Question about Maytag Ensignia 3.3 cu. ft. Top Load Washer
Maytag ensignia washer...cold water settings
I have the maytag ensignia washer...none of the cold water settings are working...i have cold water coming through to my laundry tub sitting next to the washer...if i set the dial to say...warm wash cold rinse...warm works...cold doesn't...same with cold wash cold rinse...no cold at all...
  • echo34 Feb 21, 2009
    I have the same problem on a Maytag Ensignia washer (model number MAV6358AWW). I have a temporary fix that sometimes works. When the problem occurs, I just play around with the Automatic Temperature Control feature.
    Here's an example sequence of steps:
    1) Problem: On cold/cold setting, no water comes out.
    2) Switch to warm/cold setting. Water starts coming out.
    3) Turn "Auto Temperature Control" on.
    4) Switch to cold/cold setting. Now only cold water comes out, as desired.
    5) (Optional) Turn "Auto Temperature Control" off.
    6) (Optional) Shut off hot water valve at the wall. That's because warm water sometimes comes out on the cold/cold setting on my machine. Remember to turn it back on when you're done with your load.
  • Maytag Master
  • 17,827 Answers
You need to remove the cover and check the voltage to the cold water inlet valve. Do this with a volt meter while it is set to fill with cold water. It is most likely an AC voltage that is around 24 volts. If you have voltage then the valve is most likely bad.
Posted on Feb 16, 2018
  • 1294 Answers
SOURCE: Maytag Atlantis -won't spin
Find out where your filter is & clean it out thoroughly, refit.
Posted on May 10, 2008
kaienana
  • 10 Answers
SOURCE: Maytag Ensignia Oversize Cap Plus Washer stopped working in mid cycle
Check the water level control, it could be stuck or faulty.
Posted on Jul 07, 2008
SOURCE: Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Posted on Nov 19, 2008
  • 311 Answers
SOURCE: washer's warm setting alternately fills hot and cold
Call for wty svc- the temp switch is bad; they had many of these built like that Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Posted on Nov 30, 2008
jumptrout51
  • 3361 Answers
SOURCE: Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Posted on Apr 02, 2009
Washer will work in Rinse or Spin settings, but not any wash settings
If you are doing the normal procedures and the water elimination function is working, you have power to the circuit board and controls. The circuit board wash cycle section is independent and aligned with the timer circuit, thus the Wash Cycle Controller has failed. All of the functions or options are one the one board and a replacement board needs to be purchased and installed.
Feb 26, 2014 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag ensignia top load washer will not fill with water at start of the cycle?
The drain hose has to be at least 30 inches above the floor or gravity will drain the machine. Also: If the water hose is jammed into the drain a siphoning affect will occur in some instances.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 04, 2012 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Cold water doesn't shut off and keeps pumping into washer
Replace the water valve where the hoses connect to the washer.
Mar 24, 2009 | Maytag Ensignia 3.3 cu. ft. Top Load...
My maytag ensignia washer has an electronic panel. We took the little basket out of the cold water line cleaned it and replaced it. Now the washer, in all cycles, will start to fill then stop and all the...
first I would check your water lines that they are on all the way and that you didn't switch the cold and the hot water line...if this doesn't work let me know we can go deeper into it....let me know
Sep 13, 2008 | Maytag Washing Machines
Maytag Ensignia 3.3 cu. ft. Top Load Washer Logo
258 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
