Acer aspire one does not boot, turns off immediatly
Yesterday, my AA1 did not boot, so I disassembled it, made a backup from my harddisk, and reassembled it.
After reassembling, I had 2 screws left, I tried to boot, I couldn't. It started, powerlight stayed on, a bit of noise, but that's all.
I flashed the bios (http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html) that helped! It did boot, I used it all night and this morning for a few hours.
Untill half an hour ago, it just shut down, while I was typing, and did't reboot. Now the power light turns on for one or two seconds, as does the harddisc led. I hear some sound (fan? harddisc?) for two seconds and then everything is off.
I can't boot with the Bios recovery usb-key, turns off all the same.
Any suggestions???
  • Merlijntje
    Merlijntje Dec 20, 2008
    Well, it turned out to be the two screws...
    Didn't think so, because it has been running for hours without them.
    Nevertheless: it's solved.
    And for anyone who's looking for a really, really good instruction on how to take apart and reassemble your AA1:
  • caroline41 May 25, 2009
    My AA1 does not boot up at all, the power light comes on when you press it and then goes off straight away. I have been looking for the receipt but can't find it to take it back under warranty. I'm not technically minded and don't know what to do next apart from jump on it and bin it, but it really hasn't had that much use and cost me £175 , so that would be just stupid. I have read things about Bios ?? and USB s but I'm pretty clueless. If anyone has any easy instructions in simple english it would be appreciated. x
Hi i have an acer aspire one 523h-2588 and in the bios it says "IDE0 HDD Password is : Frozen" how can i get rid of it to use my laptop again cause it wont let me see my windows
Acer Aspire One BIOS Recovery The Acer Aspire One has a built-in BIOS recovery routine, which can boot into a minimal BIOS environment via a special boot block to re-flash the BIOS, even if the system does not pass POST and does otherwise not boot anymore. This procedure is also known as Crisis Disk.
First format an USB flash drive with FAT. It does not need to be bootable.
Download the latest BIOS, and extract all files. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the flash drive. The files must not be in a folder. Rename the BIOS file to ZG5IA32.FD before proceeding. It only works with this exact filename.
Turn the AA1 off, and verify both battery and AC adapter are plugged in.
Press Fn and Esc simultaneously, keep them pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press it once. The AA1 will now access the files on the flash drive and initiate flashing the BIOS. After a while the power button stops blinking, and the AA1 reboots by itself. Wait patiently.
If it doesn't reboot, but keeps blinking, wait at least a few minutes before turning it off, and try again.
Oct 06, 2011 | Acer Aspire One AO532H-2527 Netbook
My ACER netbook turns on but the screen remains
After switching off the aa1, when trying to turn it on again, it just shows blinking leds and the fan is turning. But the screen remains black.
If your aa1 does like this probably its BIOS has been damaged...
Luckily the Acer Aspire One has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore.
Please note that the process I'm about to describe is only meant for emergencies and may void your warranty, so use at your own risk.
1) Format a USB memory key with the FAT mode.
2) Download the latest version of the BIOS from Acer support website:
3) Extract the files from the zip and put both the FLASHIT.EXE and the BIOS file in the root directory of the memory key.
4) Rename the BIOS file to ZG5IA32.FD and then remove the disk.
5) Turn the AA1 off, insert the battery and connect the AC adapter.
6) Insert the USB Memory Key into one of the USB port of the Aspire One.
7) Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on.
8) Release Fn+Esc after a few seconds, the power button will be blinking.
9) Press the power button once. The AA1 will start the BIOS flash, do not interrupt for any reason. After some minutes the power button will stop blinking, and then the AA1 will reboot. Wait till the AA1 has completed all this operations.
If everything has gone right, the BIOS is flashed and all settings are reset to default.
Nov 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Mo display
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
Sep 13, 2009 | Acer Aspire One A150-1006 Notebook
Will not bootup....got a black screen
"Download the latest BIOS, and put bothFLASHIT.EXE and the BIOS file in the root directory of the stick.Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove theUSB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected.Press Fn+Esc, keep it pressed and press the power button to turn theAA1 on. Release Fn+Esc after a few seconds, the power button will beblinking. Press the power button once. The AA1 will now initiate theBIOS flash, do not interrupt it under any circumstances. After a whilethe power button will stop blinking, and the AA1 will reboot shortlyafter. Wait patiently.
The Bios can be found from the Acer site. Source(s): http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
Aug 26, 2009 | Acer Aspire One PC Notebook
System crash
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a dikette won't work with a usb stick
May 24, 2009 | Acer Aspire One Netbook 8.9" Notebook
Aspire One won't boot
You need to get you a restoring disk...or brand new drive
May 24, 2009 | Acer Aspire One PC Notebook
I have Problems with Acer Aspire One AOA110-1113 Blue Intel Atom N270 8.9' 512MB Memory 8GB. it shows no signal on the screen. no light no cursor no nothing. only sound. and no physical damage. it just...
May 17, 2009 | Acer Aspire One AOA110-1113 Netbook
Acer One pc notebook black screen?!
That is a problem of BIOS. U need to reset your BIOS.
May 07, 2009 | Acer Aspire One PC Notebook
Acer Aspire won't power on with fully charged 9 cell battery!
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
Mar 08, 2009 | Acer Aspire One AOA110-1626 Notebook
Open Questions:
Computers & Internet Logo
2,594 people viewed this question
Alun Cox
David Payne
David Payne
