Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I left my outside refrigerator door open over nite and now it seems as though no cold air is making from the freezer down to the refr.
  • 700 Answers
Un plug the unit and let it defrost. it may have frozen up when the door was left open.
Posted on Dec 21, 2008
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
Freezer working, but fridge is not. when you turn it off then back on its kicking on but fridge is not getting cold.
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 05, 2011 | Whirlpool Refrigerators
Im having a problem with my refrigerator. Freezer vent has cold air refrig does not. Kids left door open on refrig yesterday for a couple hours no definet time thats when problem started. any solutionns
Sometimes the refr still will not constantly blow cold air just because it is on and does not meet the required temperature that it's set at. In most cases, for a new refr to fully cool down, it takes 24 hrs. Let it sit for at least 6 hours with the doors closed, If it hasn't cooled off then chances are that there's a problem with the compressor. Whatever you do, don't turn up the colder knob just yet. Leave it where it was and see if it cools down, you don't want to overwork the compressor trying to reach that cooler temperature.
If after the refr sits and it still doesn't cool down, chances are you're going to have to call a repair service to come and check it out.
Dec 01, 2010 | Amana AFD2535DES French Door Refrigerator
My refrigerator keeps freezing on the refrigerator side
your damper door is frozen fully open between the refrigerator and freezer compartments and letting in too much cold air even though the temp setting is set on warmest setting,defrost it and then adjust the cold control and see if it moves again,if it freezes often the door seals may be letting in warm air from outside,condensing and freezing things up
Jan 16, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
No cold air on the right side.
Designed that way . The fan stops , so that warm outside air , is not sucked in by the fan , and circulated thru the refrig . The freezer door switch is what activates and de-activates the fan .
Nov 11, 2009 | Refrigerators
Not cooling enough
air baffle in refr stuck closed or bad control not letting open
Jun 24, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
74 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
