black lines go down the screenblack lines go down the screen
AnonymousApr 12, 2009
when playing the game for a little while black lines on the screen appear this was when play cod waw its making it hard to play somebody help plzwhen playing the game for a little while black lines on the screen appear this was when play cod waw its making it hard to play somebody help plz
Try taking it off hdtv and putting it on tv using the yellow,red, and white cord If it doesn't work contact Contact me and i can probably solve it then
XBOX 360 repair guide
available that covers this problem and also all other common XBOX problems. You
can get your copy XBOX 360 Repair Guide, you can download it and get help to
fix your console..... click here to download repair guide
These "black dots" you talk abotu could be a variety of things and since you haven't given much detail it's hard for me to say.
Just double check it's not your TV or cables or any nearby electrical products causing interferance so you're certain the problem originates from your Xbox 360.
Hopefully, it's just a problem with your cable, maybe it's not plugged in right or maybe a replacement will fix it.
When I say hopefully, I mean, hopefully it's a cable fault as opposed to an Xbox 360 hardware fault. Variations of black lines or dots, or just general artifacts on screen while using your 360 usually happens prior to a hardware fault usualy concerning the GPU.
I guess it's just a waiting game for you now mate.
Just check it's not your TV or cables or any nearby electrical products causing interferance.
check your game for deep scratches on the cd if there is none, then your best bet is shipping it back to microsoft or there is actually a company that fixes your 360 for a cheaper price. just google xbox 360 recall and if you look through the pages of signatures you will find an advertisement for 360 recalls go to that and call the #, i hope it works out for ya.
Hi i on u r screen white dotted vertical lines comming & if the no. is more than 6 the if the laptop is under warrenty then company will replace the LCD & if not under warrenty then to fix this issue u have to replace the LCD.
I had this happen a few times, then after a while it stoped working all together. In the end I was getting the E74 message code appear when I turned on my xbox 360.
You'll probley get this happen with yours soon, the E74 code means theres a problem with your visual display.
Sometimes it can be as simple as changing your HD Lead or scart lead, whatever your using. If you know someone else with a xbox try theirs.
If this doesn't work you'll have to send it off to mircosoft, it will be free if your still under warrenty, if not I think it's about £100+
Or you could go on www.cd24-7.co.uk and buy one of their DIY kits.
how can fix this problem so that i can stil use hdtv?
me 2 help!
