Question about Samsung TXN3275HF 32" TV
Samsung Flat Screen Won't turn On
Hi My Samsung just became unresponsive, tried a good outlet, and tried to turn with the preset remote-nothing. Before I try to open the TV, do you have any thoughts? Thanks Paul
  • 2 more comments
  • uSee360_net Dec 16, 2007
    TV just stopped working. I've called into several repair shops, and apparently this has been pretty common. One tech told me he had replaced 16 power supply's in the past 6 months. Which, from one tech, in one metro area, that's a serious problem. Called Samsung, who said they would send me a refurbished one, then they renegged, when I called back about it, they said they thought it was a computer monitor. I explained the issue, and apparently, they don't care if there's a serious malfunction on these models. Back to the drawing board, I got an LCD flat screen, and it's great! Not Samsung this time. I'm going to crack her open and see if I can fix it myself, and then re-sell it.
    Does anyone have a part number on the power supply and corresponding circuits/wires that I might need to have?
  • pumbowins Jul 05, 2008
    well my tv will work fine then when i shut it off it wont come back on so i took it apart to find a blown fuse once replaced the tv is fine till you shut it off and expect it to come back on. and suggestions?
  • mdscherle Nov 19, 2008
    Samsung TV just went off. Everything else works (cable box, etc) but the TV won't. Its under a year old!!
  • Anonymous Dec 30, 2008
    Hi
    I have the same problem with my Samsung Model TXN3275HF. However I checked my fuse, and it seem to test fine. Problem to be determined. I'm leaning towards the power supply.
  • 3 Answers
Replacing the fuse worked for a few days, and then the fuse went out again. I did this 2 times already. The TV repair shop says it might be the "degaussing unit." He may charge me $175 to fix it.
In this bad economy, it may be worth it to fix it than to buy a $1000+ TV.
Posted on Sep 16, 2008
I had the exact same problem. Before I threw the TV away, I opened it up and saw a blown fuse near the power cable connection.
I just replaced the tiny fuse in the same TV. It's a 250-Volt 5-Amps fuse. Make sure you get this exact fuse. Otherwise, it will blow again. Now, the TV's working fine.
Posted on Sep 05, 2008
    Genius:
  • 1,074 Answers
Yea take your tv to a tech tv has a problem in the power supply there is 10mf cap in the power supply that likes to go bad replace it if that model does not have it check regulator and the microchip.however your problem lies in the powerand related circuit.good luck
Posted on Apr 06, 2007
I have a Samsung Plasma TV (pn60f5300afxza) and when i try to open my TV there is nothing on the screen and the red light flashes. The screen doesn't open or nothing.
Samsung remotes sometimes have buttons up the top of their remotes to control other devices. I accidentally hit these sometimes and they change the controller to another (not connected). Ensure TV Button on top of controller is pressed before using remote to turn on tv.
Nov 07, 2016 | Samsung Cell Phones
I have an RCA F31672ET TV. It was working fine for many years. Then all of the sudden it will not turn on with either the remote or the power button. I thought of using a universal remote to try and turn...
Hi - pretty common problem. Not worth fixing, I'm afraid. It is caused by a defective circuit which became defective with old age. the "EEPROM."
Feb 27, 2011 | RCA F31672ET TV
42 Inch Samsung Flatscreen; 1.5 years old. Won't
First test the wall outlet, try plugging a lamp into the same outlet see if it works. If the outlet works then read the following below. If the wall outlet doesn't work then plug the TV into another outlet.
If its not the wall outlet:
Unfortunately the power supply has a problem sustaining DC output. This can be caused from several fault scenarios. Get someone who is technically savvy and I will show them via e-mail what to test to fix this problem for you. Or you can take it to your local repair center.
Dec 20, 2009 | Samsung HP-T4254 42 in. Plasma Television
TV will not power on
the remote button has change resistance... its a carbon film resistor on board.. cleaning
Dec 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Samsung 40" Full HD LCD
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE:
Aug 22, 2008 | Samsung LN-S2651D 26 in. LCD Television
My remote is not responding to the tv even i have changed the new baterry
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Samsung BN59-00599A Remote Control
RCA P52960 R/P lost all controls..remote & panel!1 HELP
Hello ChupacabraV2,
This is a scene from some horror movie. I bet , if you unplug it, the TV will still be on!!....Just messing with you. Its been several days since you posted this problem. Please post update if there is any change. I don't think you have the TV on all this time. Let us know
Best regards
circuitcity
May 31, 2008 | RCA P52960 52" Rear Projection Television
Samsung TXN2745FP
1 your power must have failed get it checked. 2 there might be problen in horizontal section.
Sep 13, 2007 | Samsung TXN2745FP 27" TV
Samsung TXN3275HF 32" TV Logo
1,164 people viewed this question
Demonic-2011
Demonic-2011
Steve Allison
Steve Allison
