Question about Garmin GPS
When turning on my nuvi 200w sat nav I get the error message "System Software Missing"
  • 2 more comments
  • trev55 Dec 20, 2008
    have tried reboot but no joy so far , any other ideas?
    have tried to reload software as advised but get the message , "upload data is corrupted" - where do I go from here?
    I fear that i have inadvertently downloaded some software that is incompatible with my unit - I recall seeing something somewhere that said this may cause the unit to become inoperative, suspect I may have to send back to manufacturer, is there any way I can avoid having to do this?
    I'm still not having any joy, will keep persevering but if anybody else has any other ideas I would very much appreciate receiving them
  • 19,396 Answers
The message "System Software Missing", means that the software is corrupted.
In this case, reset by holding the power button will not help , as software is damaged and must be reinstalled. Reset only clear settings to factory default.
The system software must be update, and this is normally done doing Webupdate.
If you additionally get "Update file corrupted", then you need to reinstall also the updater:
If the download does not work straight from Garmin, do the download using a computer and upload a special recovery file, called Update.exe provided by Garmin on the Nuvi using USB cable.
To get the Update.exe file for your model, you need to contact Garmin support, they will give you the right file for your Garmin model, and for your region.
Do not download Update.exe from the Internet, if you chose the wrong version you can damage your Garmin.
Call Garmin and safely install the right patch.
See:
Contact Garmin Support
Once you upload the Update.exe using a computer, you should be able to do the rest of the updates with the garmin regular update tool (Webupdate) , see
Garmin Update Guide on how to do updates once updater is working.
Let me know how it goes.
Posted on Dec 20, 2008
  • 199 Answers
From here:
  1. Power off the unit.
  2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
  3. Once the pre boot mode message disappears release the power button and your device will perform some activites to recover from the above problem.
    President:
  • 1,257 Answers
Try this solution as it is..It will fix the error message "System Software Missing" ------------------------------------------------------------------------------------------------1. Power off the unit.
Apparently this sequence will only work with the above error. I hope this assists other if they encounter this problem
REGARDS
DILIP BAGDI
    President:
  • 2,110 Answers
Http://www8.garmin.com/software/WebUpdater_241.exe
download this software to update system software thorough ur PC...
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls think of your Garmin as a computer. In certain instances, the Operating System crashes, gets corrupted or just plain goes faulty. Assuming no hardware fault, it is a matter of re-installing the OS or in your case the System Software.
Fortunately, Garmin made this plain and simple. The process is done by and through your computer using the Internet to access the Garmin Server(s), download the most recent firmware (System Software), connect your Garmin to the computer and follow on screen instructions.
Pls start here.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 20, 2008
    You might be interested referencing this page.
    Genius:
  • 1,847 Answers
Try this: Hold the power buuton down, you will see on the lower screen the word "Pre Booting - ". Keep holding the power button for about 60 second, then you will see on the lower screen "Booting".
This time, release power button; system will reboot and loading map... again.
How do i unlock my sat nav, when i dont know the pin code, which my child has put on it
1.- Power off the GPS
2.- Press and hold the reset button
3.- connect the N?vi to an EXTERNAL power source
From the user manual
For the soft reset holf the lower - right corner while power on, wait still pressing the lower - right corner till the message appears.
Oct 17, 2010 | Garmin nuvi 200W GPS Receiver
Tip
Nuvi 200W Webupdate
Garmin Nuvi 200W Webupdate
Models: Garmin Nuvi 200, 200W, 250, 250W, 260, 260W, 270
Models: Garmin Nuvi 205, 205W, 215, 215W, 255, 255W, 265, 265W, 275
Does your Garmin Nuvi 200 or 200W GPS get stuck or freeze at startup, or when loading maps?
Looking to reflash the firmware / system software for your Garmin GPS device?
Replacing the brains of your Garmin GPS is the surest way to resolve freezing, hanging, and erratic behavior. Keeping the system software and firmware in your Garmin GPS current and up-to-date is also the best way to keep it performing well.
Your GPS may not start properly at all, and display a 'System Software Missing" message. This tip will describe how to restore your Garmin Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your computer and update the system software of your GPS.
Your Garmin Nuvi should now be running as good as new.
I hope that helps.
____________________________
Download your Garmin Nuvi 200 Series manuals here.
Download your Garmin Nuvi 205 Series manuals here.
Garmin Nuvi Hard Reset Here.
Garmin Nuvi 200W Favorites Backup here
on Apr 17, 2010 | Garmin nuvi 200W GPS Receiver
Have accidently wiped mapping from garmin sat nav
I can help you fix your Garmin Nuvi 200.
The error message you are receiving about maps is actually a sign of a firmware corruption problem, which just happens from time to time with electronic devices. Updating the firmware of your nuvi will replace the corrupt firmware.
These are the steps to take to update your Nuvi 200:
Download and then run Garmin 200 WebUpdater to replace its firmware / system software. Occasionally a nuvi 200 will also need a Hard Reset (preceded by a favorites backup) to bring it back to 100% operation.
I hope that helps.
_____________________________
Nuvi 200 Manuals here.
Backup your favorites.
Nuvi 200 Hard Reset.
Apr 09, 2010 | Garmin nuvi 200W GPS Receiver
My nuvi 200w turns on with an error message that says " No detailed maps found that support routing. The Nuvi cannot be used without them. " Please advise on a fix. I have downloaded the most current...
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
There was a WebUpdate release on March 31, 2010, so even if you have downloaded it before, I recommend you do it again.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Feb 16, 2010 | Garmin nuvi 200W GPS Receiver
Can i download free maps for my 2year old garminnuvi200 satnav and from which site
You can update mapping software on most sat nav units to take into account alterations to the road network. Either from your PC, in the case of portable sat navs; or via your phones GPRS connection, in the case of phone models. Always check the level of mapping that comes with your equipment in the first place. Is it up-to-date?
. Every couple of years Garmin will release a map update, which you can get on DVD or download - you've got to pay for it though!
Oct 18, 2009 | Garmin nuvi 200W GPS Receiver
When i turn on the sat nav it brings up a message
This is an indication that your map unlock code has either been corrupted or is missing. Please see thisloink for more information on this problem.
http://www.sharc.net/discus/messages/6/250.html?1247812497
- Jim
Sep 01, 2009 | Garmin nuvi 200W GPS Receiver
Garmin 200w map freezing problems
Not being able to start up and freezing up are signs that the system software or firmware of your Nuvi has become corrupt.
I hope that helps.
Jul 17, 2009 | Garmin nuvi 200W GPS Receiver
My sat nav wont load and start
I hope that helps.
Jul 13, 2009 | Garmin nuvi 200W GPS Receiver
How do youcess your sd card on the garmin nuvi 200w series please
i lost my card for my garmin nuvi 200w series do i really need it
Mar 21, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 200w shows system software missing.
I had the same thing happen. I called customer service
(1-800-800-1020). They linked to my computer (nuvi was pluged into it)
and fixed everything!
Dec 24, 2008 | Garmin nuvi 200W GPS Receiver
GPS Logo
78 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
