Question about LG Televison & Video
LG 32LT75 TV. Keeps showing black screen
My LG 32LT75 lcd tv sometimes shows a black screen when switching it on or changing channels but you can still here the sound. To get the picture on we have to turn the set off and then turn it back on again. Can anyone help as it's getting worse.
techman
  • 3130 Answers
SOURCE: toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Posted on Jun 29, 2006
SOURCE: goodmans flat screen TV.Blank screen
If it is a LCD TV, and there is a faint picture, it is probably the backlight or inverter board (probably the latter). This is a common problem (especially with PC monitors).
Do an internet search for your model and inverter, you may be able to replace it.
Make SURE you REMOVE the power lead before opening the set !!!!
Posted on Mar 03, 2008
  • 43 Answers
SOURCE: Connect LG 42LY95 LCD to Toshiba Laptop
Hiran
can you use the vga source from your laptop to the pc input on the LG a standard vga monitor cable will do then set your laptop to output the vga signal
Scott
Posted on Mar 23, 2008
SOURCE: Red screen on LG 44-inch DLP
Rear projection TVs require a light bulb (found on the right hand side of TV behind a small screw fixed panel) and this, like any bulb needs replacing from time to time. You need to get it changed by a repair guy or get a bulb yourself and do it. They're quite expensive though, £200 last I heard I think.
Posted on Oct 06, 2008
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
Tv has died
When the TV is on, if you look at the screen and can see dark images, then you will need to replace both the inverters. The inverters drive/power the back light inside the LCD to show the images. You may have to try and different channels and or inputs to truly see if you can see dark images while the TV is on. If you are hearing audio from a channel or an input then you should be able to see the dark images if just the inverters are bad.
If the screen is dead black without any dark images, then typically your LCD screen/module is bad.
If the TV powers up (power supply is good), you have audio and the remote will work with the TV (the main board is good), the only parts left is the inverters or the LCD screen/module.
I can get you LG part numbers if you need them.
May 21, 2010 | LG 42LC2D 42 in. LCD HDTV
2 year old LG Flat screen TV keeps freezing
It is not your tv its channal 9, switch off totally at the wall, disconnect aerial, turn on - tune into channel other than 9, plug in antenna again
Feb 04, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Screen on LG goes to black right after turned on.
It looks as if the backlights are being switched off at start up, this will be due to a fault either with the inverter board or a fault with the screens backlights which would mean the screen needing replaced. Contact your repair centre to have an engineer give you an estimate on the cost of repair.
Oct 24, 2009 | LG 20LS7DC 20 in. LCD TV
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
LG LCD TV remote power button turns off LG DVD Recorder as well
Hi VMUZZI,
IT Seems that teh SIMPLINK Featire of your TV/DVR is ON. Try to OFF the feature.
Mar 09, 2009 | LG DR787T DVD Recorder
Black out
Try turning off the Closed Caption..
Feb 03, 2009 | Polaroid TLA-01511C 15 in. LCD Television
Tv guide on our LG tv
If, when selecting the guide, the entire screen is black (except for the preview in the corner), then the digital main board has gone bad and will need replaced.
Hope this helps, please rate my solution.
Jan 09, 2009 | LG 32LX1D 32 in. LCD Television
Televison & Video Logo
83 people viewed this question
Computer Repairing
Computer Repairing
