Question about MGE Galaxy 3000 UPS System
Sukam home ups not charging the battery
I have su kam home ups but the problem is its indicator showing charging but it is not charging the battery when checked with ampere meter...........
both scr are ok but problem isnt diagnosing .......... if somebody has its circuit diagram plz send me
  • abhij1987 Apr 16, 2009
    I have a champion ups-500VA .
    My problem is my UPS is directly shut down when power supply is gone tell me what i can do..
I have a sukam falcon 1.4kva inverter I just got it back from the service station. It was tested ok. On getting home and connecting to my main (with the inverter off) all the lights came on and there was...
I am guessing it is because you are running mains power into it. You are supposed to only connect it to low voltage and the mains voltage comes out the other side when your house power is off.
This seems more of an uninterruptible power supply for computers? They are usually self contained and connected to the mains at all times. When the mains fails, the internal battery sends out 110 volts automatically in an instant. This seems to be a 12 volt inverter though. It's confusing.
http://www.sulekha.com/inverter/su-kam-falcon-1400-va-inverter-prices-and-specifications
Aug 26, 2018 | Televison & Video
My inventer 100w sukam is not loading of one cfl 15 wats . Ichanged many battery of 12v ,7.2 ah but they showing low battery what is the problam.
What happens with no load? WHat IS the battery voltage exactly?
Many inverters/UPS wont start with uncharged batteries to protect them.
Oct 23, 2014 | Computers & Internet
Sukam 800VA not charging my battery
Check the charging voltage if you know how to use a multimeter .
if it is 13 volts then it is ok.please tell me how old is your UPS and battery.if the battery is 2-3 years then it may need replacement.
after checking the charging voltage charge the battery or some 6-8 hours promptly maintain charging .
Aug 10, 2014 | Computers & Internet
How do I find this manual?
Doesn't seem to be on line better call Beckman with serial number of the unit.
Nov 13, 2013 | Beckman Du Series 60 Spectrophotometer...
My sukam home ups on continuous buzzer &inv0n indicator & low batt indicator on but batt is ok wath problem
You have this posted in the car and truck forum. Please post it in the correct product category so the right expert will see the problem and help you.
Feb 21, 2012 | Cars & Trucks
My sukam sinewave inverter its output is less than 10volts
Hi rutabairu,
We are extremely sorry if you have been inconvenienced through a Su-kam product. However, we pride ourselves on prompt and effective customer service. Please provide us with your name, contact number and address. Please give us the complaint number and date as well and we assure you to look into the matter at the earliest. Mail us at custserv@su-kam.com, We would do our best to resolve your grievance at the earliest.
Hoping to hear from you soon.
Sarita
Su-kam Executive
custserv@su-kam.com
Jul 25, 2011 | Electronics - Others
My SUKAM Shiny 400va sinewave home ups is powerd half when utility power off. overload light glowing. But this ups running perfectly at the same load before.
There might be a problem in the battery acid concentration. Take the battery to a battery recharging shop. The specific gravity of the battery has to be 1.22-1.25 for a fully charged battery.(if your battery is lead acid type) Handling lead acid battery(or any other battery) without proper knowledge and supervision is very dangerous.Be cautious.
Dec 03, 2010 | Electronics - Others
I am using sukam 650 tourque inverter before 3 month . from 15 days fuse of inverer getiing fused again and again after 2 3 daus of replacing new fuse . waht can be the problem ?
Dear customer,
We are extremely sorry that you have been inconvenienced through a Su-kam product. However, we pride ourselves on prompt and effective customer service. Please provide us with your name, contact number and address. Please give us the complaint number and date as well and we assure you to look into the matter at the earliest. Mail us at custserv@su-kam.com, We would do our best to resolve your grievance at the earliest.
Sarita
Su-kam Executive
custserv@su-kam.com
Sep 01, 2010 | Kitchen Ranges
My sukam 800 VA inverter is dead
If the regulating circuits 78xx had blown it means that the input voltage which may be 18 - 35 VDC has been fed to all ICs. Some of them or all may have burnt. I did not understand which crystal did you change (the 2 - 20 MHz Quartz may be), but I think that rather the PIC was damaged.
If you have Oscilloscope on hand, check the oscillations on PICs clock.
Jul 18, 2010 | Inverter Pure Sine Wave 1500w Inverter
Computers & Internet Logo
678 people viewed this question
Top MGE Computers & Internet Experts
Marvin
Marvin
Jose Pino
Jax Planet
Jax Planet
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
