Question about Kirby Heritage II Vacuum
Wiring foot pedal switch legend II
Foot pedal switch broke in my Legend II and I want to verify where and how the wires go back into the new pedal I purchased?? Also, do you know if the manual talks about doing these types of repairs? This vacuum is ancient and still vacuums extremely well, I just want to be able to do the repairs.
Thanks
  • kcolrat Dec 22, 2008
    The foot pedal has an N by 2 connectors and L by the other 2 connectors..not sure what that means.
    Thanks for the insight into the manual.
  • 35 Answers
If I remember correctly,on the switch itself,each connector is letter coded.'W' for white,'R' for red,and so forth.The manual mostly talks about how to change attachments and basic operating,but not repairs.
Posted on Dec 21, 2008
When i press the foot switch the machine does not switch on. Is there an internal fuse?
Don't think there is an internal fuse.
If you have replaced or tested the plug top fuse & that's ok, it may be that the foot switch needs replacing or a wire has come loose from it.
Nov 18, 2009 | Kirby Heritage II Vacuum
My kirby legend II started spitting out sparks near the foot plug. How can I fix it please? Thanks Candy
Depends where the sparks are spitting from.Unplug from the wall and try to detach the cord from the vac itself, where it plugs in. If there is a small hole burned in the side you will need to detach the entire cord from the handle where it clamps on and buy a genuine new one from a vac repair shop or Kirby dealer. Cords do wear out. Ther is a slim possibility you could have a bad switch below but generally the switch just dies , no sparking.
If the sparks were shooting out from inside the motor housing, you will likeley need a motor rebuild which should be done by a professional at vac shop.
Oct 04, 2009 | Vacuums
Kirby Legend II, How do you remove Foot Switch
There is a plastic pop in trim cover which surrounds the switch itself. It will peel off revealing two screws which hold the switch in place onto the underside of housing.
However you must also remove the rear cone shaped motor housing by a series of philips screws where the motor meets the fan intake area. You should not have to remove any screws from the front are of the fan housing
Pay attention to these screws as they all face inward to the center area of the housing at the sides and underneath, but there are several lengths
Sep 28, 2009 | Vacuums
Foot pedal not working
sounda like the rachect teeth inside peddle r worn out probably need to take to shop for repair
Jul 10, 2009 | Kirby Heritage II Vacuum
Belt broke on shampooer
there are screws on the ends. I got it fixed.
Apr 11, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Legend II shampooer
make sure you have the exact soap added, tank filter cleaned after each tank fill up, turn tank knob all the way open, pull back slowly. try those...one or all has to fix it.
Jan 31, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Legend II
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11558&thid=818960
Kirby Legend II
Posted by smokey 1 on July 22, 2008
Hello, Help please, Using my vacuum, turned it off briefly, then went to turn it back on and it would not .I checked plugs which were both fine. Motor is strong, impeller is fine. The light comes on near the button to turn it on however it's not doing anything. Switch maybe? Just a guess. Thanks for your help! Alice
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It can be only one of 2 things, either it could be the safety switch or the foot switch and they would have to be replaced. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 22, 2008 | Kirby G4 Bagged Upright Vacuum
Legend II Kirby footswitch
Generic problem for all Vacuums
I have a Legend II footswitch foolishly did not record the position of the wiring I have 2 reds for the light and a positive and negative could you tell me which wire goes in what hole please
I do not have schematics of the wring diagram in order to help you on this question but to be accurate you will need to contact a serv tech tat would be in the yellow pages , or call the Kirby factory service or some examples listed below:
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874 ask for the service dept
Apr 18, 2008 | Vacuums
Foot Pedal was knocked out of alignment
You will have to take the top loose so you can put the handle release in its place. It probably isn't in the right place, either that or a piece of it broke off and it needs to be replaced.
Mar 16, 2008 | Bissell 1699 ProHeat Clear View Upright...
Vacuums Logo
293 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
