Question about GE 24 in. ZBD7100GSS Built-in Dishwasher
Wash Motor Keeps running after water pumps out
Hello, I have a 2 1/2 year old (just out of warranty) Monogram Dishwasher that runs through its regular cycle and rinses fine. However, the wash motor doesn't shut off and will run for hours until I cut the power out and open the door. When the power comes back on, there is usually a "3 beep pause 1 beep" or a "3 beep only" code that comes on. When the door is shut again, the wash motor turns on again and keeps running. If I reset the fault condition, the dishwasher will return to normal for 1 or two cycles and then get hung up again. Many articles I found on the internet regarding GE dishwashers reference a stuck fill switch due to too much soap, but I can't seem to find anything like that on this model. I've put the electrical schematic from the toekick at http://www.leaf.org/GE/GEdwelectrical.pdf Any help would be appreciated. Thanks
  • Lee Evans Jun 08, 2007
    You are absolutely right. A relay on the control board inside the Door was fried.
  • 87 Answers
You have a bad control board in the unit.
Posted on Jun 08, 2007
I have a Monogram that I was able to get out of this by taking out an overflow reservoir (cloudy square/trapezoid plastic box) and washing out the chalky detergent sludge.
Posted on Jul 05, 2007
LG dishwasher model LDF6920WW 1 1/2 years old approximately. Suddenly stops a minute or so into cycle (it drains remaining water and fills with new water then get LE error). When I open the door at the...
The manufacturer has assigned this error or fault code to indicate a problem with the water circulation pump motor. Turn the appliance off for 30 minutes to allow it to cool. Then, restart the cycle. If the error code returns check the wiring to the pump motor. Also, if the wash impeller is broken this error can appear. If the impeller and wire harness check out, and the code keeps returning, you will probably need to replace the pump and motor assembly.
Aug 06, 2017 | Dishwashers
Water comes in but doesnt push threw spray nozzles, and a humming is heard.
This indicates a failed wash motor or clogged screen in the sump assembly. On your model dishwasher the pump and motor is the likely issue, I replace several a month on this style dishwasher. On some of these the motor has a five year warranty, check your use and care guide on the warranty page.
http://www.appliancerepairlesson.com/
To determine if the screen is clogged remove the bottom rack and take the wash arm off. Once off you can access the screen by removing the one torx screw in the bottom. Like I said on this style dishwasher the motor has likely failed. If the motor is getting 110v and it sounds like it is then it's bad. Check the warranty on the motor!
Mar 01, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
I have a model 665.15831791 When it fills with water it does not go into a cycle, it automatically discharges the water
It could be two things causing such problem: no power to the wash pump motor or the motor itself is bad. Remove the wire plug from the motor and check for the 120V when the timer is on wash cycle. If there is no power then check the wires and the plug at the timer. If this is not an issue replace the timer.
If there is a proper power to the motor then the problem with your dishwasher is a bad wash pump motor. If your dishwasher is less then 5 years old then it could be under limited manufacturer warranty. Call kenmore with the model and the serial numbers and they will tell you. If the dishwasher is more then 5 years old I do not recommend you to repair it yourself. I've seen many times when it's not possible to install the pump back after repair because the plastic tub got warped.
here is the link to the schematic diagrams for your dishwasher ... you can also order for timer and other parts if need be from the same link as well
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dishwasher-Parts/Model-665.15831791/0582/0130000?pathTaken=
Sep 03, 2010 | Kenmore Dishwashers
I have an MDB760 dishwahser making a lot of noise
The pump is not turned on when the what is sloshed around. It is the wash motor which turns the arms around. It is likely something is stuck under the washer arms or the washer motor bearing is faulty.
If the dishwasher is only about 2 years old, I would suggest you call Maytag for warranty service. Depending on the part they will have different warranty time period. Normally 2 years should be a general policy .
May 08, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
Whirlpool gu2200 dishwasher, the detergent
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Aug 27, 2009 | Whirlpool GU2200XTSS Built-in Dishwasher
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
Water not draining from GE Monogram
hi, check your waste pipe is clear, check that the filters in the bottom of the machine are clear, try it again on rinse cycle, if it does not empty select rinse again and gently turn selector click by click ,see if empties now? if it does it may be your progamme timer fault if not it may be your pump
Feb 05, 2009 | GE 24 in. ZBD0710KSS Stainless Steel...
Dishwasher
Hello tytsai2005
Welcome,
You said,At the end of a wash, some water still remains at the center of the bottom
You have a clogged dishwasher drain, or drain line.
Otherwise your Caloric's pump is pooping out on you!
Is the model # CDC550CL or CDC550CW ?
Here are 4 things that I believe can be the reason for your machine not pumping all the water out!
1. Defective Motor
print.gif Print save.gif Save to list email.gif E-mail to a Friend help.gif Diagnostic Help Rate Article Helpful Not Helpful Was this helpful?
How can we improve?
The water pump is driven by the drive motor. If the motor is defective, the pump will not operate and the water will remain in the tub.
2. Defective Pump
Most but not all dishwashers incorporate a reversible motor. By using a pump impeller and wash impeller, the action of washing and draining is accomplished by the reversing of the motor. If the drain impeller in the pump is defective, the water will not drain. Check the pump impeller for proper operation.
3.Drain Line
Check the drain line for kinks. If the line checks out visually, it could be an obstruction in the line
4.Garbage Disposal
If a garbage disposal has recently been installed, make sure the knock out for the dishwasher drain hose has been removed. You should also make sure that no items under the sink have been pushed into the drain hose. Any kink or crimp in the hose can cause it to stop draining.
How old is the dishwasher ?
Here is an interesting article I just read, that you may find interesting
Repair or replace?
When to pull the plug on your old dishwasher
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your dishwasher,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your dishwasher is under warranty or less than four years old ,
paying for a repair makes sense.
Note that dishwashers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your dishwasher is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new dishwasher.
Data also shows that it doesn't pay to fix a less-expensive dishwasher
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of dishwashers you replace are likely to end up in a landfill.
Let me know how you do!
Thanks for giving me the opportunity to help!
Huuum
Please do not forget to give a rating before you sign off!
Oct 20, 2008 | Caloric CDC550C Dishwasher
Dishwasher not pumping the water out?
hi
the larger motor housing underneath the unit is what moves the water around to wash, the smaller pump is the drain pump, if you don't hear that running it is likely in need of replacement. check your paper work for warranty, if it's out of warranty try to find a deal online and it's relatively easy to replace
Mar 20, 2008 | Frigidaire 24 in. FDB750RCC Stainless...
GE 24 in. ZBD7100GSS Built-in Dishwasher Logo
603 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Steve Allison
Steve Allison
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
