Question about Blitz BZA2000D Car Audio Amplifier
Blitz BZA2000D protection error
I bought this amp on ebay and it dosent work.It has protection light on as soon as i turn the power on and constantly thumps lightly. My other amp works fine with the power setup that i have. Is it easly fixed or do i need to get my money back?
    Novelist:
    Champion:
  • 218 Answers
Either you will have to see a repair tech or get your money back. Sorry about the bad news. If you have a blown output (which is what you probably have) then it is more of a problem than a regular consumer should attempt to repair. Sorry.
Posted on Apr 02, 2007
Amp constantly blows fuses as soon as power wire is connected. anyway to fix?
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty .
.A thumbs up would be greatly appreciated if this answer is helpful to you
May 22, 2011 | AudioBahn A2002T Car Audio Amplifier
Why is the red light that says protect on? my amp turns on but it dosent work, i have a sup hooked up & it dosent work. the red light that says protect is on.
first thing check all ground and power wires and make sure ur rca wire make sure it isnt cut in anyway. after that unplug ur sub and unplug the negative wire from ur amp, while its out check the fuses on the amp if all is well put all fuses back if not get new. then plug the negative wire back in if protect goes off check for heat and if no heat inspect the wires from speaker out put all the way to the sub, look for any wire touching another this is were most problems are even the smallest wire can trip a protect. if u still cant find the problem. an amplifier specialist is in order.if its trashed go on ebay and buy a powerbass there goin cheap right now. hope i could help
Oct 12, 2010 | Lanzar VIBE266 Car Audio Amplifier
I have just bought a planet audio ap1500d and when i hooked it up the protection light turns on not the power
disconnect any woofers and retry the ignition sequence (if still in protection get yourself a digital multimeter and check to make sure you have @ least 12volts of power (if under 10 volts the amp will go in protection from under voltage)and good ground as well as remote if you do have all these things return the amp where you bought it or have it checked out) if the amp works you have a blown woofer
Sep 04, 2010 | Car Audio & Video
The red protect light is on what do I do to fix this. thank you
check that the amp is properly earthed and that the 12v, rem and gnd connections on the amp arnt touching
May 05, 2010 | Blitz 2 CHANNEL 2400 WATT CAR AMP Car...
My nitro bmw-486 amp is in protect mode how can I
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty De .A thumbs up would be greatly appreciated if this answer is helpful to you. nitro-bmw-486-amp-in-protect-mode-lv2kkrmxrai4iihdvw4m3np2-1-0.jpg
Feb 24, 2010 | Nitro BMW-486 Car Audio Amplifier
Pyramid PB1500 vs. Metrik Rem. Bass knob????
Yeah it's probably not going to work because it's not even the same brand
Jan 18, 2010 | Pyramid PB1500 Car Audio Amplifier
Red protection light is on constantly. the light won't turn green
is the remote source have enough amp to triger amp seem like that is you prob and chk you spk wire and rca too-
Mar 24, 2009 | Polk Audio PA250.2 Car Audio Amplifier
Problem with my kac-959 amp
The amp is likely going into protect mode due to failed output transistors. To eliminate other possible causes, read through the following page:
Troubleshooting - amp going into protect mode
Let me know if you have any other questions.
Sep 24, 2008 | Kenwood KAC-959 Car Audio Amplifier
My amp automatically turns over to protect when powered
Disconnect all of the speakers and see if it does the same thing. If it does come on, you will need to check all of your speaker wire as well as the speakers. If it still goes into protect, I'm afraid to say that there is a short in one or more of the output or driver stages of the amp. Unless you know how to trouble shoot solid state printed circuit boards down to the component level, you will need to have the amp look at by a pro. Good Luck
Feb 15, 2008 | Blitz BZA2160 Car Audio Amplifier
Both green and red ligt or on my jensen ka3 i dont know what it means i had it working b4 i swaped my subs for some new ones and the amp dosent work now.i dont know if is because of the red light but i...
Generally, the power light is green and the protect light is red. If the protect light is on there could be a short in the wiring or there could be an internal fault in the amp.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down (goes into protection), the amp likely has blown output transistors.
Dec 28, 2007 | Jensen KA3 Car Audio Amplifier
Blitz BZA2000D Car Audio Amplifier Logo
62 people viewed this question
Top Blitz Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Blitz Car Audio and Video Expert? Answer questions, earn points and help others
