Question about Microwave Ovens
Microwave panasonic genius nn t687sa, all displays working - but will not heat tried resetting of demo mode - problem still exists any suggestions
  • 195 Answers
SOURCE: My Panason NN-C994S is on demo mode and I am
If you go to the Panasonic site you can download the manual.
www2.panasonic.com/consumer-electronics/.../model.NN-C994S
Regards
Alan Hood
ami-man
UK
Posted on Apr 06, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave oven (nn-sd997s) stuck in
It may be in the startup mode. Try this:
Setting the Clock
1. Press Timer/Clock twice. Colon flashes.
2. Set time of day using Time Dial. Time appears in the display window; colon continues flashing.
3. Press Timer/Clock. Colon stops flashing; time of day is entered.
If that doesn't do it, try unplugging it for a minute or two then try again.
Is the Child Lock on?
To Set Child Lock Press Start 3 times. “LOCK” appears in the display window. "LOCK" continues to be displayed until Child Lock is cancelled. Keypads may be pressed but the microwave will not start.
To Cancel Child Lock Press Stop/Reset 3 times. The display will return to colon or time of day when Child Lock has been cancelled.
You can download your owner's manual here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 27, 2008
SOURCE: Panasonic Dimension 4 the Genius
i had to take the entire cover off the microwave (it is held in pace by screws at back as well as the bottom). Take the busted bulb to hardware store (bunnings) or panasonic spares and replace. Note I have a slightly different models (nn9853, nn9807).
AH
Posted on May 26, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave Panasonic Genius Prestige Model
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Posted on Sep 28, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Stuck in Demo mode
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
If that doesn't work, check the owner's manual.
You should be able to download your Panasonic owner's manual here.
Posted on Dec 07, 2008
Why does it stay on demo mode?
Once a unit is in demo or showroom mode, it will stay and not exit. It doesn't matter if it's unplugged or not. Look in user manual and see if it list how to exit. Good luck!
Jan 29, 2016 | Panasonic Genius Prestige NN-SE782S -...
Turn off demo mode
Jeanine,
Here is a copy of the manual for your microwave. Check page 11 for instructions on taking off demo mode. http://service.us.panasonic.com/OPERMANPDF/NNH735BF.PDF
May 16, 2015 | Panasonic NN-H765BF 1250 Watt Microwave...
How do I get out of demo mode on a NN-A524M panasonic slimline microwave?
You can clear it if doesnt take it to the technician its must be reseted
Sep 16, 2014 | Microwave Ovens
Turn off demo mode
Unplug it if doesnt its work it may be the pc board
Sep 13, 2014 | Panasonic NN-H765BF 1250 Watt Microwave...
Panasonic inverter nn-cf778s
Demonstration Mode
This is to enable you to experiment setting various
programs. (The letter D will always appear in the display
window. This is to confirm that there is no microwave
power produced and it is safe to use the oven without
any food). To set Demonstration Mode: press micro
power once, then press Stop/Cancel 4 times. To cancel
Demonstration Mode press Micro power once, then
Feb 03, 2012 | Panasonic Microwave Ovens
How do I get my Panasonic Inverter microwave out of demo mode? I think my toddler might have hit something to put it in demo!
Hello Two options to try: a) Press the Clock / Timer button 3 times b) Unplug, wait a few seconds, then re-plug to power up with the factory settings. You will need to reset your clock and any favourite settings.
This should work with all Panasonic Microwave models.
Good luck
Aug 10, 2010 | Panasonic NN-H275 Microwave Oven
Model NN 9804 U microwave in Demo Mode
No owner's manual?
If you're in the US, find it here.
If you're not in the US, see Panasonic.net and look for support / download links.
Otherwise, I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 14, 2010 | Panasonic NN-T888S Convection/Microwave...
Microwave stuck in demo mode
try unplugging it for 10 minutes. Otherwise, try looking at the instructions:
service.us.panasonic.com/OPERMANPDF/NNC994S.PDF
Sep 14, 2009 | Panasonic NN-C980 Convection/Microwave...
Panasonic NNA554W
Try pressing the clock button 3 times.
Jun 22, 2009 | Panasonic NN-C994S Convection/Microwave...
Microwave Ovens Logo
436 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
