Question about Hotpoint RGB745 Gas Kitchen Range
Oven temperature off
MY hotpoint RGB745 gas oven's temperature is off, sometimes as much as 200 degrees. It seems that the problem would either be with the temp sensor in the oven or the temp controller built into the digital clock. How can I find out which one is bad?
  • Anonymous Dec 20, 2008
    Ours is doing the same thing. We have to set it at 500 for it to maintain 350-400. We tested the heat sensor and it seems fine.
    Problem Solver:
  • 6 Answers
If you have a ohm meter you can ohm out the temp sensor. It has a harness that connects in the back. Unplug it and it should read around 1100 ohms at room temp. It sounds to me more like the ignitor itself. It has to draw so many amps to open up the gas valve. Check the sensor first. If it ohms out, change the ignitor. I think your problem will go away. Tenbears.
Posted on Dec 20, 2008
  • Ron Pettybone Dec 25, 2008
    I don't know what you found but thanks for the crappy rating. I now see what the other techs mean and why a lot of them won't waste their time helping people like this.
On a Frigidaire Gallery oven, it takes forever for the oven to heat to the set temperature. 20-30 minutes. This seems like a very long time. Once it reaches the temperature the oven temperature is fine,...
Replace the door seals, they are the thin rubber strips around the front of the oven when the door is open. They are simple to change as they just clip on.
Jun 26, 2014 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas oven won't keep its temperature. I
The temperature sensor in the oven needs replacing. It is located in the back wall of the oven. About 3 inches long,metal and about the size of a thin pencil.
Nov 22, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas oven
This is an indication of low gas pressure to the oven. This condition may improve when other gas equipment is turned off and worsen when demands increase such as during cold periods where heating plants are running. Contact your local gas company to check pressures at the burners and adjust the incoming pressure to the oven accordingly.
If you found this helpful, please Vote!
Mar 03, 2008 | Hotpoint RGB745 Gas Kitchen Range
Hot Point Gas Range oven problem
Open back cover fix the nozzle by push neddle to small hole where gas passes/ clean also burner holes /check the gap between nozzle and burner ,does incline with the guide.cover it and test oven.
Dec 16, 2007 | Hotpoint RGB745 Gas Kitchen Range
try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
Oven does not maintain temperature while cooking. Oven will come on and preheat as it should but then temperature drops while cooking and remains below preheat value. Every 15 minutes or so we set the...
Hello Michael Smith,
You MODEL number only came through as a
PARTIAL ... (so I filled in the rest (assuming USA)):
RGB745 ... wea2ww
Please note:
Accordingly... you will have to VERIFY the part.
Part and video guidance are available here:
Third item on the page "heat sensor"
http://www.appliancepartspros.com/parts-for-ge-rgb745wea2ww.html
Hope this helps...
Carnac the Magnificent
Aug 13, 2017 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
312 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
