Question about HP Compaq FS7600 17" CRT Monitor
Monitor flickers and image is reduced and squeezed
Having this problem recently with this monitor. About 2 years old. Clicking sound sometimes and the monitor image will flicker and appear reduced and squeezed in on the left and right
  • 1 more comment
  • Anonymous Apr 11, 2008
    2 years old. Monitor flickers occasionally and now the screen goes black if idle for a short time and won't come back on. Green power light is still on.
  • BadDataJack May 02, 2008
    Sounds like the same problem - the monitor (MultiSync 75) clicks and the screen image will expand by a half inch on either side - or it will click and shrink by a half inch on either side.
  • no dice May 31, 2008
    monitor flickers and shows small wavy black segmented lines top to
    bottom, picture sometimes fades to blank screen then will come back
    to wavy black lines again and sometimes back to normal.
    I had this problem about a year ago and took off the cover and found
    some of the grounding jumpers connected but not locked, that seemed
    to help until now, we were gone a week and powered down everything.
    Now the problem is back, opened it again to check ground wires, all ok.
    Its funny, now since I started typing it has worked normal ............ ????
    Champion:
  • 220 Answers
Heat related dry solder issue Horizontal output side.
Posted on Feb 23, 2008
How do I fix flickering
Reduce the brightness level on the monitor, sometimes correct problem. The most likely cause is by the inverter transformer, and monitors usually have more than one.
May 09, 2012 | Tatung Computers & Internet
I have a IBM L151 LCD monitor which is 2 years old. recently while starting all of a sudden the monitor started displaying images in green color only. Secondly the horizontal images get restricted to half...
-try the monitor on another computer and see if it will be having the same problem
-if same problem w/ a different computer it need repair
-if not the computer that you are using w/ this monitor has a problem w/ the video card --try reinstalling the video card driver
cheers
Feb 25, 2011 | IBM ThinkVision L151 15" LCD Monitor
My monitor is about 6 years old. Some weeks ago, when I powered on, a grey streak started appearing and moved top to bottom before the normal image came on. Lately, the monitor blinks on and off when I...
2003 is the first one made, 14 years old it sure can be.
new to you sure,.
all monitors, from 2000 to 2010 year, are backlighted with
crude CCFL maps, that last for 2 years (shortest life full time)
the all go bad, ever one , if USED, lots.
they all: endup soon.
1: dim
2: yellow tubes.
3: flicker ands strobe (not the data just the back lamps)
4: dead.
5: totally interminttant.
just like the forecent lamps im garage and for the same reasons.
6: the osd goes dead to when above happens. menu key on monitor front, but not data seen with flash light trick.
learn when 4 happens, above, do this.
http://pcdied.com/monitors.html#flashlighttest
manual.
https://www.manualslib.com/manual/30069/Hp-F1523.html#manual
buy monitor 2011 and newer, and this pain above goes byebye
at the introduction of wonderful, LED backlamps.
Oct 16, 2017 | HP Compaq FP 7317 17" Flat Panel LCD...
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Blacks have changed to blue on my PC Monitor
Can you check your monitor's device settings (on physical buttons on the monitor) and check for changes to the Hue or contrast setting(s)?
It sounds as if the hue or contrast has been adjusted slightly, just enough to be visible.
May 24, 2009 | Acer AL2416W Monitor
Flickering, jittery image, white horizontal flashing lines
this is real old right
no photo off i messing up, how can we guess, what you see?
amazing....
my guess power pack shot.
i guess you cant barrow a monitor and try that?
2nd guess blind, the back light failing
or is damage if it was hit, the LCD will have damage
gently flex the frame goes nuts, bingo.
Mar 02, 2017 | HP Pavilion F1703 17" LCD Monitor
Screen flickers in 1680x1050 - samsung 2232BW plus
Can your monitor AND PC put out that resolution??
I don't think your Dell and put that out, if it's an "old" machine.
Dec 02, 2008 | Computers & Internet
Dell monitor
Who manufactured it? Better call them to check if the monitor's still under warranty. Im thinking it has to be replaced and may eventually fail completely.
Oct 03, 2008 | Dell Computers & Internet
Blueish flickering
Try to put speaker distance from monitor.
Try to remove the display card and fixed it again.
Then boot up your and see .
Apr 21, 2008 | Acer AL1913 19" LCD Monitor
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
HP Compaq FS7600 17" CRT Monitor Logo
237 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
