Question about Mitsubishi VS-50703 50" Rear Projection Television
Mitsubishi VS-50703 Our power went off and came back on very quickly the other night. Now the TV is just showing a blue screen. We are only able to get Antenna A and B. We used to have inputs 1-3 and DVD. I have tried going to menu and setting up channels again. I have tried unplugging and plugging in again. Nothing, just a blue sceen and I am able to use the menu. No sound either. thanks
To Fix TV: Press Menu then 1-7-3-0.
Make sure Initial is highlighted in yellow and press Enter.
To get additional input channels:
Press Menu/SetUp/AV Connection/Locked to Input 1: Should be on NO.
1(800)332-2119 Mitsubishi Customer Support
Posted on Feb 06, 2008
  • Mark Kroehler
    Mark Kroehler Mar 30, 2014
    Had a similar problem, but had sound and could view the picture in Setup mode. Followed the second set of instructions and the set is now functional.
Won't turn on
Posted on Aug 25, 2011
    Genius:
  • 1,074 Answers
Tv has a problem in the IF circuit or power supply have a tech check your tv.good luck.
Posted on Apr 16, 2007
Westinghouse ew32s5kw tv red light shows power is going to unit pressing power turns indicator light from red to blue for a brief moment then back to red.
I had the same problem on my Westinghouse 32 inch TV. The internal main power supply went bad and had to be replaced. I had a TV repair shop do it. It was about 8 years ago. Haven't had a problem since. I think it cost about $70 for parts and labor. Nowadays TVs are pretty much a throw away item if they go bad. TV repair shops are getting hard to find plus the cost of TVs has come down so much sometimes you can get a new set for what the repair would cost!
Oct 25, 2017 | Westinghouse Televison & Video
TV shows no input service
You may have to change / adjust the settings on your tv to use cable vs over the air antenna. When power was lost, this setting may have defaulted back to factory (Air / Antenna).
If the cable tuner is damaged, you don't need to write off the tv just yet. Try connecting a VCR to the AV / Component Video jacks, and feed the cable through the VCR (use the vcr as the tuner). Take a few more steps, but you will still be able to use the tv.
Jun 23, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Screen has gone to blue screen.....
OK A Blue screen, indicate that there is, or the TV "Thinks" there is NO SIGNAL. Please Check your Antenna Connection. Unplug the TV, for 5 mins or so. You MUST prove either the TV or it's "Signal Source" the Antenna. Try the antenna on another TV, if possible, try another antenna,on the TV, Try feeding in a signal via the EXTERNAL inputs. IF ALL Inputs are proved OK, and the TV, still will NOT display any signal, then it would appear that you may have a "Tuner" fault, or some other underlying condition, that affects the reception. In my professional opinion, in that case is to get the unit looked at by a Toshiba, recommended service center, VERY IMPORTANT to do that. Ask for a "Quote" from that service center, and go from there.
Apr 16, 2010 | Toshiba 37AV500U 37 in. LCD TV
Apex 19" #LD1919
1. UNPLUG the TV from the wall or power strip.
2. Turn ON the TV (w/o the power plugged in).
3. Plug the power cable back in.
4. Turn ON TV ... it should work...
5. Also... adjust antenna if you are on "broadcast" mode.
Sep 03, 2009 | Apex Digital LD1919 19 in. LCD TV
Nothig bu a blue screen shows when turned on
Blue screen of Death?
No, this is not windoze.
can you change channels?
a blue screen usually means that you don't have a signal.
Is it hooked up through dvd/vcr player?
Try a straight connection to cable or antenna.
If it remains, then it requires surgery.
Sep 30, 2008 | LG 42LC2D 42 in. LCD HDTV
Blue screen sony
blue crt shorting use crt restorer to lift short or replace picture tube /crt
Aug 19, 2008 | Sony KP-46WT500 46" Rear Projection...
Screen is blue
the problem will either fix itself out or the screen will go. chances are one color goes then the next and then its toast but can go after blue as well.
Aug 06, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Black Screen
The first step here is to isolate the problem. You need to know if it is in your TV or DVR. Unplug your TV from the DVR and connect it directly to the wall outlet. Then connect a TV antenna, or a small thin wire, to the F connector on the back of the TV (this is the threaded connector - where you plug your cable). Try searching for some air channels and see if you get any channels at all, and post back.
Feb 26, 2008 | Apex Digital AT2708 27" TV
Televison & Video Logo
582 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
