Question about LG L1932TQ LCD Monitor
See the picture or 1 second when power on the monitor
I can see the correct screen only when i power on the screen, for 1 second.
I can see it again after turning on and on again(For about 1 secpnd)
    Problem Solver:
  • 6 Answers
This sounds eerily like what happened to me a few months ago with a 15" Omnitech monitor I got at an online auction. Unless you are a tech, or at least confident in dissassembly of your monitor and toruble shooting component problems, you may need to find someone near you to help. My problem was bad capacitors in the inverter board circuit. (Google BAD CAPS or go to badcaps.com for more info on that.) I got really lucky that two of mine actually looked bad, they had swelled up, so I replaced them and the monitor now works perfectly.
For someone who does this for a hobby or living it doesn't sound too difficult. Don't try it on your own without proper help. I hope this helps.
Posted on Dec 20, 2008
Monitor screen is black. If I switch it off and on again it'll light for 1 second and then go off. I rebooted and it came on for 1 second each time the powering up screen changed.
The picture board on your monitor is bad, since it goes off after a second and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board.
Regards.
May 17, 2010 | Computers & Internet
Screen blanks out when turning on after two seconds
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
Will the power button still be on while the screen is blank? if yes, it means your picture board is malfunctioning.
The picture board on your monitor is bad, since the screen turns blank after two seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 29, 2010 | Samsung 19 SyncMaster 192MP LCD Monitor ...
The monitor displays the screen then goes black. For example, I turn of the monitor off and then back on. I will see the screen for 1/2 second then it will go black.
Hi sglick - you will need to do a few simple trouble shooting steps to pinpoint the problem, as this can be cause by several different things.
Follow these steps and reply back with your findings: 1. Unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor. 2. Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet. 3. If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad. 4. Disconnect all connected devices except the mouse, keyboard and monitor. This includes thumb drives and camera-type memory cards from card reader slots. With the devices disconnected, restart the computer. If the computer starts and the monitor now displays a picture, a device is preventing the computer from starting or sending a proper video signal to the monitor. Update the BIOS to resolve this issue.
If doing all of this doesn't change your issue of no video after seeing it pop on, try the monitor on a different computer/laptop, and if you have one, a different monitor on the system with the problem.
Let us know what you find following these steps and we can figure out what to do next. -Trev
Oct 03, 2009 | Dell E173FP 17" LCD Monitor
Screen goes blank right after power up
Same symptom with mine. Turned out it was NOT the monitor, but the stand-alone power supply. Once the display fully powered on, the supply would cut out, apparently unable to drive current needed. I stole 12V from the computer's power supply and have no problems. Your display is fine.
May 28, 2009 | X2Gen MW22U Monitor
LCD show right picture for 1 second when I turn on, then go black
you need to read the monitor manual . other wise you can contract the dealer.
Jan 21, 2009 | Computers & Internet
ACER AL1715 PowerLed blinking only,no picture,flash about .5secs
This sounds as if you are using the hibernate feature in windows reboot it and reset the power options to hibernate never check the vid connection as well
Dec 19, 2008 | Acer AL1715 17" LCD Monitor
Power button stay on for 2 seconds, black screen,no picture
hi there, yes, you do have a broken monitor, bring it to qualified service personel how can repair the monitor. or you can just simply replace it. TY
Nov 29, 2007 | HP vs15 15"LCD Flat Panel Monitor
LG L1932TQ LCD Monitor Logo
334 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
