Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Ge fridge will not get cold, clicking relay on back panel board, no compressor or fan, or water working.
  • vndragone Dec 20, 2008
    thanks, part is on it's way..
  • JeetM Jan 04, 2009
    Actually I have the same problem but the GE refrigerator side by side model # is GSH25JSRF SS. Based on the given solution, I guess that even I need to change the relay board. Any help in getting this part ? Is it easy to fix or should I call appliance repair guy ?
    Thanks
    Jeet
    Problem Solver:
  • 6 Answers
That clicking relay is a sure sign of a bad control board. I've seen many of these go bad. You need to replace the board, it's an easy job. The board is held in with 4 plastic clips. Just pinch them down with a needle nose and pull out gently while doing this. Then plug in the harnesses to their respective terminal. Tenbears
Posted on Dec 20, 2008
My GE Profile Refrigerator (model PDS20MBSBB) is making a clicking noise. The thermostat display turns off while this happens. When it comes back on the fridge gets really cold and then slowly gets
needs new control board wr55x10942. condensing fan not running or running slow. it get to hot then the compressor relay cut off compressor to protect it once cooled down enough it starts back running.
Oct 09, 2014 | GE Refrigerators
How do I troubleshoot GE GSS25LGPABB sbs: no freezer, now no fridge?
everything runs through the computer board on the back of your machine,part number wr55x10942.pull your machine out away from the wall and on the back right side bottom you'll see the cover for the board,unplug the machine and remove the cover,look at the board,you'll see black relays on the board,the new board has all 7 relays,if your board doesn't have all 7go here and see it most likely this is your problem.everything runs through the board,have you noticed your fans running at different speeds or anything else like that
http://www.repairclinic.com/PartDetail/Main-Control-Board/WR55X10942/1531075another thing it sounds like you have no compressor,all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer over to the fridge side so if the freezer is down the fridge side is going down too.here's a picture of the board
http://www.flickr.com/photos/zenzoidman/4482598198/sizes/o/in/photostream/
if you look at the diagram it tells you that if you jump out j8 and j11 the compressor should start,i've never done this but i did jump out j9 and j11 to check the defrost heater and thermostat.hope this helps you out and good luck,also if you do jump it out and the compressor doesn't run you can check the overload and relay on the compressor for continuity but most likely you have a bad computer board.
Sep 02, 2012 | GE Refrigerators
I have a GE profile side by side model PSS26SGRCSS. Lately the water and ice dispenser have worked only intermittently with a dimming of the lights. Tonight it stopped working and the temperature display...
Something has malfunctioned on *********** control board part number WR55X10942 This board controls most functions of the refrigerator. It would be simple to say change the board but this is the first time I have seen one affect so many different controls that I recommend that a service technician come out and make sure that something other that that board is not affecting the other controls on your refrigerator. Please let me know what the technician finds, Thanks, Sea Breeze
Sep 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
HotPoint fridge clicks and the fan doesn't turn
14 vac indicates a bad motherboard.Clicking could possibly be a bad start relay on the compressor.
Relays are inexpensive. I would replace the relay and hope for the best. Next step would be the motherboard that GE has had trouble with from day one
Jul 21, 2009 | GE Refrigerators
GE MODEL GSH25JSRF-SS PROBLEM HELP PLEASE
I had the same problem back in March. First the water and ice dispensers stopped working, then the clicking started and the compressor wouldn't turn on. I replaced the circuit board and everything started working again, until today. This is a very common problem with the circuit board on these refrigerators. Do a search for "GE circuit board" and you'll see what I mean. GE issued a service bulletin to its technicians that this service should be provided free of charge, and anyone who already paid to have the circuit board replaced will be reimbursed. I wish I would've known about it 6 months ago. I will be calling GE Consumer Affairs on Monday to get this resolved.
Jul 26, 2008 | GE GSL25JFPBS Side by Side Refrigerator
Freezer fine /After power went out twice fridge not cold enough
In back of the refrigerator is a removable panel behind which is the compressor. Listen for a hum and a click. If you hear those sounds the compressor may have failed. Behind that same panel is a condenser where heat is removed from the refrigerating system. Make sure it is clean and check that the fan operates when the compressor runs.
Jun 07, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Relay clicking, not cooling either side
First of all Give me model# and Serial#.
you will most likely have to replace main control board and evaporator fan motor. They have had a service bulletin out on this problem.
Jan 17, 2008 | Hotpoint HSS25GFP Side by Side...
Fridge is not 'freezing', Looks like fan stopped working
could be due to ice build up jamming the fan. take back panel off and check for ice. if ice present the defrost system has failed. also on some models, the fan stops when door is opened. check door switch is operating
Mar 22, 2007 | GE GSS25JF Side by Side Refrigerator
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
112 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
