Question about Sony NWZB133F MP3 Player
Sony Walkman can't function after format using Windows Explorer
I formatted the player, NWZ-B133F using Windows Explorer, then when I plug out to use, the device can't work. When I connect to the computer, the computer can't detect it.
  • 5 more comments
  • gphdei Jan 03, 2009
  • Soosle Jan 15, 2009
    i tried resetting using the buttin it did not work,,,, this problem is only with windows viata ,,,,,windows XP and LINUX are fine with the MP3 player !!
  • Anonymous Jan 19, 2009
    same...
  • Veniamin Apr 27, 2009
    does anybody know how to program Sony NWZB133F MP3 Player
  • hazeeq May 02, 2009
    my mp3 player cannot save song after i format it....gt solution??
  • Kathryn Hearsum May 06, 2009
    I formatted the walkman but now I can't charge the battery as it is not recognised. I get a MTP device error and cann't charge it. Help.
  • Anonymous May 23, 2009
    I conected my device to PC and after DISCONECTION IT DIDN'T work, I mean it doesn't get on and nor conect to PC
Hi! i have d same problem, no power. this happened after i transferred files to and from the mp3 player. Anyway, i already solved it. Try reset the unit. its located at the back of the unit, beside the earphone plug. It works for me. Hope this helps. Pls let me know if it did. :)
Posted on Dec 29, 2008
My sony walkman nwz b133f(b) wont start. when on, it says boot error... what should i do? do u have the firmware availble that i can download myself?
I had the same problem but i solved it.
Follow the folliwing steps.
1- Download firmware nwz-b133f (firmware nwz-b130 V-1.01)
2- Download firmware nwz-b103 (firmware nwz-b100 V-1.3)
3- First execute firmware nwz-b100 , connect your walkman when the programm
asks: please connect device. Then the program ask format your device
you will loose all the data , click accept.
4- Don´t disconnect your device , wait until format and dataload are finished.
This is necesary because firmware nwz-b130 doesn´t do the format.
5- Disconnect your walkman and you will see it doesn´t start (logical it ain´t his
firmware)
6- Now execute firmware nwz-b130 , connect your walkman when the programm
asks: please connect device. Don´t disconnect your walkman wait until program ends.
7- When finished disconnect your walkman the save way.
8- Ready like new.
Greetings Quicktronics here from Mexico.
Sep 11, 2010 | Sony NWZB133F MP3 Player
Hello, I'm not able to play files on my Sony walkman NWZ-B133F MP3 Player. Please help, the error being shown is "Boot Eeror"
boot_error
Yo tenia este problema y esta solucionada.
Sigue los siguientes pasos.
1- Baja firmware nwz-b133f (firmware nwz-b130 v-1.01)
2- Baja firmware nwz-b103 (firmware nwz-b100 v-1.3)
3- Primero ejecutar firmware nwz-b100 , conecta tu walkman
cuando pida conectar por favor el dispositivo luego pida formatear
el dispositivo vas a perder toda la informacion has click en
aceptar.
4- No desconectas tu walkman espere hasta que formatea
todo y carga todas su datos , este era necesario para el puro
formato porque el firmware nwz-b130 no lo hace.
5- Desconectas tu walkman y vas a ver que no enciende (logico no
es su firmware)
6- Ahora ejecutar firmware nwz-b130 , conecta tu walkman cuando
pida conectar por favor el dispositivo , no desconectas tu
walkman espere hasta que carga todas su datos.
7- Cuando termina desconecta tu walkman de manera segura.
8- Listo como nuevo.
Saludos Quicktronics aqui desde mexico.
Espero que la gramatica esta bien , soy Holandes.
Aug 28, 2010 | Sony NWZB133F MP3 Player
No music adds
To reformat the NWZ-S545 Walkman follow these steps found on page 92 of the operation guide:
Formatting memory [Format]
You can format the built-in flash memory of the player.
Note:
  • If the memory is formatted, all data (songs, videos, photos, etc., including sample data installed at the factory) will be erased. Be sure to verify the data stored in memory prior to formatting, and export any important data to the hard disk of your computer.
  • Be sure not to initialize (format) the built-in flash memory of the player using Windows Explorer. If you have formatted with Windows Explorer, format again using the player.
  • This function is only available in the pause mode.
  1. From the [Home] menu, select [Settings] / [Common Settings] / [Format]. [All data including songs will be deleted. Proceed?] appears.
  2. Select [Yes]. [All data will be deleted. Proceed?] appears. To cancel the operation, select [No].
  3. Select [Yes]. When initialization finishes, [Memory formatted.] appears. To cancel the operation, select [No].
Mar 26, 2010 | Sony Network Walkman NWZ-S545 Digital...
My son's new Sony Walkman NWZ-A728 suddenly won't play videos. I loaded one on to it from a stored file (in Realplayer, then Windows Media Player) but although it played this initially, suddenly it said...
Are the videos in the right format? The format that works for the mp3 is MP4 video. you must convert your videos using a mp4 converter.
i use winavi ipod converter (works with nwz a728)
Hope This Helps!
Sources: I have one myself and came across this problem :)
Jan 08, 2010 | Sony Audio Players & Recorders
New Sony NWZ-B133F/BCE Walkman does not show as removable drive
I bought a new Sony NWZ-B133F/BCE Walkman. When I plugged it to the USB the drivers got properly installed, but the player does not show as a removable device or any other device in My Computer.
just follow...be sure your player is connected to pc
go to my computer right click>>properties> IN HARDWARE TAB select device manager>portable audio>right click select update drivers>click next>tick the option let me choose driver for this device>next choose usb mass storage driver from two options click next....
AND U R DONE....
Mar 17, 2009 | Sony Walkman Video NWZ-A815 Digital Media...
NWZ-B133F Sony Walkman won't turn off, no data on it too.
Hi, you can solve the problem by upgrading (re installing ) the firmware. It is very easy to do. Go to Sony Support web site and download the latest firmware for your MP3. Then follow the instructions to update your firmware.
Jan 25, 2009 | Sony NWZB133F MP3 Player
Sony NWZB133F MP3 Player Logo
704 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
