Question about Kenwood Audio Players & Recorders
I have a Kenwood CD Receiver Model#KDC232MR that I use on my motorcycle. I took my bike in for detail and when I got it back he radio was not working. I use this mainly as a receiver for the Sirius receiver. The problem seems to be no power to the unit itself,when I take the facepiece off there is a red light flashing. What could be wrong.
  • 1 more comment
  • Stephen Subin
    Stephen Subin Dec 20, 2008
    All wiring has been checked out and the fuse was replaced: still no power to the unit itself:as mentioned its a Kenwood CD Receiver model# KDC232MR: worked one day didn't the next.
  • Stephen Subin
    when I remove the faceplate I can see a red light flashing on the lower right side; Hope this helps
  • Stephen Subin
    Yes I guess that's about what I throught: if its in error mode then I guess I could just send it back to Kenwood: Thanks for your help
    Sergeant:
  • 233 Answers
The yellow wire should have 12 volts all the time, red is 12 volts switched (ignition).. being that the red LED is still flashing, this means it has power on the yellow wire. check to see that you have 12v at the red wire (At the stereo plug) and also check the fuse in the back of the unit...you will have to unplug it to see the fuse, it is right by the fuse socket.
If the fuse is good, and you have 12v on the yellow and red wires, and a good ground on the black, then You might need to look into another satellite capable kenwood.
Stereos mounted motorcycles and boats suffer alot, due to humidity and all the extra moisture they are subjected to. IF you do have to replace this unit, I would recommend using a Kenwood MARINE unit, as they ase designed to deal with the extra moisture. The circuit boards in these units are epoxy coated and sealed from moisture - this doesnt mean they are "indestructible" but they will last alot longer than a average stereo.
Posted on Dec 20, 2008
  • 916 Answers
There is a fuse both in the back of the deck...and in your fuse panel...
Refer to your service manual for the car to find the correct fuse for the audion system.
and
Refer to your service manual for your deck to see what im talking about...all the fuses Ive seen just plug into the back of the deck.
Also all the wiring could be correct but one may be loose.
Try cleaning all the contact points and resetting it and make sure that the fuses have power going to them.
    Brigadier General:
  • 5,158 Answers
The read flashing light is "normal" .... warns theives when the faceplate is removed. when you put the face plate back on is it seating properly... also was the power unhooked from the radio for any length of time ?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, your info that the problem came about after a detailing work is significant. Probable faults could be:
  • press the reset button, right side of the faceplate after the SRC;
  • moisture inside the unit, try using a can of compressed air. Use the long small tube/nozzle to fit inside the unit;
  • clean the multiple contacts both of the unit and the faceplate;
  • there are two (2) wires that supply the need power, yellow from the always on B+12 such as the battery terminal and red which is ACC controlled +12.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Kenwood Master
  • 19,396 Answers
If there is no power at all, check the fuse. If you have a red light on the unit it means there is power, but unit is not starting.
If you have a red light the radio is on error mode for some reason, in this case do the following:
  • Ensure the radio is not just asking you the anti theft code, in this case you will be asked to input a code to proceed.
  • Unplug power negative battery for ten minutes, this will reset the radio.
  • Check the wiring at the back, ensure there is no short or missing contact.
If all the above did not help that means that the radio is on error mode, in this case it must be removed and tested on an external 12v DC 5A regulated power supply, and taken apart for testing. This job is usally done at car stereo fitter repair shop.
  • 10,594 Answers
Let me know does the red light flashing in circuit board or just behind of front panel.
  • Shahid Electronics
    Shahid Electronics Dec 20, 2008
    Find is there any reset switch located, press it once and place front panel back and insert cd or select tuner.
    President:
  • 2,110 Answers
and
Looking for a Kenwood KDC X397 owner’s manual? .
Yes of course. See the link
hard copy of this Google Search
KDC-MP238/CR KDC-MP208 KDC-138/CR - Kenwood
manual.kenwood.com/files/B64-3898-00_00_KW.pdf
Translate this page
2 ' KDC-MP238/CR/KDC-MP208/KDC-138/CR. Contents. Before use. 3. Basic Operation. 4. General functions. Tuner functions. Disc play functions. General ... Menu Operation. 10. Menu System. Activating Security Code. Deactivating Security Code. Manual Clock Adjustment. Auxiliary Input Display Setting. Receive mode ...
Kenwood KDC-138 CD Player User Manual - ManualsOnline.com
www.manualsonline.com > ... > Home Audio Kenwood > Kenwood CD Player Record the serial number, found on the back of the unit, in the spaces designated on the. warranty card, and in the space provided below. Refer to the model and serial numbers. whenever you call upon your Kenwood dealer for information or service on the product. Model KDC-MP238/CR/MP208/138/CR Serial number.
KENWOOD KDC-138 INSTRUCTION MANUAL Pdf Download.
https://www.manualslib.com > Brands > Kenwood Manuals > Car Receiver > KDC-138 View and Download Kenwood KDC-138 instruction manual online. Kenwood CD-RECEIVER INSTRUCTION MANUAL. KDC-138 Car Receiver pdf manual download. KDC-MP238/CR KDC-MP208 KDC-138/CR CD-RECEIVER INSTRUCTION MANUAL AMPLI-TUNER LECTEUR DE CD MODE D'EMPLOI REPRODUCTOR ...
Connecting Wires To Terminals - Kenwood KDC-138 Instruction ...
https://www.manualslib.com > ... > Car Receiver > KDC-138 > Instruction manual
Kenwood KDC-138 Manual Online: Connecting Wires To Terminals. To Kenwood disc changer/ External optional accessory (KDC-MP238 only) Fuse (10A) Wiring harness (Accessory1) Power control/Motor antenna control wire (Blue/White) TEL mute wire (Brown) Not Used (Blue) White/Black White...
Kenwood Car Stereo Head Unit Replacement Wiring Harness Plug ...
https://www.amazon.ca/Kenwood-Stereo...Wiring-Harness/dp/B005X273W8 Rating: 4.7 - ‎15 reviews
Kenwood Replacement Stereo 16 Pin Wire harness; Top quality all copper 18 gauge leads. Perfect Fit.Molex type 6 inch long black color; KDC KRC DPX KTS models see the descrition for model compatibility; Kenwood power harness plug 16 pin indash radio and video units; Allows for installation of an aftermarket radio ...
Mar 23, 2018 | The Computers & Internet
Need wiring diagram for Kenwood KDC-X679 CD receiver for my 1997 Chevy truck
The manual for the Kenwood Excelon KDC-X679 has the wiring diagram for the connections to the car/truck on page 33. Crutchfield has the manual on the product page: http://www.crutchfield.com/S-FpCU7SY0yQm/p_113KDCX679/Kenwood-Excelon-KDC-X679.html . (Click on the Details tab.) The direct link to the manual is http://pdf.crutchfieldonline.com/ImageBank/v20050828082600/Manuals/113/113KDCX679.PDF .
Kenwood also has the manual on their support page: http://manual.kenwood.com/en_contents/search/ . Just enter the model number. On this site, you can find the manual is several languages. The direct link to the English version of the manual is http://manual.kenwood.com/files/B64-2764-00.pdf .
I hope this helps.
Jan 30, 2016 | Kenwood Car Audio & Video
Where does the orange and pink wire go to dpx303
You have only provided us with details on your Kenwood Receiver, but not the vehicle make or model.
Therefore, I can only answer based on the Kenwood receiver wiring.
The Kenwood receiver loom has an ORANGE (White stripe) wire - this connects to your vehicle's "Dimmer" control wire.
Kenwood receiver loom does not have a Pink wire.
Hope this helps.
Dec 18, 2012 | Kenwood DPX303 CD receiver
I have a kenwood it says,kdc-mp142 and all of a sudden it just says protect. it wont do anything
The Kenwood radio will generally give a "PROTECT" error if the amp or receiver is being overloaded. This may mean that some of your wiring may have gotten frayed, one of your speakers isn't putting out the right voltage, or the receiver has decided to go bad. Make sure all of your connections in the back of the radio are solid and not frayed. If that's not the problem, try running each of the speakers one at a time. If one causes the radio to go into protect mode, that's your culprit.
If neither of these are the issue and the radio decides to stay in "protect" mode, your receiver may have seen better days and may need a replacement.
Feb 28, 2011 | Kenwood KDC-MP142 Car CD/ MP3 Player
Need security code for kenwood kdc232mr
You will need to visit an Authorized Dealer or service center for that product to get the unlock code reset. You can find a dealer listing on their website, or call them.
Jan 05, 2011 | Kenwood 50W x 4 MOSFET Apple iPod...
I have an KDC-MP435U receiver with 160w kenwood speakers. can you please advise for the the best speakers for this model? can I add a subwoofer? Please advise how can I improve my car sound. I'm using this...
Yes you can add a subwoofer. you will need an amplifier and feed the signal to the amp with your subwooder output rca jacks on the back of the radio. this will give you control over the sub.
Jan 03, 2009 | Kenwood KDC-MP435U CD Player
Kenwood receiver/sub problem
The amp's remote turn-on wire is probably connected to the blue wire coming from the back of the stereo - this is intended for a power antenna, which is why it only works when listening to the radio. Disconnect it from the blue wire and connect it to the blue/white wire coming from the back of the receiver and you should be good to go.
Sep 21, 2007 | Kenwood KSC-WD250 Car Subwoofer
29 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
rigger094
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
