unplug the stove and take out all the racks. There should be one screw on each side of the element on the back of the stove (inside of the unit) take out the screw on eack side and GENTLY pull on the element and you will see wires conected to the element. Dosconet and replace the element. You might see that one wire is burnt and not conected. You might try reconcting the wire and testing the unit. If that is not the case then replace the lower element and problem solved. If you have any more questions feel free to ask and I will be happy to help. Good Luck.
Aug 24, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Maytag electric oven - MER5770AAQ. lower heating element not work
Hi, Unplug the oven and remove the element to test it. Check the element and see if there is continuity. If the element is open, replace it. It can be bad even tho it doesn't appear bad.
I hope this helps you.
Vic
Jun 20, 2009 | Ovens
Oven and broiler: no heat
Flipped the breaker switch! Although we had looked at the breaker first thing, and it was not flipped off, plus everything else on the range was working: we found out it is actually a double breaker, with one half controlling just the oven, and it can be just partially flipped and you don't notice it. So as soon as you toggle it off and on again, you are back in full power.
Apr 08, 2009 | Kenmore Kitchen Ranges
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven not working
There is a separate element for the oven (bottom one) and the broiler (top one) It sounds like the bottom heating element is burnt out assuming this is an electric oven.
Nov 23, 2008 | Ovens
Bottom Baking element not working
dmiller58
If all your connections are solid then your controller is defective. Did you get any faults before changing the element? Does the broil (one at the top of the oven) work?
Post a response
Regards
Sep 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
395 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
