Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
50" Sony rear projection only 2 years old, will not curn on..
Starts to come on then shuts of and power light blinks red. Recently changed lamp and optic "box".
  • Any Guy
    Any Guy May 11, 2010
    How many times does the red light flash?
  • Sony Master
  • 5,138 Answers
Your Fan could be bad, pull back off watch when you turn set on if fan stops running lamp and set will not come on. I had set that fan would sometimes run for all day then set would go back to not turning on. finally would not come on at all It was fan going bad.
Posted on Jan 02, 2009
My sony kdf E55a20 does'nt come on ,has two red light's on blinking, the other not
the set may or may not have the self check feature--set off with the Sony remote hit display, 5, vol down and power.
Oct 29, 2012 | Sony KDF-E55A20 55 in. LCD Television
I have a sony kds 55A2000 and my lamp went out so i replaced it. and it startes up fan goes on and off . and tv shuts down light still blinks red? My optical block is getting a light green yellow tint but...
Lamp Fan should not cut off and on it should run at all times when TV is Turned on.Lamp Fan is designed to run when set is turned on to Keep Lamp Cool otherwise Lamp will burn up.
Yes Bad optical unit block could also cause set to shut down.But most of them will Play but with Dots,Green yellow tinit or Big blue Spots
Jun 23, 2011 | Sony KDS55A2000 55" HDTV
Power light is flashing 3 times consecutively. When hitting the power button the fan comes on then shuts back down..then starts flashing the red light again..I've recently bought a new lamp and installed...
Put lamp cover back in its place as 3 times blinking light shows lamp cover has not been fixed.
Lamp cover is first thing that you removed to replace lamp in tv, make sure it is fixed securely in its position.
Aug 13, 2010 | Sony KDF-50E2000 50" HDTV
KDF-60xs955 Sony WEGA. TV has no picture, no sound; green light blinks for a while then stays on. NO RED BLINKING LIGHTS. Replaced the bulb with no change in result. I would think it is NOT the...
Hi,did you close the door cover?Make sure itsproperly shut other wise it won't tv light up. Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.Also did you get the original Philips lamp if you got a generic that
could be your problem.God Bless you!
Nov 25, 2009 | Televison & Video
Series of 3 blinking lights. manual says lamp door isnt fastened properly. it is. i tried unplugging tv, have opened and closed lamp door 3xl. still blinking.
After I unplug and then plug tv to reset I get a solid standby light,then when I push the power button I get a green light that blinks 6 times then it blinks red 6 times and then red 6 times continuosly with a slight delay between the 6 blinks of red.
Oct 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Lamp not lighting
Reset the lamp and try it.
Mar 28, 2008 | NEC VT660 Multimedia Projector
KDF-55W655
red light blinks in 5 times then pause and then repeats. It is the lamp error. " Lamp Driver Defect"
When the "LAMP-PORT" (pin 95) is low, the lamp is not turned on. If the "LAMP-HV-DET"(pin 96) is low at the same time, it is classified as no high voltage of the lamp driver. I'm guessing it needs a Lamp driver which I think is on the C Board, which is part of the "Optics Unit Block Assy. The C Board cannot be orderd separately, and Optics Unit Blocks are not cheap. Good luck
Bobby G aka poolmvp1
Oct 31, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
