Question about Intel D946GZIS Motherboard
CAN'T GET MY NEW INSTALL OF VISTA TO RECOGNIZE MY SATA HDD
    President:
  • 1,179 Answers
Make sure that bios is set to SATA not to IDE. Hope this helps.
Posted on Dec 21, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 21, 2008
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
Need sata achi drivers so i can istall a sata hdd
You sure? Most of the time if your motherboard has sata connections then the bios should recognize the hard drive and once the computer comes up. It should come up with new hardware found and then install the drivers on it's own, however if it doesn't or won't go the the hard drive manufactures website and you should be able to find the drivers you need there. Probably under the drivers and help section of the website. Hope this helps
Jun 18, 2010 | HP Pavilion a1200y (EK457AV) PC Desktop
I can't get Vista Ultimate set up to recognize my WD 1TB HDD in a new build. Is this a software problem or problem with the HDD. I get the short beep at BIOS start up so I don't think its with the...
Few steps to check your harddisk status on the motherboard would resolve this issue. Checkin to the cmos setup and look for the detection of the HDD and the size it shows once you have done a formating.
Vista 64 bit shows issues at times while installing a new SATA 1TB HDD. Check if the 1TB HDD is installed on to SATA 0.
Use a WD Disk Manager and format the HDD initially and then try install Vista on to it. Else if this doesnt work on the system, Put the HD on to another working system and Format it with NTFS File system and try installing Vista.. You will be successful. Good Luck.
Feb 13, 2010 | Gigabyte GA-MA785GPMT-UD2H AM3 AMD 785G...
My Gateway CX2724 will not install a fresh copy of XP on new Harddrive. HDD is a newly formatted, and the BIOS is set to recognize CDROM, HDD, and so on. The SETUP is still stating that it can not see the...
You need to go into the BIOS and change the SATA type to IDE and not AHCI. I had this same problem on my laptop. Once I switched it to IDE it installed XP no problem. I don't know if Vista or 7 work with it set to IDE mode.
Nov 28, 2009 | Gateway CX2724 Notebook
Sata drive is not recognized by os during new install
When installing XP or Vista you get the option to load third party drivers for unknown devices. I think it's F6 just after the start of any version of Windows, once you press this you will have to supply the drivers for the Windows installation. This will make Windows recognise the hdd from then on.
Aug 18, 2009 | Gateway MT6821 Notebook
I have a gigbyte GA-MA790XT-UD4P mother board that when I try to install XP on a new Seagate 1TB Barracuda HDD, that it won't recognize during the install process
If your hdd is sata and you have an old mobo , windows xp (onlycvista will) will not recognize it. Integrate sata in xp (use nliteand goolgle how to) or use the flloopy disk to run sata driver
Mar 29, 2009 | Gigabyte GA-K8VM800M Motherboard
I cant install vista OS on this MBD , by sata HDD
You must enter setup at boot and select the CD/DVD as first boot. Then ensure that the BIOS settings have SATA enabled. When CD/DVD is first boot watch the screen for 'press any key to boot from cd' message is displayed. The boot screen will say how to enter setup. Typical buttons are F2, Delete, F1, F10 -you did not say which manufacturer. OEM trumps mobo maker with BIOS setup.
Oct 14, 2008 | Gigabyte GA-8KNXP Motherboard
Not Recognized?
The device driver is causing a conflict with the system. If you have got any specific cd with hardrive install the driver from the cd. Otherwise , i would suggest try changing he manufacturer of the hdd and get a new one. If you have recently bought it.
Otherwise try creating a new account in windows vista on your computer and then try plugging in the drive
Proton
Aug 01, 2008 | Fujitsu 160GB MHY2160BH 2.5" SATA 5400 RPM...
HP DV2700Tx Windows vista to XP Downgrade
you will need to download the SATA controller driver from
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-56416-1&lc=en&cc=uk&lang=en&os=228&product=3641490&dlc=en
without that your laptop won't recognize your hard drive there
are 2 ways to solve this:
first one you'll need an external floppy drive save the sata driver on a floppy put your xp disk in and start the install at the very begining xp prompts you press F6 to install sata driver press that and it'll get the driver from the external floppy drive.
second way is to create an xp disk with the sata driver to achieve that you'll need a deployment software i use nlite
http://www.nliteos.com/ if you have any problems add me to your msn messenger atlascomputerrepair@hotmail.co.uk and i'll talk you through it
May 03, 2008 | Panasonic U7500 Notebook
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
Intel D946GZIS Motherboard Logo
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
