Question about Vizio P2 42 in. HD-Ready Plasma Television
I cant get picture to fill the screen
New vizio 42 lcd tv, i cant change the format
On my remote i have a wide button and it changes it to full screen i hope this helps
Posted on Dec 20, 2008
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
New 47" Vizio tv.
Look at your remote and there should be a menu button. Once in the menu you will see a screen section that will let you select between 4:3, 16:9..... Toggle through those until you find the one that works with your tv.
Also there may be a button on your remote that looks like a box with an arrow pointing left and right. Click on that and it will toggle through the same thing mentioned above
Jul 25, 2011 | Vizio 42 in. LCD TV
I have a large spot on the right side of the LCD screen, it looks like a large water spot does it mean the VIZIO TV is going out? What can I do to make it disappear.
Not possible.Tv have damages to it LCD screen panel by an object or a person have causes by forced or putting pressure to the tv LCD screen panel itself to causing colors picture pixels and it radiation to died to causing this problems.Sorry it time to buy a new tv,because by replacing the tv LCD screen panel itself will cost u the same as a new tv.Tries buy a new tv from the VIZIO tv corporation directly return the damages LCD panel tv to them,u could get a 5 or 10% off of the tv prices.
Jun 05, 2011 | Vizio VU42L 42 in. LCD TV
I have a Vizio LCD HDTV 1080 120hz 37", ModelSV370XT. (Bought 1/10/10 at Costco) The tv fell to the ground resulting in scratches appearing in the picture screen. You can't feel scratched on the TV surface...
The statement was not complete in the forum , hence I presume the LCD was damaged while it fell to the ground.
The cost of replacing a new LCD to a new set must be reviewed unless you are able to get one swapped from an old one.
Oct 23, 2010 | Vizio SV422XVT 42 in. LCD HDTV
Vizio 42 in TV LCD HDTV white line across to of
That white line (usually jagged) is actuallly part of the transmitted picture. However, you are not intended to see it because it is located in what is known as the 5% overscan area. Your TVs today are more than just cable ready... they are a versital, technology filled multimedia display. You can see that line because the screen size or wide mode you are using is intended for 1080p/24 signals. You have 0% overscan with this screen size setting. This allows you to see ALL of the picture, including portions of the picture the broadcaster did not intend for you to see. You can change your screen size using the Wide feature in the Setup menu. See pg.62 of your user manual for details and descriptions of the various wide modes.
Mar 14, 2010 | Vizio VW42LF 42 in. LCD HDTV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
When we watch a movie on our 37" vizio it's not going into widescreen it's smaller how do you set it up so it fills the screen
You can zoom in on the picture. But you are most likely watching a movie formatted for wide screen. There are different formats of DVD's. Hope it helps.
Aug 09, 2009 | Vizio VOJ370F 37 in. LCD TV
Vizio 42 LCD turns on but no picture or sound
32 in vizio turns on but but no picture only blue screen and cant turn channels up or down
Mar 11, 2009 | Vizio L32 32 in. LCD HDTV
My picture 37" vizio hd tv does not fill in the whole screen when watching an HD channel
you need to change the aspect ratio on your cable box from 4:3 to 16:9. sould be under menu/setting/. if not try using the format button on the remote. hope this helps
Jan 02, 2009 | Vizio L32 32 in. LCD HDTV
42" Vizio LCD
Emilie, I have the same issue. I have to press the input on the TV to go through all of the inputs and whenI get back to HDMI 1 it usually goes back to nomral - but sometimes that doesnt even work. I tried calling support, but waited 40 minutes and hung up. chris
Jan 06, 2007 | Vizio L30WGU 30 in. HD-Ready LCD...
Vizio P2 42 in. HD-Ready Plasma Television Logo
284 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
