this box updates automatically. virgin have found a way to cut the signal off. you can press menu then numbers 1570 and go onto nagravision menu and it will tell you how to enter the code. if you can't get this menu then you havent got the right firmware in the box. hope this helps.
key 00 = 5C 2C 26 36 CF 81 AB 66 key 01 = 2C 10 35 AC 06 57 BE 6F To enter the codes 1 - Press menu 2 - Press 1570 3 - Make sure key emu is on 4 - Enter nagravision 5 - Make sure it says ntl at the top box, if not press right till it says ntl 6 - Key number should be on 00 7 - Go to key data and put this code in To enter the codes 1 - Press menu 2 - Press 1570 3 - Make sure key emu is on 4 - Enter nagravision 5 - Make sure it says ntl at the top box, if not press right till it says ntl 6 - Key number should be on 00 7 - Go to key data and put this code in ******************* 8 - Go to key number and press right so its on 01 9 - Press down so you are on key data and enter this code ****************** 10 - Press ok to save 11 - All done8 - Go to key number and press right so its on 01 9 - Press down so you are on key data and enter this code ****************** 10 - Press ok to save 11 - All done
When my box does this I just re-scan it..that normally works...press menu then factory setting type in 0000 then go to installation and auto re-scan (will take several mins) when done make sure the emu key is on. and you should have all your channels back.
Good luck Gord
Ps if you need them the NTL codes are 00=B0 B8 4F 04 E6 5F 87 80 01=A3 EB EC 07 D6 49 D2 EB
To input the codes press menu then key in 1570 this will bring up another menu..enter nagravision to input the codes.
Press menu
go to user installation
go to parental lock
press red button on remote for key manager
go to nagra page
click on code to change with hexkey pad
for replay lite i got solution thanks for help
