Bang & Olefson Beocenter 7000 When pressing "Tape" the tape player does not play. It clicks but whatever contacts the inserted tape retracts
robotek
  • 1512 Answers
SOURCE: TEAC V770 3head tape deck.
Hi saabangerman
The unit sounds like it has a take up clutch or takeup idler problem. Check all the drive assemblies in the unit. Remove the cover from the front of the transport inside the cassette well, and check the condition of the idlers and reel base drives. The counter belt can also gatherup and prevent the takeup reel from working correctly, or fire the auto stop mechanism preventing it from playing, although that sounds to be ok in this case as the unit will FF and REW ok. The takeup drive is supplied by a different drive idler as it requires much lower and more controlled torque. This unit was always considered to be a great tape deck and is well worth a bit of attention for restoration. You can get a new belt kit for $19.00 from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
SOURCE: My sa-ak40 panasonic cd music
My dear friend the belts of your tape sistem are damaged you need to change him.Good luck
Posted on Jun 02, 2008
SOURCE: My Teac Z-7000 will not record tapes
some weeks ago I got this really impressive deck (Teac Z 7000) from a colleague, and found the same problem. I fixed it, and the fix is not too complicated. It´s the potentiometers that do fail. All pots are from the same manufacturer (Alps) and construction. The problem is that the wisher is broken away from the holding plastic and will loose contact completely. You can check that with a normal ohmmeter: You´ll find the total resistance over the outer terminals but endless resistance from one of the outer terminals to the middle wisher contact. The values are: 100 kOhm linear for each of the upper left pots (fader,space), 2x22kOhm pos.log. for the lower left pot (phone volume). So, what does a broken wisher at the "fade in" pot do? The Recorder "thinks" that You selected an "endless" fade in time, and the result is : no record level. You can do an easy "quick and dirty" fix just to see if that´s the problem: Hold- or better solder- a say 47kOhm resistor in parallel to the conducted potentiometer terminals and try to record.
4 of 5 pots have been defective in my deck, and I´ve replaced them with standard types from my local electronic supplier (Conrad electronic, has a shop in Frankfurt/Main). Well, the new parts didn´t fit perfectly, I used a file to get them in (not visible from outside). Also I lost the possibility of pushing the knobs in and out, but that is not a really problem.
I assume this fix might also help owners of the Teac Z-6000 and Z-5000, which- most probably- use the same type of potentiometers.
This text was written by Boris Witke, Kelsterbach (near Frankfurt/Main), Germany. E-Mail:
witke1@web.de Please tell me if You were successful, possibly we get lucky users of these really fascinating machines.
Posted on Feb 24, 2009
SOURCE: Harmon Kardon reel to reel tape player
I have a Harmon Kardon TD-3 that I'm looking to sell. It's not in its original cabinet, but in a smaller box that takes up less space.
Posted on Oct 19, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a pioneer CT-F900
The take-up reel is dragging or the belt is stretched or broken. No surprise on a deck this old. Try Fast Forward. Try Rewind. Same result?
If it still doesn't work, and it happens with only one cassette, rap the cassette's flat side against a solid flat surface to loosen it. Try again.
If you're really an old-school deck user you probably know how to cheat the transport with no tape resent to make the capstans engage for cleaning. Try that. The two reels should spin opposite as if maintaining tension. If the right one is stationary or lethargic (try to feel how strong it pulls compared to the left one), there's a loose or broken belt.
Next step. Get out the can opener, go inside and see what's wrong. Good luck.
Posted on Dec 26, 2010
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
When inserting vhs tape, the player pulls the tape from inserted vhs
That is exactly what a typical M-Load mechanism is supposed to do. Once the VHS tape cassette is inserted, cassette housing cover will be flipped up and two arms will pull tape out of cassette housing to wrap tape around cylindrical spinning head housing that contains video heads and, if VHS HI-FI, audio heads as well. When stop or eject button is pressed, arms will retract and tape will wind back into cassette housing. What type of problem are you experiencing with unit? It may have nothing to do with M-load engaging tape around head cylinder.
Mar 22, 2014 | Samsung DVD-VR325 DVD Recorder/VCR
Beocenter 7002 tape deck starts and clicks off within 2 sec.
If the take-up spool (r/h) doesnt turn the autostop will activate.Both these spools get clogged with old grease with age, remove and clean/regrease them,check all belts while apart and replace any limp ones.Removing the tape deck requires some knowledge.
May 09, 2010 | Bang and Olufsen Beosound 2000 Shelf...
Black glass control panel has become unstuck; where to get suitable adhesive tape? Ref Beocenter 9300.
unscrew glass panel at back, take all plastic trim off and remove all sticky residue on these and the glass, then use liquid nails sparingly and let dry thouroughly before reattaching (slide panel back on, then put rear screw back in.
Dec 27, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
The sliding cover for the tape player sometimes gets stuck when opening.
if we are talking beocenter 9000/8000/9300/8500/9500 replace belt,clean and lube door guide rails
Oct 19, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
Glass panel unstuck
if product is beocenter 9000/8000/8500/9300/9500 remove screw under l/h side of panel, push panel to side and remove.careful to note position of plastic attachments and metal screw socket.lay face down on bench and apply thin ribbon of epoxy resin where double sided tape is,do not clean off old tape.apply glue over top.assemble plastic parts on top and leave to set.refit to machine and refit screw.
Oct 14, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
On our Bang and Olufsen Beocenter 9000,
if sticking is only your issues, then replace all belts. Cleaning has nothing to do with the sticking of doors.
Apr 06, 2009 | Bang and Olufsen Beocenter 9300 Shelf...
I found a loose part in the VCR bay I'd like to reinstall. Part #T5B
I found that part #T5B was on the bottom of the VCR tape tray on the right side of the VCR tape bay opening and was spring activated by inserting the tape to allow the tray to retract into the player mechanism. Without a tape installed, part T5B prevents the tape carriage from retracting.
However, I still couldn't get the whole mechanism timed properly, and gears were skipping teeth, the mechanism was still binding, and shutting the power for the whole player down. Therefore, I removed the rubber drive belt that operated the VCR tray insertion/ retraction process, and disabled the VCR side from operating at all. This allowed the power to remain on and allow the DVD side to work properly.
This worked only for the Phillips DVP3150V/37. I cannot say for certain if other Phillips players are the same.
Oct 12, 2008 | Philips DVDR3435V/37 DVD Recorder/VCR
Broken cd player
The motor is last thing to gone before you go to service check the rubber belt which connect the motor to the door gears.Your set is 20 years old and this should be the problem and easy to fix
Feb 07, 2008 | Bang and Olufsen Beocenter 9300 Shelf...
VHS player stops
VCR is set with blank tape..Bring up vcr control on TV with television set on Chanel #3, go to menu
Follows procedure for progamming date,time start,time finish,chanel and.speed and single recording.finally click on menu and turn vcr off. Vcr lights indicate set for taping,,.Does no start to tape at requested time and lights indication taping ready stays on ??????
Aug 22, 2007 | Zenith DVR413 DVD Recorder/VCR
192 people viewed this question
 Grubhead
Grubhead
