Question about Sony Mavica MVC-CD500 Digital Camera
Camera dropped, disc error c:13:01 shows up on the screen
When I dropped my camera a disc error and C:13:01 has shown up on the screen. I tried to down load my pictures from my disc, but my computer tells me that there isn't any pictures on that disc. Is there any way to save my pictures and fix my camera without spending lots of money?
    Genius:
  • 2,985 Answers
Mo- Fixing will cost lots. As for downloading images- go to www.konvar.com and download PCInpector install it and see if it can see your missing images.
Posted on Sep 13, 2007
Camera failed.. how to sole tat
First, go into Settings, and choose Applications.
From the Applications menu, choose Running Services.
When shown the list of Running services, press the Menu key to show the option Show cached processes. Select Show cached processes.
Scrolling through the list of cached processes look for the Camera app and select it.
When you select the Camera process you will have the option to Stop it. Choosing Stop should successfully release the camera hardware.
After stopping the cached camera process, return to your home screen and try relaunching the camera app or whatever other app you were trying to run when you ran into the "Camera Failed" error message. It should now successfully start with access to the camera.
Nov 15, 2013 | Samsung Cell Phones
Tip
Solution for nikon "lens Cover Error"
Nikon Coolpix S5/S6 “LENS COVER ERROR”
In this document I have given a solution to fix the problem most of the Nikon coolpix S5/S6 cameras face. At power –on it give an error “Lens Cover Error”
Before opening the camera I would suggest you to take a snap of each and every step. Because it will helpful while you are fixing the screws back. There are many screws which has to be opened. So better take a photo of each and every step.
IMP NOTE: Remove the battery before opening the camera. Use some antistatic strip to prevent the components from getting damaged Or Keep your feet touched to the floor such that your body remains grounded.
Follow the below steps in the given order:
Step 1> Remove the screws at the bottom of camera
Step 2>Remove the side screws
Step 3> Remove the side screws as given below .
Step 4>Lift the cover and remove the cables which connects the switches to the camera. These cables are fitted in a small connector. There is a tiny lock (present for few connectors)  on the connector, which on pulling it across its hinges, will open and the cable comes out easily. You need not pull it forcefully.
Step 5> Remove the screw as shown below
Step 6> Lift the screen as shown below.
Step 7> Remove the cables and screws as shown below.
Step 8> Lift the screen panel as given below.
Step 9>
Remove cables as shown below.
Step 10>
Remove the cables as given below.
Step 11> Remove cables.
Step 12> Remove cables
Step 13> Remove the 4 wires using a soldering iron.
Step 14>
Step 15> Removing at this stage is a bit difficult. You will have to open it cleverly. Lift it from the side as shown below.
Step 16>
Step 17>Below figure shows the lens cover and the stepper motor which controls the lens civer.
Step 18> To remove the stepper motor remove the screws as given below.
Step 19> Below figure shows the stepper motor used for lens cover
Step 20> Below figure shows the stepper motor which is used to control the lens cover. There is a small white switch on this motor. This Switch is used by the camera to detect whether the camera lens cover has is open or closed. When we switch on the camera the lens cover (which is shown in step 17) opens and in turn it presses the white switch show below. If the lens cover is unable to press this switch, then the error “Lens cover Error” flashes on the camera.
I would suggest 3 different ways to solve this problem.
1>     Fix some glue on the white switch shown in the below figure, such that it remains pressed forever. Because of this, camera will never give the error message. Remove the lens cover (which is shown in step 17) forever. You don’t  need it anymore. Now fix the below stepper motor back in the camera and follow the steps in the reverse order to fix the camera components.
2>     Buy a new stepper motor from the market. Its quite cheap. Fix it back in the camera. Here you need not remove the lens cover. Follow the steps in the reverse order to fix the camera.
3>     In this method you can open the stepper motor to fix the problem. Now follow the steps given below.
Step 21>
Remove the screws as shown below.
Step 22> Remove the gears one-by-one. See the placements because you have place them again in the right order.
Step 23>
Step 24> The gear shown below is the culprit. Remove it. There is a tension spring present inside this gear. Do remember the position of this gear before removing this gear. Its placement is very important.
Step 25> The spring is shown below.
Step 26> Now the switch shown in step 20 does not get pressed because of reduced tension of the spring. Increase the tension of this spring by pulling it in opposite direction. Place the spring back in the gear and follow the steps in the reverse order to solve the problem. Now because of increased tension of the spring, the lens cover will be able to Press the switch shown in fig 20.
Happy debugging
Mukesh
on Mar 25, 2009 | Nikon COOLPIX S6 Digital Camera
Camera failed
Aug 29, 2013 | Samsung Galaxy S Ii S2 I9100 16gb Unlocked...
My camera battery indicator not show the battery status while using camera but batteries are shown when executed. find solution.pls.
The camera will not display the battery status until it drops below a certain threshold. When you don't see the status on the screen, take that to mean the status is good.
Jan 19, 2013 | Nikon Coolpix L310
Camera not working
"camera standby"
is that shown on your screen when you try to use camera?
if "camera standby" shown on your screen
probably its failure from Rap3G(Radio Aplication Processor 3rd Generation / CPU) .
"RETU" the name of IC power on Nokia 3110 deliver vdig cam 1,8v to and vana 2,5 to connector camera.
if this voltage not deliver to the connector camera the error will be "operation failed"
to check if the error come from Rap3G check the cam clock, if it under 9,6Khz change your Rap3G
Sep 23, 2009 | Nokia 3110 Cellular Phone
Lens does not retract or show an image. D18 is shown on viewfider. everything ese works
Lens errors (believe "E18" is showing on your viewfinder) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 05, 2009 | Canon PowerShot S2 IS Digital Camera
My Canon Power Shot A80 Digital camera goes ON but only shows the screen name Canon then the lens goes back into off - some sounds come on and then E18 shows in the lower left of a black screen. Help.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 09, 2009 | Canon PowerShot A80 Digital Camera
Camera does not go on
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Jan 11, 2009 | Canon PowerShot A520 Digital Camera
Powers on then lcd screen shows disc error ; c:13:01
i had the same issue i have a couple of thease i use for parts the drive error will be 1 of 2 things 1 a bad floppy 2 the floppy drive is bad i had to take one apart and swap the drive out witch fixed the issue on the other note ther cheep on ebay so i'm trying to hack it to install a SD card insted just to see if it will work good luck
May 07, 2008 | Sony Mavica MVC-FD7 Digital Camera
8mm dvd
Have you finalized the disk? I would suggest that you put it back in the camera and finalize.
Dec 27, 2007 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony Mavica MVC-CD500 Digital Camera Logo
313 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
