SanDisk Sansa m240 MP3 Player Logo
Rachel Fisher Posted on Apr 02, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It Wont Turn On/Off!!!
My mp3 player that i hd bought will not turn on/off it seems the menu(on/off) button is stuck or something. Please help its fairly new only had it a couple months. I anyone has a solution please contact me ASAP.
  • donramon Nov 17, 2007
    i have tried to turn it on by pushing the button for about 10 seconds but it still doesn't turn on. I opened the devices and I noticed some kind of rust build up at the internal battery (not the AAA battery). what do you think is wrong?
Anonymous
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 112 Answers
  • Posted on Apr 02, 2007
Anonymous
Expert
Level 2:
Mentor:
Answers
112
Questions
36
Helped
51293
Points
186
You need to push the on/off button and wait for about 5 seconds (try 10 just to be sure it really doesn't work). Let me know if it's still not working.
10helpful
2answers
Its stuck in disk mode screen displays a check mark that says ok to disconnect player wont turn off or go to menu screen
Try resetting it. Hold down the middle and menu buttons at the same time and it should reset itself. Then it should go to the main menu. Good Luck!
RCA Opal M4204 Locked Up
On the back of the player is a small reset hole, use something non-metallic to press in there. Something like a toothpick will work great.
This will reset the device. If the problem persists after doing this you will need to contact RCA.
Thanks
My computer wont recognize my USB
Try the following steps:
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
NOTE: Resetting will turn the player off while it is frozen.
If that doesn't work, then you may download and install the Sansa Firmware Updater and update to the latest firmware.
7helpful
3answers
Frozen ipod chromatic
:D! Okay, you unplug it and hold the middle button and menu button at the same time for a couple seconds until the apple sign comes up, Uhh then you just turn it on C:
2answers
Ok i bought a coby mp4 player and it just wont turn on for someapperent reasonand its a mp605-4g
Sometimes the factory accidently catched the hold button , try to turn this off first and then fully charge the unit or while attached to the computer scroll throught the menu to see what your settings are. In the end you may have to return it as there may be something wrong with it. Hope this helps.
2answers
Coby MP3 mp550 -1g
my mp3 player wont turn off or charge some one please help me.............. help help help
DMP400N
Since I was unable to turn my Mp3 player off, it eventually ran out of battery!
I then connected it to my pc, and now it seems to work like a charm!
Turns on but wont bring menu up
Try flashing the firmware first, if it won't communicate with the pc, try another pc. If it is still stuck you may need to replace the HD. I had the same problem after replacing the HD I was able to flash the firmware and get working.
4answers
Mpio HD-400 is stuck on loading screen windows doesnt recognize it
alotita, I have an MPIO HD-200. Does Windows play the sound like you have something attached when you plug it in? Or does Windows not regognize it al all? Either way, I've had to play with mine after I've dropped it a couple of times. I charge the battery all the way, then just keep plugging and unplugging from the USB wire. The last time, it took 20+ times before Windows would recognize it.
Stuck at start screen!
I had the same problem. I had to download iRiver's firmware upgrader software and upgrade to the latest (v2.51). http://www.iriveramerica.com/support/hd/h10_20gb.aspx
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
