I have samsung mm vb9 multi audio system. the cd player door in not opening
4 Suggested Answers
SOURCE: RCA 2656 bookshelf music system cd door
I have a similar stereo system and accidentally put two CD's in one tray and it got stuck and could not open. What I did was unplug everything from the unit and took off the side panel. After some careful fiddling I got it to open. You could try something like that.
Posted on May 11, 2009
  • 314 Answers
SOURCE: Stuck CD in the multi CD player of 2004 Chevy Malibu Maxx
The only thing that is left for you to do is to remove the stereo and then disassemble it and remove it yourself. A little daunting but needs to be done. Sounds like it went in wrong and then became jammed
Posted on Jun 10, 2009
seabelow
  • 95 Answers
SOURCE: the update cd for the
put it in the upper unit (main) don't load it from new 3 slot
Posted on Jun 14, 2011
How do I connect my Yamaha RX-V733 to a CD Player?
I don't see a RX-V733 on Yamaha's site. However, look for a stereo audio input on the receiver. Then use the appropriate audio cable or adapter for the CD player audio out.
Depending on the CD player, you should use either an RCA M/M to RCA M/M (red/white) audio cable or a 3.5 mm headphone to RCA stereo audio cable. (If you don't have a headphone to RCA stereo audio cable, you can use adapters on either side. Examples: 3.5 mm M to RCA F/F adapter to RCA audio cable as above or 3.5 mm M/M cable to 3.5 mm F to RCA M/M audio adapter, depending on which cable you want to use and where you connect the adapter.) After making this connection, turn on the CD player, select the appropriate input.
The connection for an external audio device (like a CD player) is shown on page 31 of the manual for the RX-V773. Even if this is a slightly different model, the image may help. The manual is available from Yamaha on the product page: http://au.yamaha.com/en/products/audio-visual/av-receivers-amps/rx-v773_g/?mode=model . Click on the Support tab. The direct link to the manual is http://download.yamaha.com/api/asset/file/?language=en&site=au.yamaha.com&asset_id=54075 .
I hope this helps.
Feb 21, 2017 | Yamaha Audio Players & Recorders
After moving doors willnot open
Koss XJ310 Shelf System Door not open - Questions - Fixya
www.fixya.com > ... > Koss > Koss XJ310 Shelf System
Question about Bang and Olufsen Audio Shelf Systems ... ...not opening. sign on screen,is flashing door.after pressing select button,sign disappears.door does not open The ... The cd player will not open when you press the open close button.
cd player door opens closes itself Audio Shelf Systems ...
www.fixya.com > Forum > Tags > cd player door opens closes itself
Get free help, advice & support for popular audio shelf system brands. ... CD player model SA248 the doors opening and closing mechanism does not work. ... flashingdoor.after pressing select button,sign disappears.door does not open The .
JVC MX-K30 CD Shelf System Cd door not open ... - Fixya
www.fixya.com > ... > JVC > JVC MX-K30 CD Shelf System
Question about Philips Audio Shelf Systems. 1 Answer · CD player door not opening. CD player door not opening when pressing cd open and closing select button ...door.after pressing select button,sign disappears.door does not open The .
How to fix a CD player drawer problem - #1 - YouTube
? 9:21
https://www.youtube.com/watch?v=FngAg3mk2Ug
Apr 27, 2008 - Uploaded by Eric Barr
When CD and DVD players stop working, its usually because of the drawer not opening and/or shutting ...
Jan 05, 2016 | Audio Players & Recorders
I have an RCA RP-8530 compact audio system and the CD player will not open. I seems stuck. Any suggestions on how to repair?
CD drawers are normally driven by a small rubber belt that comes off or snaps. If you take the top cover off the unit you might be able to find the belt. If it's broke just measure the diameter in MM and put that into Google with the words "drive belt".
Feb 15, 2015 | RCA Audio Players & Recorders
Where can I find drive belt for rca rs-9150a (opens the cd door)
I have had this unit for a number of years. Can't find the original drive belt so I've been using rubber bands. They work for a while till they dry rot. If you're doing the job yourself, go to a hardware store and get an assortment of rubber O-rings for plumbing. A little tricky to get one on the gears but I put one in a few months ago and so far it's outlasting a rubber band.
Feb 14, 2015 | RCA Audio Players & Recorders
Cd changer will not open
INTERNAL CD PLAYER PROBLEM.
TAKE TO SERVICE CENTER (AUDIO) OR CONTACT MANUFACTURER OF CD PLAYER
Jul 26, 2013 | 2008 Toyota Highlander
The gears are jammed, or the timing gear is out of sync, and possibily a bad loading belt.
May 20, 2012 | Philips Audio Players & Recorders
Disc belt needed
You need only measure the diameter in MM and put that and "CD/Cassette drive belt" into google and you should find a supplier. A few MM either side shouldn't make difference. Drive belts etc are none specific makers by the way.
May 31, 2010 | Sharper Image SA265 Shelf System
Rca multi cd player has been moved with cd's in it and will not
Take the outer casing off and manually remove the CD's hope this helps.
Jul 26, 2009 | RCA RS2652 Shelf System
I have a shelf system samsung MM-zj6, its out of order, doesn´t turn on of the source power, the display is off always, is black, what I can do? please help me. Thank you. Armando.
Hi Armando, I guess you chucked it in the bin by now, but I just fixed exactly this problem on my MM-ZJ6. It is caused by capacitor RC7 (10uF) going open circuit which puts a huge ripple on the "Power Sens" line causing a reset pulse to go to the microprocessor every 50msec, resulting in it never starting.
To find RC7, remove the right hand side panel and look at the very bottom front of the large pcb. It is the smaller of the two located there. To change it, unclip the rear panel and angle it back slightly. You may find it easier if you remove the CD unit first.
Colin.
Feb 21, 2009 | Samsung MMZJ8DABRH CD Shelf System
Dec 30, 2007 | RCA RS2531 CD Shelf System
43 people viewed this question
 Grubhead
Grubhead
