Question about Hitachi 53UWX10B 53" Rear Projection Television
Volume Just recently I have a volume issue. The volume used to be loaud at setting of 24 now I have to turn it up to 35-40 o hear it. I have tried different speakers but that does nothing for it. Any suggestion as I woul prefer to fix this than buying a new tv.
I have the same problem with my 51S500 which just started. I used to have it set at 12-14, now needs to be 25-30. Playing DVDs is not affected. External speakers hooked into the external speaker jacks are affected.
Posted on Jan 08, 2008
  • 1Bonzai Jan 08, 2008
    Sorry, this was not meant to be posted as a solution...my bad!
    I found my solution, hope it helps anyone else with the same problem. There is a separate volume control on my HD cable box that had been turned down, which is strange because no one ever touches it. (I blame it on my wife...) By turning it up, problem solved!
How to I turn the universal volume on a Norton Networks T7316E Phone?
Have you tried to call the phone and adjust the volume on the set while the call is coming in? I think the only way you can adjust the ringer volume is if the phone is ringing.
Jun 25, 2015 | Nortel Networks T7316E Telephone Platinum...
I have a motorola razr v3 that i hear fine out of but others cant hear me
You will have to get your cellphone repaired that is the only solution to fix this problem.IF it is under warranty then please get it replaced.
You can try taking the phone apart if you want and clean and reattached the connections to the speaker in the phone.
Good luck,
Please don't forget to rate the solution.
Mar 30, 2008 | Motorola Mobility RAZR V3
How can I reset the volume control? All of a sudden, I can barely hear with the volume set at max.
You do not mention the type of Motorola radio so this answer will be general. You may have a problem with your volume potentiometer, Receive (Rx) sensitivity, or a speaker problem.
The volume pot on a 2-way radio is a common failure item, and will after repeated use possibly fail, or get dead spots. Try backing off your volume to 75% and see if it is louder at this setting. If so, you have a bad volume pot.
Rx sensitivity can be caused by various internal problems with the radio,and some models are more prone to this than others. Operating your radio at full volume most of the time can bring this issue to the forefront. (Tip: Try running your radios at 80-90% volume vs. full volume to alleviate this problem.) If this is your issue, your effected radios are in need of repair. Most repair facilities (including ours) can correct Rx sensitivity in most models during a repair.
Speaker problems: If you work in an environment where dirt, debris or metal shavings can get inside the speaker, your speaker may fail over time. Or if you run your radio at full volume the majority of the time it can cause your speaker to fail.
Best regards.
Oct 13, 2014 | Motorola Walkie Talkies 2-Way Radio
I am having problems with our daughter's tv. The volume isnt working now even though the picture is fine?
Have you looked at the headphone jack? Sometimes a set is left plugged in and sound wil not come out of speakers.
Also, look at cable box. It can sometimes have a separate volume control.
last, if you plug in a set of headphones and you hear sound, pick up a pair of inexpensive powered speakers and use those.
Jul 10, 2014 | Bush 5693D 24" TV
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
Just purchased a used hk 3370,only hear a little bit of sound if I turn the volume all the way up.Tried both speaker sets and headphone jack,all the same
Turn the volume down. Maximum volume is not a troubleshooting tool. If it's silent at half volume, it's essentially source-free. No sense blowing your speakers up when we find the setting that's wrong.
http://www.retrevo.com/support/Harman-Kardon-HK3370-Receivers-manual/id/386ag421/t/2/
Let's us FM for the initial silence issue. Tune a station.
Look carefully at the front panel. Analyze every indicator.
Is MUTED turned on?
Is a Tape selected by mistake?
Page 6: items 14 and 15 should be joined by jumpers.
Feb 10, 2011 | Harman Kardon HK 3370 Receiver
Sony Wega 32in with a volume problem
use it with energy of any shockwave
Jul 11, 2009 | Sony Televison & Video
Outside caller hears themselves in an echo
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
Jan 23, 2009 | Plantronics CS55 Wireless Headset
Volume Control
How do you have it hooked up to speakers (are you using a center channel)? What listening mode are you in (dolby digital, stereo, pro-logic...)? It sounds as though you're not getting center channel info....
Jan 09, 2008 | Onkyo TX-SR605 Receiver
Hitaci volume problem, pls help !!
My problem is solved. There is a separate volume control on my HD cable box that had been turned down. By turning it back up the issue was corrected.
Jun 18, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
