The two rear speaker on 5.1 surround sound are working but produce no sound when played through only through the test. could u advise me on how to change the levels so that sound can be heard from all 5 speakers and the woofer?
  • 67 Answers
If you have diffrent mode's on your system like---
3ch,pro logic, and or live,hall pavilion,try setting them@pro logic first.then if you have DSP mode that increases the rear effect the higher the number the stronger the effect.
Posted on Dec 20, 2008
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
I've had my Denon AVR-2308CI receiver for 3 years and last week I turned it on to watch a movie and there is no sound coming from my rear speakers? I have a 5 speaker set up (3 in front and 2 in the rear)...
On the front display of the unit, you should have indicator icons that light up if a speaker is being used. Are there only 3 speakers lite up, or are there 5? As a quick check, make sure your speaker connections are secure, and then make sure your surround mode is set to a 5 channel surround mode. 5 channel Stereo is a good one to test with. Also, you can hit the "test" button to see if the speakers are connected and working, it will give a test signal out of each speaker independently. Let me know what you find, and I can answer more.
Mar 05, 2011 | Denon AVR-2805 Receiver
No surround sound with Prima HT-TW57P DVD System
I realize this may sound silly but it could be the disc your are playing. Some DVDs are not mixed for surround sound and thoes that are produce very little sound from the rears.
Rear speakers were meant for effect, not meant to distract you from the picture.
Give this a try, get a movie playing that is 5.1 surround sound. Check that the home theatre is not set to stereo mode, if it is change the surround mode on the unit. Now that you are in the middle of an action scene disconnect the front speakers and see if there is background noise comming out of the rears.
If its still dead let me know more details about the system and I will work on a solution.
Cheers,
Jan 06, 2010 | Televison & Video
Speaker output doesnt work
Hi when using surround sound its important to understand that not all soundtracks have a "rear channel' meaning that the rear speakers will not always produce sound. In fact the rear channels may only produce sound about 10% of the time.
Your receiver has a "test tone" which sends a tone sound through the 5 speakers you should turn the speakers up or down so that all 5 speakers produce about the same volume.
The speakers of course will have a different sound to them depending on the brand and model but just try to balance it as much as possible.
Should also point out that you need to start out with at minimum a STEREO signal and that it needs to be connected with good quality cables. If possible use the optical inputs or HDMI which is a digital signal but not all receivers have that capability.
Lastly play around with the settings Dolby is of course the standard but many receivers have Neo or other proprietary surround formats which may produce the desired effect.
Hope that helps
Jan 02, 2010 | JVC RX-558V
Rear surround sound speakers not working during movie.
Look on your manual, page E16. Go into your speaker setup. Select your speakers (Front,C,Surround, Sub) and make sure each are selected as "small" (make sure you go through each one). If the surrounds are selected as "none" the rear will not activate and will light up as red on the display. Let me know if this helps.
May 02, 2009 | Koss KS3102 System
2 Dell 5650 have no sound
the surround sound speakers plug into the rear of the computer with three plugs. an adapter comes with it to plug those three into one green plug. if you plug that green plug in, the rear and center speakers should work, although i don't know if the surround sound will work correctly but you should get sound
Apr 03, 2009 | Dell 5650 Computer Speakers
Reciever only allows 2 channels(speakers) at a time.
If the amplifier is not receiving a surround sound signal, you will get nothing from the rear speakers and probably nothing from the front centre. Play a dvd in dolby surround and it will work.
Apr 14, 2017 | Pioneer VSX-918V Receiver
Rear Surround speakers
Best thing to do is to put the unit in 5 channel or 7 channel mode. That will send left ch information to the front left and rear left speakers ( both will get the same information). Ditto with the right channel. The center channel will get centre channel information.
If all the speakers work, go out and rent TOP GUN. ( yes its old), BUT there are a few extreme scenes , one of which is the elevator scene, where the camera changes perspective and suddenly you hear the elevator doors close BEHIND you through only the surround speakers ( have the unit in surround mode....NOT 5 or 7 ch mode ). If this works ok, then you have no problems.
Remember, surround sound only produces information in the rear channels when the information is there. To check out the digital and DTS decoders, get an action flick. If you can, get a remote too, because that will unlock many features about the receiver that you cant get to with the front panel controls. Also go to yamaha and download the owners manual ( its free !!).....that should get you going.....
best of luck...
Rob
Jun 08, 2008 | JVC RX-880V
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
78 people viewed this question
 Grubhead
Grubhead
