Question about Atrix Black Gamer Case w/ Maximum Filtered Airflow Meshed Side Panels and LCD Readout, Front USB&Fir... (CASCINP9001C4)
Tiny CD conection cord probe suposed to fit positiveto foot 25 negative foot 26
ATRIX Game Case A 900 1 The case is a lovely case,fittings and other probes are no bother. But this one is driving me nuts. The picture I have uploaded is the CD Connection Cord attached to the front panel multifunctional Display, There are 2 pins to fit into the IDE cable feet which goes to "CD Rom feet 25 (Positive) and 26 ( Negative)" The picture I have uploaded also has the temperature probes, but I have no problem with them. The problem is how to get the pins into the IDE Lead feet, where it says in foot 25 and 26. Yes I know where pins 25 and 26 are. But I cannot for the life of me fathom out how to place this connection. I have never seen one like this before, and I have been building computers for about 10 year. The Instructions are not very good,they point to the 40 Ribbon lead holes, but where the lead would already have the pins from the actual drive already in there. How can the pins on this probe type thing be fitted when the ribon cable is attached to the drive? DOH! It driving me up the wall. thanks Joyce
  • Joyce Richardson
    Joyce Richardson Apr 15, 2007
    The two pinned prong has to fit in the back side of the IDE lead, on the opposite side of the holes for the pins. (That is really the base of the pin holes, not the pin holes them-selves). This is not that easy to do on some IDE leads as new leads are ultra and it takes forever to count the tiny wires to find the base of pins 25 and 26. This would have been easy on the older leads, but the newer one's I had to count about 10 times to be sure I had the right pins, as I kept forgetting where I was. Once I was sure of the exact pins, I marked them with the: - & + under the connection with a CD writing pen. Remembering not to push the probe in to far, incase it made conntact with the pins from the drive, or split the thin wires. If your lead also has a backing on it with the tabs on to help pull the lead off the drive, you would have to remove this, and also the plastic strip covering the back of the connection. Then insert the two pins in the base of the connection. It did not really make this instruction clear on the case info leaflet, which was a pitiful excuse for instructions.
    But all is running fine.
  • Anonymous Jul 12, 2008
    Although I didn't quite have the same problem, my question was to do with the connectors for the CPU fan etc. The case connector would connect directly into the mobo connection for the CPU fan but that would leave me with nowhere to plug in the CPU fan lead. If I plug the fan lead into the mobo connection, I would have to piggy-back the case lead - but it has that tab to make it connect the correct way round and so won't piggy-back. Instructions aren't pitiful, they are completely useless! Any pointers as to how you connected the CPU fan leads for the case?
Actually the pins go on the Slave connector (the connector in the middle of the IDE cable) while the CD/DVD is connector to the Master connector which is on the end.
Posted on Apr 27, 2008
I need to know where the vacum line from the ball shaped object under the hood of my 95 s10 with a 2.2 engine conects to its off and i cant find the place it is supose to hook to
That is the vacuum resevoir tank and I believe it hooks onto a fitting at the base of the throttle body; it should be a small, half inch long tiny pipe. Take off air cleaner which sits on top of throttle body and look on base where it fastens to the engine manifold.
Dec 07, 2014 | Cars & Trucks
I cant replace my pull cord on my bc30 zip start ryobi weed eater?
On the equipment I have worked on the spring ends are formed into a circle. One end of the spring fits into the pulley and the other into the case. I wind the spring up on the pully just enough to fit it into the case with the cord placed into a notch in the pulley. Then you must wind the spring more so the cord is fully taken up. So to wind it up some more place the cord in the notch and turn it a turn or two till the cord is fully taken up.
Mar 07, 2014 | Garden
Hi just recently my psp cd rom case came off. as a result,it cant read the UMD. can anyone help? thanks nihal
Well, you should clean the CD and check for scratches and attempt to fit the case back on snug. If it still won't read it, you need a whole new game sadly.
Sep 29, 2011 | Sony PlayStation Portable (PSP) Slim...
I HAVE AN OCTOBER 2008 XBOX AND A 150W 12.1 AMP POWERBRICK FROM A NEWISH XBOX . PLUG ON POWERBRICK WILL NOT FIT SOCKET ON XBOX
The power cords for the Xbox 360 and the Xbox 360 slim have different shaped plugs. If the plug you are using is not fitting it is likely that you have purchased the incorrect cord. If this is the case you will need to purchase a new cord.
When you purchase your new power cord make sure that it is designed for the original Xbox 360 NOT the Xbox 360 slim.
Jun 13, 2011 | Microsoft Xbox 360 Console
Replace the case for nintendo ds lite touch screen stopped working
Hi did you replace the shell an now the touch screen isnt working
If so you either have damaged the P6 conecter where the touchscreen goes or it is not in far enough or needs a new 1 can be sorted for a reasonable price i fit a lot of them
Aug 04, 2010 | Nintendo DS Lite Console
My wii fit board wont switch the blue light flashes then goes off
Unplug the AC adapter on your console out of the Power cord then wait 15 min and plug it back again.Open the front cover on your Wii, then push the red button there, then open the batteries cover on your Wii Fit and push the red button there.If this not help press and hold the red button on your Wii for 20 seconds.This will clear all synced Wii Remotes from the console.Then repeat the procedure again.In this case you need to SYNC your Wii Remote too.If this not help your Wii Fit may need service.
Nov 03, 2009 | Nintendo Wii Fit - Balance Board + Game...
Fitting front headlights in Saab 900 1993
You really need to clarify what you are trying to do!
The headlight case is secured by two horizontal bolts at the top of the case, visible from outside the car and under the hood when it is slid forward but not raised, and one vertical screw at the outside of the case that connects to the body or side lamp case(?) and is visible from inside the engine bay. There is no adjustment to the fitting of the headlight case to the body.
Aiming the headlights is done with the nylon knobs on the back of the headlight, from inside the engine bay.
Oct 07, 2009 | 1993 Saab 900
Atrix 9006-C4 Black Midi Case 520W fitting for lcd display
There will be "headers" on the motherboard for some case fans. Look for 2/3 pin connections on the board marked "sysfn" or something similar. Any other fans you will have to fit to a spare Molex power connector from the power supply ... you can buy 2 or 3 way "splitter" cables to give you more power connections from one Molex for this purpose. BTW make sure you connect the cpu fan to the "cpu fn" header !!!!! That one is rather important :-P
Dec 20, 2008 | Atrix (CSCI-C8001-C43) ATX Mid-Tower Case
Installing the game Age of Mythology on my PC
Look on the back of your game manual, within the CD case sleeve jacket plastic goodness, etc. It is usually black characters on a white background and hidden somewhere inside the packaging. Keep this key and don't share it with anyone - it's unique to your specific game.
Jun 27, 2008 | Video Game Consoles & Games
I broke my temp probe on my raidmax
if by the probe you understand front fan controller,yes,there are controlers to replace yours..just pay attention to fit in the bay..
Jan 21, 2008 | RaidMax SIRIUS (ATX-701WS) ATX Mid-Tower...
Computers & Internet Logo
131 people viewed this question
Top Atrix Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Atrix Computer and Internet Expert? Answer questions, earn points and help others
