Question about Apple iPhone Smartphone
I restored my iphone manually i didnt save any thing it said it would take an hour its been for hours but it still just shows the pinapple sign with a black back ground what should i do
  • dantura111 Dec 21, 2008
    i restored manually is show me apple icon
  • 405 Answers
You should start over. You can't hurt it, just restore it in Itunes, and start again. but before you do unplug it and reboot and see what happens. Good luck! merry christmas!
Posted on Dec 23, 2008
I reset my iphone 3g..and it says that it would only take about an hour..but after an hour in didnt start up..it hanged up..it shows only the logo from the screen. how can i fix this?pls help..thx alot
Hi, How do you reset you iphone? Do you want to restore to original factory setting or restore to the back up. Everytime you connect your iphone to computer which have Itunes, Itunes will try to sync the change between Itunes and your Iphone. Before doing that, Itunes always create a back up. If you want, you can restore to early good point back up. There is other way to restore your iphone. Google and download your iphone firmware, save it. When click Restore in Itunes, press Shift key at the same time, it will ask you the firmware you want to restore, browser where you saved and restore you iphone to the firmware you want. Hope this will help. Thanks for reading.
Jul 11, 2011 | Apple iPhone Smartphone
My iphone 3g had a trouble on its memory, when i want to enter my photo album it said the memory is too big it cant be saved. whereas, in the graphic, it shows that there are still enough room for it. i...
You erased all data, so you will need to:
1. Reconnect iPhone to the computer
2. Choose Restore
3. Choose the last saved profile, or whichever one you'd like and restore to that profile.
Next time you want to erase the amt of pic's on the phone, just use the tab in iTunes and deselect the folders you'd like to remove then sync and you'll have made room.
Hope this helps,
Matt
Feb 26, 2011 | Apple iPhone Smartphone
My iphone has passcode locked and saying to try after 20 million minutes.. what can i do?? please help
try the password after sometimes....still your phone no working means just format your phone...
Jan 12, 2011 | Cell Phones
I'm having trouble setting this item. I can get it to come on, but it won't turn off at the set time. What am I doing wrong? Thanks, Janene
I don't have a Woods 59112 Manual
Here's link to Woods 49063 manual aka Woods TD1000 aka Noma TD1000
If manual is same/similar as your manual, then read solution given below
If solution below is incorrect, the write out your instructions ... I found that writing out instructions makes things clear.
Solution:
I think you have set ON time but did not set corresponding OFF time
Below is whole programming layout for you to read through
The important thing is to look at the display while programming
For example, lets say you are setting ON time for PROG1
For ON time, the display shows 3 things:
-display shows PROG in upper left corner
-display shows the number 1 to right of time
-display shows the word ON to the right of the number 1
Now you want to set OFF time for PROG1
For OFF, the display shows 3 things:
-display shows PROG as before
-display shows 1 as before
-display has changed and shows the word OFF to right of number 1
Here's how to set Woods TD1000 timer
Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set current time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Oct 05, 2010 | Woods INDUSTRIES 59112 INDOOR DIGITAL...
There are 3 signs on my cell while charging.
firmware issue. kindly download 3.1.2 firmware and and jail break it using blackrain.
to download firmware visit www.redmondpie.com for blackrain : www.blackra1n.com
use itunes to update the phone to select the firmware keep pressing SHIFT button n then press restore n browse n select the firmware file.
Feb 28, 2010 | Apple iPhone Smartphone
I reset all settings on my iphone 3G it took over an hour after it was finish all it does is showing the apple logo and it would not go past that. How can I fix it? Can someone help!
I think the only thing you can do now is restore your iPhone to the factory setting. If I can chat with you then I can show you every steps. But you can check on the iPhone manual or just connect to iTune choose restore and do what it say on the screen. Good luck and hope this help ;)
Aug 31, 2009 | Apple iPhone 3G
Did a factory restore yesterday but now i phone only displaying apple symbol, periodically showing "wheel" (as though thinking about something) and then turning off and straight back on...is this the...
hmm it might be, but 4 hours is way too long.
I'd suggest putting it in DFU mode
connect to PC or MAC
hold sleep/wake+Home button for 10 seconds
release sleep/wake but CONTINUE HOLDING HOME
after a while itunes will say it's detected an iphone in recovery mode. Restore from here.
Aug 17, 2009 | Apple iPhone Smartphone
Reset my 3g Iphone now it will not come on
press and hold the power/home button till the screen gose black.(before the apple logo appers)
then plug iphone into comp and hold home button down,
itunes will see the iphone as a new phone.
You're going to have to put it into recovery mode and do a restore
u will loose every DATA!!!
plz rate.
thnx
Feb 08, 2009 | Apple iPhone 3G
Apple iPhone Smartphone Logo
116 people viewed this question
Top Apple Cell Phones Experts
Marvin
Marvin
Martin Buck
Martin Buck
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
